The following error occurred while running the program:
uncaught JavaScript runtime exception: ReferenceError: "XML" is not defined. (C:/workspace_v7/pwm/TMS320F28335.ccxml#1)
C28xx: Error: (Error -1135 @ 0x8000) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 7.0.48.0)
C28xx: Unable to determine target status after 20 attempts
C28xx: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
