C28xx: GEL Output:
ADC Calibration not complete, check if device is unlocked and recalibrate.C28xx: Flash Programmer: Warning: The configured device (TMS320F28335), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: GEL Output:
ADC Calibration not complete, check if device is unlocked and recalibrate.C28xx: File Loader: Verification failed: Values at address 0x0802D@Program do not match Please verify target memory and memory map.
C28xx: GEL: File: C:\Users\Administrator\Desktop\DSP2833x_Project_Template_\Debug\DSP2833x_Project_Template_.out: a data verification error occurred, file load failed.
