板子型号为28377D,第一次能将程序烧录,但之后就再也无法烧录程序。该程序在其他板子上可以正常烧录。
这块板子烧录程序时,报错为:
C28xx_CPU1: GEL Output:
Memory Map Initialization Complete
C28xx_CPU1: Error initializing flash programming: Interface returned from dll, but flash is not available on this device.
C28xx_CPU1: Loader: One or more sections of your program falls into a memory region that is not writable. These regions will not actually be written to the target. Check your linker configuration and/or memory map.
C28xx_CPU1: File Loader: Verification failed: Values at address 0x86000@Program do not match Please verify target memory and memory map.
C28xx_CPU1: GEL: File: E:\CCS9workspace\28377_6KVSI_zhongduan\Debug\28377_6KVSI_zhongduan.out: a data verification error occurred, file load failed.
看过其他帖子,说升级到最新版本CCS可解决该问题,我已升至CCS9.1.0,但仍出现该问题。
请问该如何解决这个问题,感谢。
