我参照ti\c2000\C2000Ware_3_03_00_00\device_support\f2837xd\examples\cpu1\adc_soc_software\cpu01
修改后,debug时发现没有读数,不知怎么回事
// FILE: main.c
// Included Files
#include "main.h"
#include "algorithm.h"
Uint16 AdcdResult0;
// Main
void main(void)
// Step 1. Initialize System Control
InitSysCtrl();
// Step 2. Initialize GPIO
InitGpio();
ConfigureGpio();
// Step 3. Clear all interrupts and initialize PIE vector table
DINT;
// Initialize the PIE control registers to their default state
InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags
IER = 0x0000;
IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt Service Routines (ISR)
InitPieVectTable();
ConfigurePieVectTable();
// Step 4. Initialize the Device Peripheral
// ConfigureADC();
SET_MUX_EN;
SET_MUX_A1;
SET_MUX_A0;
EALLOW;
AdcdRegs.ADCCTL2.bit.PRESCALE = 6; //set ADCCLK divider to /4
AdcSetMode(ADC_ADCD, ADC_RESOLUTION_12BIT, ADC_SIGNALMODE_SINGLE);
AdcdRegs.ADCCTL1.bit.INTPULSEPOS = 1;
AdcdRegs.ADCCTL1.bit.ADCPWDNZ = 1;
DELAY_US(1000);
EDIS;
EALLOW;
AdcdRegs.ADCSOC0CTL.bit.CHSEL = 0; //SOC0 will convert pin A2
AdcdRegs.ADCSOC0CTL.bit.ACQPS = 63; //sample window is acqps +
AdcdRegs.ADCINTSEL1N2.bit.INT1SEL = 1; //end of SOC1 will set INT1 flag
AdcdRegs.ADCINTSEL1N2.bit.INT1E = 1; //enable INT1 flag
AdcdRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //make sure INT1 flag is cleared
EDIS;
// InitCpuTimers();
// ConfigureCpuTimer();
// ConfigureExternalInterrupt();
ConfigureSci();
DisableEpwm();
ConfigureEPwm();
// EnableEpwm();
// Step 5. User specific code, enable interrupts
EnablingInterrupts();
// Enable global Interrupts and higher priority real-time debug events
EINT; // Enable Global interrupt INTM
ERTM; // Enable Global realtime interrupt DBGM
// for(;;)
do
AdcdRegs.ADCSOCFRC1.all = 0x0001; //SOC0 and SOC1
while(AdcdRegs.ADCINTFLG.bit.ADCINT1 == 0);
AdcdResult0 = AdcdResultRegs.ADCRESULT0;
}while(1);
