将TMS320F28335移植到TMS320377s到过程中,由于增加了GPXQESL,我在GPIO驱动程序做了相应的增加,但是出现如下问题,希望懂的大佬提点一二!!
Description Resource Path Location Type
#10010 errors encountered during linking; "PrjExe_DHL_Modem.out" not built PrjExe_DHL_Modem C/C++ Problem
#10263 BEGIN memory range has already been specified modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 93 C/C++ Problem
#10263 BOOT_RSVD memory range has already been specified modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 109 C/C++ Problem
#10263 FLASHA memory range has already been specified modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 91 C/C++ Problem
#10263 FLASHC memory range has already been specified modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 90 C/C++ Problem
#10263 FLASHD memory range has already been specified modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 89 C/C++ Problem
#10263 FLASHE memory range has already been specified modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 88 C/C++ Problem
#10263 FLASHF memory range has already been specified modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 87 C/C++ Problem
#10263 FLASHG memory range has already been specified modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 86 C/C++ Problem
#10263 FLASHH memory range has already been specified modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 85 C/C++ Problem
#10263 RESET memory range has already been specified modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 102 C/C++ Problem
#10264 BOOT_RSVD memory range overlaps existing memory range BOOT_RSVD modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 109 C/C++ Problem
#10264 RAML0123 memory range overlaps existing memory range RAMD0 modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 82 C/C++ Problem
#10264 RAML0123 memory range overlaps existing memory range RAMLS0 modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 82 C/C++ Problem
#10264 RAML0123 memory range overlaps existing memory range RAMLS1 modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 82 C/C++ Problem
#10264 RAML0123 memory range overlaps existing memory range RAMLS2 modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 82 C/C++ Problem
#10264 RAML0123 memory range overlaps existing memory range RAMLS3 modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 82 C/C++ Problem
#10264 RAML0123 memory range overlaps existing memory range RAMLS4 modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 82 C/C++ Problem
#10264 RAML4567 memory range overlaps existing memory range RAMGS0 modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 111 C/C++ Problem
#10264 RAML4567 memory range overlaps existing memory range RAMGS1 modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 111 C/C++ Problem
#10264 RAML4567 memory range overlaps existing memory range RAMGS2 modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 111 C/C++ Problem
#10264 RAML4567 memory range overlaps existing memory range RAMGS3 modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 111 C/C++ Problem
#10264 RAMM01 memory range overlaps existing memory range BOOT_RSVD modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 110 C/C++ Problem
#10264 RAMM01 memory range overlaps existing memory range RAMM1 modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 110 C/C++ Problem
#10264 RESET memory range overlaps existing memory range RESET modem_f28335_FlashROM.cmd /PrjExe_DHL_Modem line 102 C/C++ Problem
<a href="processors.wiki.ti.com/.../10099"> program will not fit into available memory. run placement with alignment/blocking fails for section ".ebss" size 0x2520 page 1. Available memory ranges: 28377S_FLASH_lnk.cmd /PrjExe_DHL_Modem line 110 C/C++ Problem
gmake: *** [PrjExe_DHL_Modem.out] Error 1 PrjExe_DHL_Modem C/C++ Problem
gmake: Target 'all' not remade because of errors. PrjExe_DHL_Modem C/C++ Problem
