Part Number: TMS320F280049C
Other Parts Discussed in Thread: CCSTUDIO
大家好,最近经常出现CCS8.1.0打开启动后出错后见图,用不了,必须重新安装才能用,是什么原因?谢谢。
在CCS8安装路径下搜索有很多相关log文件见图,具体哪个名字文件?
在 workspace的文件夹下,如 C:\Users\...\workspace_v6_2\.metadata
您也可以先试一下下面链接的方法
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/532151/ccsv6-an-error-has-occurred-see-the-log-file-null/1949170#1949170
见下文:
!SESSION 2021-05-24 09:47:21.509 -----------------------------------------------
eclipse.buildId=4.7.3.M20180301-0715
java.version=1.8.0_112
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
This is a continuation of log file C:\Users\Administrator\workspace_v8\.metadata\.bak_0.log
Created Time: 2021-05-24 09:51:49.371
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:51:49.371
!MESSAGE Connection to software-dl.ti.com/.../site.xml failed on Connection timed out: connect. Retry attempt 0 started
!STACK 0
java.net.ConnectException: Connection timed out: connect
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient4.ECFHttpClientSecureProtocolSocketFactory.performConnection(ECFHttpClientSecureProtocolSocketFactory.java:96)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient4.ECFHttpClientSecureProtocolSocketFactory.connectSocket(ECFHttpClientSecureProtocolSocketFactory.java:77)
at org.apache.http.conn.scheme.SchemeLayeredSocketFactoryAdaptor2.connectSocket(SchemeLayeredSocketFactoryAdaptor2.java:62)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:179)
at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:144)
at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:134)
at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:612)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:447)
at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:884)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1084)
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1075)
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:1071)
at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:74)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:51:51.745
!MESSAGE Provisioning exception
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at software-dl.ti.com/.../device_support_sitara.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:395)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:692)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.addChild(CompositeMetadataRepository.java:166)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.<init>(CompositeMetadataRepository.java:106)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:122)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:668)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.getAvailableRepositories(UpdateChecker.java:152)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.checkForUpdates(UpdateChecker.java:130)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker$UpdateCheckThread.run(UpdateChecker.java:74)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2021-05-24 09:51:51.745
!MESSAGE No repository found at software-dl.ti.com/.../device_support_sitara.
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:52:04.149
!MESSAGE Connection to software-dl.ti.com/.../content.xml.xz failed on Connection timed out: connect. Retry attempt 0 started
!STACK 0
at org.eclipse.ecf.internal.provider.filetransfer.httpclient4.ECFHttpClientProtocolSocketFactory.connectSocket(ECFHttpClientProtocolSocketFactory.java:86)
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:52:12.803
!MESSAGE Connection to software-dl.ti.com/.../p2.index failed on Connection timed out: connect. Retry attempt 0 started
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:52:56.072
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:53:24.768
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to connect to repository software-dl.ti.com/.../compositeContent.xml
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:243)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.getLocalFile(CompositeMetadataRepositoryFactory.java:73)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:98)
Caused by: java.net.ConnectException: Connection timed out: connect
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:668)
at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:542)
at org.eclipse.ecf.provider.filetransfer.httpclient4.SNIAwareHttpClient$1.connectSocket(SNIAwareHttpClient.java:64)
at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:412)
at org.apache.http.impl.conn.ManagedClientConnectionImpl.open(ManagedClientConnectionImpl.java:328)
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:263)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:53:24.768
!MESSAGE Unable to connect to repository software-dl.ti.com/.../compositeContent.xml
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:53:39.996
!MESSAGE Connection to software-dl.ti.com/.../artifacts.jar failed on Connection timed out: connect. Retry attempt 0 started
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:54:03.186
!MESSAGE Unable to connect to repository software-dl.ti.com/.../artifacts.jar
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:54:24.249
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:54:35.661
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:54:35.661
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:54:56.730
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:54:59.057
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../device_support_keystone2.
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:128)
Caused by: java.io.IOException: software-dl.ti.com/.../device_support_keystone2 is not a valid repository location.
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:102)
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 09:54:59.057
!MESSAGE Unable to read repository at software-dl.ti.com/.../device_support_keystone2.
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:55:07.696
!MESSAGE Unable to connect to repository software-dl.ti.com/.../artifacts.xml
!STACK 0
at org.apache.http.conn.scheme.PlainSocketFactory.connectSocket(PlainSocketFactory.java:120)
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:55:27.181
!MESSAGE Connection to software-dl.ti.com/.../content.jar failed on Connection timed out: connect. Retry attempt 0 started
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:55:48.413
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to connect to repository software-dl.ti.com/.../content.jar
at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:428)
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:259)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:66)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:88)
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:55:48.413
!MESSAGE Unable to connect to repository software-dl.ti.com/.../content.jar
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:55:51.522
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:56:18.301
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:57:00.847
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at software-dl.ti.com/.../device_support_radar.
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2021-05-24 09:57:00.847
!MESSAGE No repository found at software-dl.ti.com/.../device_support_radar.
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:57:21.889
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:57:28.715
!MESSAGE Unable to connect to repository software-dl.ti.com/.../content.xml
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:57:51.316
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:58:05.985
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to connect to repository software-dl.ti.com/.../content.xml
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:58:05.985
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:58:27.060
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:58:33.631
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:59:17.006
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:59:41.786
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:59:41.942
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:59:41.942
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 10:00:03.031
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:00:25.531
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../latest.
Caused by: java.io.IOException: software-dl.ti.com/.../latest is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:00:25.531
!MESSAGE Unable to read repository at software-dl.ti.com/.../latest.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:00:33.593
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../mspgcc.
Caused by: java.io.IOException: software-dl.ti.com/.../mspgcc is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:00:33.593
!MESSAGE Unable to read repository at software-dl.ti.com/.../mspgcc.
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 10:00:54.624
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:01:57.965
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 10:01:57.965
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:02:54.230
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 10:02:54.230
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 10:03:15.335
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:02.922
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 10:04:02.922
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 10:04:24.011
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:27.745
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../CCSv6.
Caused by: java.io.IOException: software-dl.ti.com/.../CCSv6 is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:04:27.745
!MESSAGE Unable to read repository at software-dl.ti.com/.../CCSv6.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:29.884
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at download.segger.com/.../JLink_TI_CCS_plugin.
Caused by: java.io.IOException: download.segger.com/.../JLink_TI_CCS_plugin is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:04:29.884
!MESSAGE Unable to read repository at download.segger.com/.../JLink_TI_CCS_plugin.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:35.432
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../CCS8.1.0.00011_update.
Caused by: java.io.IOException: software-dl.ti.com/.../CCS8.1.0.00011_update is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:04:35.432
!MESSAGE Unable to read repository at software-dl.ti.com/.../CCS8.1.0.00011_update.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:39.795
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../CCS8.2.0.00007_update.
Caused by: java.io.IOException: software-dl.ti.com/.../CCS8.2.0.00007_update is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:04:39.795
!MESSAGE Unable to read repository at software-dl.ti.com/.../CCS8.2.0.00007_update.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:44.326
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../CCS8.3.0.00009_update.
Caused by: java.io.IOException: software-dl.ti.com/.../CCS8.3.0.00009_update is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:04:44.326
!MESSAGE Unable to read repository at software-dl.ti.com/.../CCS8.3.0.00009_update.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:57.526
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../p2win32.
Caused by: java.io.IOException: software-dl.ti.com/.../p2win32 is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:04:57.526
!MESSAGE Unable to read repository at software-dl.ti.com/.../p2win32.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:05:00.712
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../p2linux.
Caused by: java.io.IOException: software-dl.ti.com/.../p2linux is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:05:00.712
!MESSAGE Unable to read repository at software-dl.ti.com/.../p2linux.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:05:03.727
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../p2osx.
Caused by: java.io.IOException: software-dl.ti.com/.../p2osx is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:05:03.727
!MESSAGE Unable to read repository at software-dl.ti.com/.../p2osx.
!STACK 0
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:05:14.434
!MESSAGE Unable to read repository at software-dl.ti.com/.../device_support.
!STACK 0
java.io.IOException: software-dl.ti.com/.../device_support is not a valid repository location.
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-05-24 12:36:09.105
!MESSAGE An internal error was logged by 'com.ti.ccstudio.errorparser'.
!STACK 0
java.net.SocketTimeoutException: connect timed out
at sun.net.NetworkClient.doConnect(NetworkClient.java:175)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:432)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:527)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:211)
at sun.net.www.http.HttpClient.New(HttpClient.java:308)
at sun.net.www.http.HttpClient.New(HttpClient.java:326)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1202)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1138)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1032)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:966)
at org.jsoup.helper.HttpConnection$Response.execute(HttpConnection.java:563)
at org.jsoup.helper.HttpConnection$Response.execute(HttpConnection.java:540)
at org.jsoup.helper.HttpConnection.execute(HttpConnection.java:227)
at org.jsoup.helper.HttpConnection.get(HttpConnection.java:216)
at com.ti.ccstudio.errorparser.parsers.PatternProvider$PatternData.fillup(PatternProvider.java:261)
at com.ti.ccstudio.errorparser.parsers.PatternProvider$PatternData.findMatch(PatternProvider.java:145)
at com.ti.ccstudio.errorparser.parsers.PatternProvider.getEmdUrl(PatternProvider.java:465)
at com.ti.ccstudio.errorparser.parsers.ErrorPattern.recordError(ErrorPattern.java:77)
at com.ti.ccstudio.errorparser.parsers.CoffErrorParser.processPendingMesg(CoffErrorParser.java:259)
at com.ti.ccstudio.errorparser.parsers.CoffErrorParser.doProcessLine(CoffErrorParser.java:111)
at com.ti.ccstudio.errorparser.parsers.BaseErrorParser.processLine(BaseErrorParser.java:313)
at org.eclipse.cdt.core.ErrorParserManager.processLine(ErrorParserManager.java:363)
at org.eclipse.cdt.core.ErrorParserManager.checkLine(ErrorParserManager.java:698)
at org.eclipse.cdt.core.ErrorParserManager.write(ErrorParserManager.java:682)
at org.eclipse.cdt.internal.core.StreamProgressMonitor.write(StreamProgressMonitor.java:101)
at java.io.OutputStream.write(OutputStream.java:75)
at com.ti.ccstudio.project.core.internal.build.temp.ProcessClosure$SynchronizedOutputStream.flushBufferedErrors(ProcessClosure.java:268)
at com.ti.ccstudio.project.core.internal.build.temp.ProcessClosure$SynchronizedOutputStream.write(ProcessClosure.java:203)
at com.ti.ccstudio.project.core.internal.build.temp.ProcessClosure$ReaderThread.run(ProcessClosure.java:90)
!SESSION 2021-05-26 14:32:37.872 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2021-05-26 14:32:46.910
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY com.ti.common.core 4 0 2021-05-26 14:32:47.441
!MESSAGE path=ccs_base/DebugServer
!ENTRY com.ti.common.core 4 0 2021-05-26 14:32:47.442
!MESSAGE debugServerDir=C:/ti/ccsv8/ccs_base/DebugServer
!ENTRY org.eclipse.launchbar.core 2 0 2021-05-26 14:33:27.372
!MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY org.eclipse.launchbar.core 2 0 2021-05-26 14:33:27.622
!MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY com.ti.ccstudio.debug.server 4 214294189 2021-05-26 14:33:29.349
!MESSAGE Unexpected CCS exit detected [21-5-24 上午9:48]!!!
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:33:51.781
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:33:55.756
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:34:24.823
!STACK 0
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-05-26 14:34:25.299
!STACK 0
org.jsoup.HttpStatusException: HTTP error fetching URL. Status=410, URL=processors.wiki.ti.com/.../
at org.jsoup.helper.HttpConnection$Response.execute(HttpConnection.java:590)
at org.jsoup.helper.HttpConnection$Response.execute(HttpConnection.java:587)
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:34:35.710
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:34:46.047
!MESSAGE Unable to connect to repository software-dl.ti.com/.../content.xml.xz
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:35:03.217
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:35:09.412
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:35:29.362
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:35:30.746
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:35:50.534
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:35:52.738
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:36:15.516
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:37:16.466
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:37:19.712
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:37:38.234
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:38:03.225
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:38:25.783
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:39:07.263
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:39:11.634
!STACK 0
!ENTRY org.eclipse.equinox.p2.artifact.repository 4 1002 2021-05-26 14:39:13.152
!MESSAGE Unable to read repository at software-dl.ti.com/.../.
!STACK 0
java.io.IOException: Invalid repository location: software-dl.ti.com/.../.
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepositoryFactory.load(SimpleArtifactRepositoryFactory.java:102)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepositoryFactory.load(SimpleArtifactRepositoryFactory.java:76)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.factoryLoad(ArtifactRepositoryManager.java:73)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:104)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:100)
at com.ti.ccstudio.p2app.DirectorApplication.initializeRepositories(DirectorApplication.java:748)
at com.ti.ccstudio.p2app.DirectorApplication.run(DirectorApplication.java:1389)
at com.ti.ccstudio.p2app.DirectorApplication.listIUsFoundInRepos(DirectorApplication.java:1775)
at com.ti.ccstudio.app.center.p2.DirectorApplicationDelegate.listIUsFoundInRepos(DirectorApplicationDelegate.java:40)
at com.ti.ccstudio.app.center.p2.DirectorApplicationDelegate.resolveIU(DirectorApplicationDelegate.java:72)
at com.ti.ccstudio.app.center.internal.CCSAppCenter._replaceIusWithLatest(CCSAppCenter.java:397)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.access$3(CCSAppCenter.java:364)
at com.ti.ccstudio.app.center.internal.CCSAppCenter$2.run(CCSAppCenter.java:240)
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:39:29.186
!MESSAGE Unable to connect to repository software-dl.ti.com/.../site.xml
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:39:50.234
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:39:57.033
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:40:18.260
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:40:35.174
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:40:39.281
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:40:56.297
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:41:42.578
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:42:00.158
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:42:03.598
!STACK 0
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:42:25.566
!STACK 0
java.io.IOException: software-dl.ti.com/.../ is not a valid repository location.
at com.ti.ccstudio.p2app.DirectorApplication.initializeRepositories(DirectorApplication.java:775)
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:42:47.078
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:43:03.529
!STACK 1
at org.eclipse.equinox.p2.engine.ProvisioningContext.loadMetadataRepository(ProvisioningContext.java:216)
at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedMetadataRepositories(ProvisioningContext.java:199)
at org.eclipse.equinox.p2.engine.ProvisioningContext.getMetadata(ProvisioningContext.java:280)
at org.eclipse.equinox.internal.p2.director.SimplePlanner.updatesFor(SimplePlanner.java:784)
at org.eclipse.equinox.p2.operations.UpdateOperation.updatesFor(UpdateOperation.java:142)
at org.eclipse.equinox.p2.operations.UpdateOperation.computeProfileChangeRequest(UpdateOperation.java:179)
at org.eclipse.equinox.p2.operations.UpdateOperation$1.run(UpdateOperation.java:323)
at org.eclipse.equinox.internal.p2.operations.SearchForUpdatesResolutionJob.runModal(SearchForUpdatesResolutionJob.java:37)
at org.eclipse.equinox.p2.operations.ProfileChangeOperation.resolveModal(ProfileChangeOperation.java:115)
at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdater.updatesAvailable(AutomaticUpdater.java:117)
at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdater.updatesAvailable(AutomaticUpdater.java:98)
at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdateScheduler$1.updatesAvailable(AutomaticUpdateScheduler.java:146)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker$UpdateCheckThread.run(UpdateChecker.java:79)
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:43:03.530
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:43:35.223
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:43:47.634
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:43:47.635
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:44:08.677
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:44:39.050
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:45:02.749
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:45:11.977
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:45:11.978
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:45:33.026
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:46:07.236
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:46:18.923
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:46:34.322
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:46:41.497
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:46:41.497
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:47:53.770
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:48:15.003
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to connect to repository software-dl.ti.com/.../site.xml
at org.eclipse.equinox.internal.p2.updatesite.UpdateSite.loadActualSiteFile(UpdateSite.java:236)
at org.eclipse.equinox.internal.p2.updatesite.UpdateSite.load(UpdateSite.java:147)
at org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSiteMetadataRepositoryFactory.initializeRepository(UpdateSiteMetadataRepositoryFactory.java:99)
at org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSiteMetadataRepositoryFactory.load(UpdateSiteMetadataRepositoryFactory.java:59)
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:48:15.004
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:48:36.100
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:48:41.904
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../device_support_radar.
Caused by: java.io.IOException: software-dl.ti.com/.../device_support_radar is not a valid repository location.
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:48:41.904
!MESSAGE Unable to read repository at software-dl.ti.com/.../device_support_radar.
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:49:11.294
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:49:32.550
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:49:32.550
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:49:53.608
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:50:15.940
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:50:15.940
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:50:22.810
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:50:22.810
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:51:13.590
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:51:13.591
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:51:57.088
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:51:57.089
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:52:18.122
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:52:23.176
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../gcc.
Caused by: java.io.IOException: software-dl.ti.com/.../gcc is not a valid repository location.
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:52:23.176
!MESSAGE Unable to read repository at software-dl.ti.com/.../gcc.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:52:32.207
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../.
Caused by: java.io.IOException: software-dl.ti.com/.../ is not a valid repository location.
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:52:32.207
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:52:53.272
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:54:00.301
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:54:00.302
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:54:03.546
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:54:03.547
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:54:48.717
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:54:48.717
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:55:09.738
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:56:13.068
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:56:13.069
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:56:16.138
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:56:16.138
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:57:22.758
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:57:22.758
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:57:43.813
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:58:47.117
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:58:47.118
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:58:51.424
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:58:51.425
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:58:55.227
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:58:55.227
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 15:00:41.753
!STACK 0
!ENTRY org.eclipse.cdt.core 1 0 2021-05-26 15:35:15.799
!MESSAGE Indexed 'OBC6600W_280049_Boot_Sci_20200402_V3' (23 sources, 163 headers) in 7.13 sec: 29,434 declarations; 29,349 references; 40 unresolved inclusions; 242 syntax errors; 311 unresolved names (0.53%)
!ENTRY org.eclipse.cdt.core 1 0 2021-05-26 18:50:04.870
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (34 sources, 168 headers) in 3.26 sec: 28,088 declarations; 33,213 references; 35 unresolved inclusions; 246 syntax errors; 464 unresolved names (0.75%)
!ENTRY org.eclipse.cdt.core 1 0 2021-05-26 18:51:02.815
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_TEST_V9104' (33 sources, 82 headers) in 0.9 sec: 15,571 declarations; 22,273 references; 40 unresolved inclusions; 241 syntax errors; 270 unresolved names (0.71%)
!ENTRY org.eclipse.cdt.core 1 0 2021-05-26 18:52:53.419
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_TEST_V9104' (33 sources, 88 headers) in 0.97 sec: 15,584 declarations; 22,540 references; 35 unresolved inclusions; 241 syntax errors; 267 unresolved names (0.7%)
!ENTRY org.eclipse.cdt.core 1 0 2021-05-27 10:29:47.518
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_V9102' (65 sources, 244 headers) in 2.11 sec: 31,133 declarations; 44,686 references; 35 unresolved inclusions; 482 syntax errors; 522 unresolved names (0.68%)
!ENTRY org.eclipse.cdt.core 1 0 2021-05-27 10:29:53.708
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_V9102' (33 sources, 88 headers) in 1.29 sec: 15,585 declarations; 22,519 references; 35 unresolved inclusions; 241 syntax errors; 267 unresolved names (0.7%)
!ENTRY org.eclipse.cdt.core 1 0 2021-05-27 10:35:44.322
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_V9104_TEST' (33 sources, 82 headers) in 1 sec: 15,571 declarations; 22,275 references; 40 unresolved inclusions; 241 syntax errors; 271 unresolved names (0.71%)
!SESSION 2021-06-04 15:17:00.142 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-06-04 15:17:08.567
!ENTRY com.ti.common.core 4 0 2021-06-04 15:17:08.689
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-04 15:17:45.811
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-04 15:17:46.059
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-04 15:17:46.060
!SESSION 2021-06-21 17:45:23.979 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-06-21 17:45:58.039
!ENTRY com.ti.common.core 4 0 2021-06-21 17:45:58.166
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-21 17:46:25.288
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-21 17:46:25.357
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-21 17:46:25.360
!ENTRY com.ti.ccstudio.app.center 4 0 2021-06-21 17:46:40.122
!MESSAGE Unable to read software-dl.ti.com/.../apps_8.1.0.json file.
!STACK 0
at sun.net.NetworkClient.doConnect(NetworkClient.java:178)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1474)
at java.net.URL.openStream(URL.java:1045)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.readFile(CCSAppCenter.java:196)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.getAppJson_0(CCSAppCenter.java:212)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.access$1(CCSAppCenter.java:211)
at com.ti.ccstudio.app.center.internal.CCSAppCenter$1.run(CCSAppCenter.java:183)
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:46:57.543
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:47:41.443
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:48:02.654
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:48:23.672
!STACK 0
!ENTRY org.eclipse.cdt.core 1 0 2021-06-21 17:48:42.927
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 88 headers) in 2.5 sec: 15,601 declarations; 22,597 references; 35 unresolved inclusions; 243 syntax errors; 240 unresolved names (0.62%)
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-06-21 17:48:44.100
!STACK 0
at com.ti.ccstudio.errorparser.parsers.CoffErrorParser.doProcessLine(CoffErrorParser.java:103)
at org.eclipse.cdt.core.errorparsers.ErrorParserNamedWrapper.processLine(ErrorParserNamedWrapper.java:48)
at com.ti.ccstudio.project.core.internal.build.ProjectAdviceManager$AdviceContentHandler.endElement(ProjectAdviceManager.java:129)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:609)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(XMLDocumentFragmentScannerImpl.java:1782)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2967)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:841)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:770)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:327)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:328)
at com.ti.ccstudio.project.core.internal.build.ProjectAdviceManager.processAdvice(ProjectAdviceManager.java:506)
at com.ti.ccstudio.project.core.internal.build.ProjectAdviceManager.handleAdviceChangingEvent(ProjectAdviceManager.java:467)
at com.ti.ccstudio.project.core.internal.build.ProjectAdviceManager.handleAdviceChangingEvent(ProjectAdviceManager.java:447)
at com.ti.ccstudio.project.core.internal.build.ProjectAdviceManager.onProjectImported(ProjectAdviceManager.java:423)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener$6.visit(ProjectStateMonitor.java:390)
at com.ti.common.project.core.internal.events.ProjectStateMonitor.notifyListeners(ProjectStateMonitor.java:859)
at com.ti.common.project.core.internal.events.ProjectStateMonitor.access$2(ProjectStateMonitor.java:848)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener.resourceChanged(ProjectStateMonitor.java:388)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:299)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:289)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:152)
at org.eclipse.core.internal.resources.Workspace.broadcastBuildEvent(Workspace.java:360)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:138)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:232)
!ENTRY org.eclipse.cdt.core 1 0 2021-06-21 17:48:46.446
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 89 headers) in 1.26 sec: 15,592 declarations; 22,549 references; 35 unresolved inclusions; 241 syntax errors; 273 unresolved names (0.71%)
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:49:13.458
!STACK 0
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2021-06-21 17:50:10.404
!MESSAGE No repository found at software-dl.ti.com/.../device_support_digital_power.
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:50:31.415
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:50:53.884
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:51:18.118
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:51:40.933
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:52:02.143
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:52:23.156
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:52:45.701
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:53:32.044
!STACK 0
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2021-06-21 17:54:21.423
!MESSAGE No repository found at software-dl.ti.com/.../device_support_keystone2.
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:54:49.774
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-06-21 17:56:03.655
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:56:03.656
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-06-21 17:56:48.515
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:56:48.516
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-06-21 17:56:53.967
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at software-dl.ti.com/.../device_support_keystone2.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:653)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2021-06-21 17:56:53.967
!ENTRY org.eclipse.ui 2 2 2021-06-22 18:51:32.505
!MESSAGE com.ti.ccstudio.system.setup.ui.views.TargetConfigurationView: Deprecated relationship "fast" should be converted to "stack".
!ENTRY org.eclipse.core.resources 4 2 2021-06-22 18:54:44.305
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
!STACK 0
java.lang.NullPointerException
at com.ti.ccstudio.system.setup.ui.editors.internal.MultiPageXMLEditor.resourceChanged(MultiPageXMLEditor.java:710)
at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:374)
at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1469)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:46)
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:26.432
!MESSAGE DS_ERROR: IcePick_C_0: Error connecting to the target: (Error -260 @ 0x0) An attempt to connect to the XDS110 failed. The cause may be one or more of: no XDS110 is connected, invalid firmware update, invalid XDS110 serial number, or faulty USB cable. The firmware and serial number may be updated using the xdsdfu utility found in the .../ccs_base/common/uscif/xds110 directory of your installation. View the ReadMe.txt file there for instructions. (Emulation package 8.0.27.9)
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:26.551
!MESSAGE DS_ERROR: Error connecting to the target:
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:29.119
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:29.172
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:33.679
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:33.731
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:39.238
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:39.252
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:42.719
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:42.775
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:06:05.365
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:06:05.385
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:06:37.095
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:06:37.140
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 20:07:44.863
!MESSAGE DS_ERROR: C28xx_CPU1: Error: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 8.0.27.9)
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 20:07:44.893
!MESSAGE DS_ERROR: C28xx_CPU1: Unable to determine target status after 20 attempts
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 20:07:44.904
!MESSAGE DS_ERROR: C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:32:21.150
!MESSAGE DS_ERROR: C28xx_CPU1: GEL: Target must be connected before calling the function
!ENTRY org.eclipse.cdt.dsf 4 10005 2021-06-23 09:32:21.157
!MESSAGE Request for monitor: 'RequestMonitor (org.eclipse.cdt.dsf.concurrent.RequestMonitor@160fb9c): Status ERROR: com.ti.ccstudio.debug code=20003 Target must be connected before calling the function null' resulted in an error.
!SUBENTRY 1 com.ti.ccstudio.debug 4 20003 2021-06-23 09:32:21.157
!MESSAGE Target must be connected before calling the function
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:40:24.763
!ENTRY org.eclipse.cdt.dsf 4 10005 2021-06-23 09:40:24.766
!MESSAGE Request for monitor: 'RequestMonitor (org.eclipse.cdt.dsf.concurrent.RequestMonitor@1ade893): Status ERROR: com.ti.ccstudio.debug code=20003 Target must be connected before calling the function null' resulted in an error.
!SUBENTRY 1 com.ti.ccstudio.debug 4 20003 2021-06-23 09:40:24.766
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:47:57.535
!MESSAGE DS_ERROR: IcePick_C_0: Error: (Error -261 @ 0xFFFFFEFB) Invalid response was received from the XDS110. (Emulation package 8.0.27.9)
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:47:57.839
!MESSAGE DS_ERROR: IcePick_C_0: Unable to determine target status after 20 attempts
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:47:57.853
!MESSAGE DS_ERROR: IcePick_C_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:47:58.005
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:47:58.009
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:47:58.010
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 15:29:43.900
!ENTRY org.eclipse.cdt.dsf 4 10005 2021-06-23 15:29:43.904
!MESSAGE Request for monitor: 'RequestMonitor (org.eclipse.cdt.dsf.concurrent.RequestMonitor@15d84f8): Status ERROR: com.ti.ccstudio.debug code=20003 Target must be connected before calling the function null' resulted in an error.
!SUBENTRY 1 com.ti.ccstudio.debug 4 20003 2021-06-23 15:29:43.904
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-25 16:03:11.990
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-25 16:03:12.242
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-25 16:03:18.205
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-25 16:03:18.341
(Error -260 @ 0x0)
for instructions.
!SESSION 2021-06-28 12:04:35.847 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-06-28 12:25:27.364
!ENTRY com.ti.common.core 4 0 2021-06-28 12:25:27.493
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-28 12:25:40.945
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-28 12:25:40.957
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-28 12:25:40.958
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-06-28 12:31:58.695
!STACK 0
!ENTRY org.eclipse.cdt.core 1 0 2021-07-02 11:53:29.456
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_Fabo' (33 sources, 82 headers) in 1.27 sec: 15,570 declarations; 21,392 references; 40 unresolved inclusions; 241 syntax errors; 271 unresolved names (0.73%)
!SESSION 2021-07-06 11:25:56.082 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-07-06 11:26:28.992
!ENTRY com.ti.common.core 4 0 2021-07-06 11:26:29.123
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-06 11:26:41.342
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-06 11:26:41.386
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-06 11:26:41.387
!ENTRY org.eclipse.cdt.core 1 0 2021-07-06 11:27:29.542
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 88 headers) in 2.29 sec: 15,599 declarations; 22,559 references; 35 unresolved inclusions; 243 syntax errors; 240 unresolved names (0.63%)
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-07-06 11:27:30.489
!STACK 0
!ENTRY org.eclipse.cdt.core 1 0 2021-07-06 11:27:31.671
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 89 headers) in 1 sec: 15,590 declarations; 22,508 references; 35 unresolved inclusions; 241 syntax errors; 275 unresolved names (0.72%)
!SESSION 2021-07-08 10:27:17.481 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2021-07-08 10:30:00.735
!ENTRY com.ti.common.core 4 0 2021-07-08 10:30:01.251
!ENTRY com.ti.common.core 4 0 2021-07-08 10:30:01.253
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-08 10:30:06.688
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-08 10:30:06.695
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-08 10:30:06.696
!ENTRY com.ti.ccstudio.debug.server 4 214294189 2021-07-08 10:30:16.075
!MESSAGE Unexpected CCS exit detected [21-7-6 上午11:26]!!!
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-07-08 10:33:04.341
!STACK 0
!SESSION 2021-07-12 11:58:58.585 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-07-12 12:24:06.995
!ENTRY com.ti.common.core 4 0 2021-07-12 12:24:07.148
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-12 12:24:19.929
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-12 12:24:19.971
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-12 12:24:19.972
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-07-12 12:28:11.156
!STACK 0
!ENTRY org.eclipse.cdt.core 1 0 2021-07-12 13:51:35.075
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_V9102New' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2021-07-12 13:55:19.778
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 82 headers) in 1.77 sec: 15,567 declarations; 22,160 references; 40 unresolved inclusions; 241 syntax errors; 270 unresolved names (0.71%)
!ENTRY org.eclipse.cdt.core 1 0 2021-07-12 13:55:27.409
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 89 headers) in 0.923 sec: 15,589 declarations; 22,438 references; 35 unresolved inclusions; 241 syntax errors; 275 unresolved names (0.72%)
!ENTRY org.eclipse.cdt.core 1 0 2021-07-12 13:57:50.613
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_DF_HV' (33 sources, 129 headers) in 1.43 sec: 28,075 declarations; 33,036 references; 40 unresolved inclusions; 242 syntax errors; 514 unresolved names (0.83%)
!SESSION 2021-07-17 12:21:54.661 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2021-07-17 12:22:31.824
!ENTRY com.ti.common.core 4 0 2021-07-17 12:22:32.353
!ENTRY com.ti.common.core 4 0 2021-07-17 12:22:32.355
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-17 12:22:37.711
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-17 12:22:37.721
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-17 12:22:37.723
!ENTRY com.ti.ccstudio.debug.server 4 214294189 2021-07-17 12:22:41.269
!MESSAGE Unexpected CCS exit detected [21-7-12 下午12:24]!!!
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-07-17 12:23:26.932
!STACK 0
!SESSION 2021-07-19 09:10:25.594 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-07-19 09:11:54.458
!ENTRY com.ti.common.core 4 0 2021-07-19 09:11:54.587
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-19 09:12:12.145
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-19 09:12:12.180
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-19 09:12:12.181
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-07-19 11:28:52.577
!STACK 0
at com.ti.ccstudio.project.core.internal.build.ProjectAdviceManager.onProjectBuild_Post(ProjectAdviceManager.java:440)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener$8.visit(ProjectStateMonitor.java:416)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener.resourceChanged(ProjectStateMonitor.java:414)
at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:496)
at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:406)
at com.ti.ccstudio.project.core.services.ProjectBuilder.internalBuildProjects(ProjectBuilder.java:279)
at com.ti.ccstudio.project.core.services.ProjectBuilder.buildProjects(ProjectBuilder.java:197)
at com.ti.ccstudio.project.ui.internal.actions.BuildActiveConfigMenuAction_hack$BuildAction_hack$2.run(BuildActiveConfigMenuAction_hack.java:83)
!ENTRY org.eclipse.cdt.core 1 0 2021-07-20 14:02:16.164
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 88 headers) in 2.68 sec: 15,601 declarations; 22,597 references; 35 unresolved inclusions; 243 syntax errors; 240 unresolved names (0.62%)
!ENTRY org.eclipse.cdt.core 1 0 2021-07-20 14:02:41.312
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_V9104' (33 sources, 82 headers) in 0.996 sec: 15,570 declarations; 22,267 references; 40 unresolved inclusions; 241 syntax errors; 270 unresolved names (0.71%)
!ENTRY org.eclipse.cdt.core 1 0 2021-07-20 14:02:45.095
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_V9104' (33 sources, 89 headers) in 1.02 sec: 15,592 declarations; 22,546 references; 35 unresolved inclusions; 241 syntax errors; 275 unresolved names (0.72%)
!ENTRY org.eclipse.ui 4 4 2021-07-22 14:24:17.866
!MESSAGE Unable to create part
!SUBENTRY 1 org.eclipse.core.filebuffers 4 0 2021-07-22 14:24:17.867
!MESSAGE Cannot determine URI for '/Obc6600KwApp_F280049_E300P_WL_V9104/source/ObcSciComm.c'.
!STACK 1
org.eclipse.core.runtime.CoreException: Cannot determine URI for '/Obc6600KwApp_F280049_E300P_WL_V9104/source/ObcSciComm.c'.
at org.eclipse.core.internal.filebuffers.ResourceFileBuffer.create(ResourceFileBuffer.java:236)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager.connect(TextFileBufferManager.java:112)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.createFileInfo(TextFileDocumentProvider.java:560)
at org.eclipse.cdt.internal.ui.editor.CDocumentProvider.createFileInfo(CDocumentProvider.java:791)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.connect(TextFileDocumentProvider.java:478)
at org.eclipse.cdt.internal.ui.editor.CDocumentProvider.connect(CDocumentProvider.java:723)
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4178)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:257)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1466)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:150)
at org.eclipse.cdt.internal.ui.editor.CEditor.internalDoSetInput(CEditor.java:1440)
at org.eclipse.cdt.internal.ui.editor.CEditor.doSetInput(CEditor.java:1405)
at org.eclipse.ui.texteditor.AbstractTextEditor$5.run(AbstractTextEditor.java:3154)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
at org.eclipse.ui.internal.WorkbenchWindow$14.run(WorkbenchWindow.java:2195)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2191)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3172)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3197)
at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:362)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:333)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:990)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:955)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:124)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:399)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:318)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:992)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:661)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:767)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:738)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:732)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:716)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:104)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:144)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4889)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:212)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:52)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:620)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:584)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:769)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1185)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3261)
at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3176)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3158)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3153)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3117)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3098)
at org.eclipse.ui.texteditor.GotoLastEditPositionAction.run(GotoLastEditPositionAction.java:85)
at org.eclipse.ui.texteditor.GotoLastEditPositionAction.run(GotoLastEditPositionAction.java:64)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:247)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:219)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$5(ActionContributionItem.java:436)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4428)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4238)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3817)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
!SUBENTRY 2 org.eclipse.core.filebuffers 4 0 2021-07-22 14:24:17.957
!ENTRY com.ti.ccstudio.ui 4 0 2021-07-22 14:24:18.005
!MESSAGE Exception during context menu override initialization for part ObcSciComm.c
!STACK 0
at com.ti.ccstudio.internal.ui.contribution.filters.PartContributionFilter.handlePartOpened(PartContributionFilter.java:147)
at com.ti.ccstudio.ui.internal.decorations.DecorationManager$PartListener.partOpened(DecorationManager.java:217)
at org.eclipse.ui.internal.PartService$10.run(PartService.java:191)
at org.eclipse.ui.internal.PartService.partOpened(PartService.java:188)
at org.eclipse.ui.internal.WorkbenchPage$23.run(WorkbenchPage.java:5106)
at org.eclipse.ui.internal.WorkbenchPage.firePartOpened(WorkbenchPage.java:5103)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.lambda$1(CompatibilityPart.java:119)
at org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl.setObject(PartImpl.java:422)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:130)
见下文:
!SESSION 2021-05-24 09:47:21.509 -----------------------------------------------
eclipse.buildId=4.7.3.M20180301-0715
java.version=1.8.0_112
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
This is a continuation of log file C:\Users\Administrator\workspace_v8\.metadata\.bak_0.log
Created Time: 2021-05-24 09:51:49.371
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:51:49.371
!MESSAGE Connection to software-dl.ti.com/.../site.xml failed on Connection timed out: connect. Retry attempt 0 started
!STACK 0
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient4.ECFHttpClientSecureProtocolSocketFactory.performConnection(ECFHttpClientSecureProtocolSocketFactory.java:96)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient4.ECFHttpClientSecureProtocolSocketFactory.connectSocket(ECFHttpClientSecureProtocolSocketFactory.java:77)
at org.apache.http.conn.scheme.SchemeLayeredSocketFactoryAdaptor2.connectSocket(SchemeLayeredSocketFactoryAdaptor2.java:62)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:179)
at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:144)
at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:134)
at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:612)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:447)
at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:884)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1084)
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1075)
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:1071)
at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:74)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:51:51.745
!MESSAGE Provisioning exception
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at software-dl.ti.com/.../device_support_sitara.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:395)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:692)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.addChild(CompositeMetadataRepository.java:166)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.<init>(CompositeMetadataRepository.java:106)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:122)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:668)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.getAvailableRepositories(UpdateChecker.java:152)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.checkForUpdates(UpdateChecker.java:130)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker$UpdateCheckThread.run(UpdateChecker.java:74)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2021-05-24 09:51:51.745
!MESSAGE No repository found at software-dl.ti.com/.../device_support_sitara.
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:52:04.149
!MESSAGE Connection to software-dl.ti.com/.../content.xml.xz failed on Connection timed out: connect. Retry attempt 0 started
!STACK 0
java.net.ConnectException: Connection timed out: connect
at org.eclipse.ecf.internal.provider.filetransfer.httpclient4.ECFHttpClientProtocolSocketFactory.connectSocket(ECFHttpClientProtocolSocketFactory.java:86)
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:52:12.803
!MESSAGE Connection to software-dl.ti.com/.../p2.index failed on Connection timed out: connect. Retry attempt 0 started
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:52:56.072
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:53:24.768
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to connect to repository software-dl.ti.com/.../compositeContent.xml
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:243)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.getLocalFile(CompositeMetadataRepositoryFactory.java:73)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:98)
Caused by: java.net.ConnectException: Connection timed out: connect
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:668)
at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:542)
at org.eclipse.ecf.provider.filetransfer.httpclient4.SNIAwareHttpClient$1.connectSocket(SNIAwareHttpClient.java:64)
at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:412)
at org.apache.http.impl.conn.ManagedClientConnectionImpl.open(ManagedClientConnectionImpl.java:328)
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:263)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:53:24.768
!MESSAGE Unable to connect to repository software-dl.ti.com/.../compositeContent.xml
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:53:39.996
!MESSAGE Connection to software-dl.ti.com/.../artifacts.jar failed on Connection timed out: connect. Retry attempt 0 started
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:54:03.186
!MESSAGE Unable to connect to repository software-dl.ti.com/.../artifacts.jar
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:54:24.249
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:54:35.661
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:54:35.661
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:54:56.730
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:54:59.057
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../device_support_keystone2.
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:128)
Caused by: java.io.IOException: software-dl.ti.com/.../device_support_keystone2 is not a valid repository location.
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:102)
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 09:54:59.057
!MESSAGE Unable to read repository at software-dl.ti.com/.../device_support_keystone2.
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:55:07.696
!MESSAGE Unable to connect to repository software-dl.ti.com/.../artifacts.xml
!STACK 0
at org.apache.http.conn.scheme.PlainSocketFactory.connectSocket(PlainSocketFactory.java:120)
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:55:27.181
!MESSAGE Connection to software-dl.ti.com/.../content.jar failed on Connection timed out: connect. Retry attempt 0 started
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:55:48.413
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to connect to repository software-dl.ti.com/.../content.jar
at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:428)
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:259)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:66)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:88)
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:55:48.413
!MESSAGE Unable to connect to repository software-dl.ti.com/.../content.jar
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:55:51.522
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:56:18.301
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:57:00.847
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at software-dl.ti.com/.../device_support_radar.
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2021-05-24 09:57:00.847
!MESSAGE No repository found at software-dl.ti.com/.../device_support_radar.
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:57:21.889
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:57:28.715
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:57:51.316
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:58:05.985
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to connect to repository software-dl.ti.com/.../content.xml
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:58:05.985
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:58:27.060
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:58:33.631
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:59:17.006
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 09:59:41.786
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 09:59:41.942
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 09:59:41.942
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 10:00:03.031
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:00:25.531
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../latest.
Caused by: java.io.IOException: software-dl.ti.com/.../latest is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:00:25.531
!MESSAGE Unable to read repository at software-dl.ti.com/.../latest.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:00:33.593
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../mspgcc.
Caused by: java.io.IOException: software-dl.ti.com/.../mspgcc is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:00:33.593
!MESSAGE Unable to read repository at software-dl.ti.com/.../mspgcc.
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 10:00:54.624
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:01:57.965
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 10:01:57.965
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:02:54.230
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 10:02:54.230
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 10:03:15.335
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:02.922
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-24 10:04:02.922
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-24 10:04:24.011
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:27.745
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../CCSv6.
Caused by: java.io.IOException: software-dl.ti.com/.../CCSv6 is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:04:27.745
!MESSAGE Unable to read repository at software-dl.ti.com/.../CCSv6.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:29.884
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at download.segger.com/.../JLink_TI_CCS_plugin.
Caused by: java.io.IOException: download.segger.com/.../JLink_TI_CCS_plugin is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:04:29.884
!MESSAGE Unable to read repository at download.segger.com/.../JLink_TI_CCS_plugin.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:35.432
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../CCS8.1.0.00011_update.
Caused by: java.io.IOException: software-dl.ti.com/.../CCS8.1.0.00011_update is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:04:35.432
!MESSAGE Unable to read repository at software-dl.ti.com/.../CCS8.1.0.00011_update.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:39.795
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../CCS8.2.0.00007_update.
Caused by: java.io.IOException: software-dl.ti.com/.../CCS8.2.0.00007_update is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:04:39.795
!MESSAGE Unable to read repository at software-dl.ti.com/.../CCS8.2.0.00007_update.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:44.326
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../CCS8.3.0.00009_update.
Caused by: java.io.IOException: software-dl.ti.com/.../CCS8.3.0.00009_update is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:04:44.326
!MESSAGE Unable to read repository at software-dl.ti.com/.../CCS8.3.0.00009_update.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:04:57.526
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../p2win32.
Caused by: java.io.IOException: software-dl.ti.com/.../p2win32 is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:04:57.526
!MESSAGE Unable to read repository at software-dl.ti.com/.../p2win32.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:05:00.712
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../p2linux.
Caused by: java.io.IOException: software-dl.ti.com/.../p2linux is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:05:00.712
!MESSAGE Unable to read repository at software-dl.ti.com/.../p2linux.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-24 10:05:03.727
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../p2osx.
Caused by: java.io.IOException: software-dl.ti.com/.../p2osx is not a valid repository location.
... 16 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:05:03.727
!MESSAGE Unable to read repository at software-dl.ti.com/.../p2osx.
!STACK 0
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-24 10:05:14.434
!MESSAGE Unable to read repository at software-dl.ti.com/.../device_support.
!STACK 0
java.io.IOException: software-dl.ti.com/.../device_support is not a valid repository location.
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-05-24 12:36:09.105
!MESSAGE An internal error was logged by 'com.ti.ccstudio.errorparser'.
!STACK 0
java.net.SocketTimeoutException: connect timed out
at sun.net.NetworkClient.doConnect(NetworkClient.java:175)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:432)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:527)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:211)
at sun.net.www.http.HttpClient.New(HttpClient.java:308)
at sun.net.www.http.HttpClient.New(HttpClient.java:326)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1202)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1138)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1032)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:966)
at org.jsoup.helper.HttpConnection$Response.execute(HttpConnection.java:563)
at org.jsoup.helper.HttpConnection$Response.execute(HttpConnection.java:540)
at org.jsoup.helper.HttpConnection.execute(HttpConnection.java:227)
at org.jsoup.helper.HttpConnection.get(HttpConnection.java:216)
at com.ti.ccstudio.errorparser.parsers.PatternProvider$PatternData.fillup(PatternProvider.java:261)
at com.ti.ccstudio.errorparser.parsers.PatternProvider$PatternData.findMatch(PatternProvider.java:145)
at com.ti.ccstudio.errorparser.parsers.PatternProvider.getEmdUrl(PatternProvider.java:465)
at com.ti.ccstudio.errorparser.parsers.ErrorPattern.recordError(ErrorPattern.java:77)
at com.ti.ccstudio.errorparser.parsers.CoffErrorParser.processPendingMesg(CoffErrorParser.java:259)
at com.ti.ccstudio.errorparser.parsers.CoffErrorParser.doProcessLine(CoffErrorParser.java:111)
at com.ti.ccstudio.errorparser.parsers.BaseErrorParser.processLine(BaseErrorParser.java:313)
at org.eclipse.cdt.core.ErrorParserManager.processLine(ErrorParserManager.java:363)
at org.eclipse.cdt.core.ErrorParserManager.checkLine(ErrorParserManager.java:698)
at org.eclipse.cdt.core.ErrorParserManager.write(ErrorParserManager.java:682)
at org.eclipse.cdt.internal.core.StreamProgressMonitor.write(StreamProgressMonitor.java:101)
at java.io.OutputStream.write(OutputStream.java:75)
at com.ti.ccstudio.project.core.internal.build.temp.ProcessClosure$SynchronizedOutputStream.flushBufferedErrors(ProcessClosure.java:268)
at com.ti.ccstudio.project.core.internal.build.temp.ProcessClosure$SynchronizedOutputStream.write(ProcessClosure.java:203)
at com.ti.ccstudio.project.core.internal.build.temp.ProcessClosure$ReaderThread.run(ProcessClosure.java:90)
!SESSION 2021-05-26 14:32:37.872 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2021-05-26 14:32:46.910
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY com.ti.common.core 4 0 2021-05-26 14:32:47.441
!MESSAGE path=ccs_base/DebugServer
!ENTRY com.ti.common.core 4 0 2021-05-26 14:32:47.442
!MESSAGE debugServerDir=C:/ti/ccsv8/ccs_base/DebugServer
!ENTRY org.eclipse.launchbar.core 2 0 2021-05-26 14:33:27.372
!MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY org.eclipse.launchbar.core 2 0 2021-05-26 14:33:27.622
!MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY com.ti.ccstudio.debug.server 4 214294189 2021-05-26 14:33:29.349
!MESSAGE Unexpected CCS exit detected [21-5-24 上午9:48]!!!
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:33:51.781
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:33:55.756
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:34:24.823
!STACK 0
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-05-26 14:34:25.299
!STACK 0
org.jsoup.HttpStatusException: HTTP error fetching URL. Status=410, URL=processors.wiki.ti.com/.../
at org.jsoup.helper.HttpConnection$Response.execute(HttpConnection.java:590)
at org.jsoup.helper.HttpConnection$Response.execute(HttpConnection.java:587)
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:34:35.710
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:34:46.047
!MESSAGE Unable to connect to repository software-dl.ti.com/.../content.xml.xz
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:35:03.217
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:35:09.412
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:35:29.362
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:35:30.746
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:35:50.534
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:35:52.738
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:36:15.516
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:37:16.466
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:37:19.712
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:37:38.234
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:38:03.225
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:38:25.783
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:39:07.263
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:39:11.634
!STACK 0
!ENTRY org.eclipse.equinox.p2.artifact.repository 4 1002 2021-05-26 14:39:13.152
!MESSAGE Unable to read repository at software-dl.ti.com/.../.
!STACK 0
java.io.IOException: Invalid repository location: software-dl.ti.com/.../.
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepositoryFactory.load(SimpleArtifactRepositoryFactory.java:102)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepositoryFactory.load(SimpleArtifactRepositoryFactory.java:76)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.factoryLoad(ArtifactRepositoryManager.java:73)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:104)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:100)
at com.ti.ccstudio.p2app.DirectorApplication.initializeRepositories(DirectorApplication.java:748)
at com.ti.ccstudio.p2app.DirectorApplication.run(DirectorApplication.java:1389)
at com.ti.ccstudio.p2app.DirectorApplication.listIUsFoundInRepos(DirectorApplication.java:1775)
at com.ti.ccstudio.app.center.p2.DirectorApplicationDelegate.listIUsFoundInRepos(DirectorApplicationDelegate.java:40)
at com.ti.ccstudio.app.center.p2.DirectorApplicationDelegate.resolveIU(DirectorApplicationDelegate.java:72)
at com.ti.ccstudio.app.center.internal.CCSAppCenter._replaceIusWithLatest(CCSAppCenter.java:397)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.access$3(CCSAppCenter.java:364)
at com.ti.ccstudio.app.center.internal.CCSAppCenter$2.run(CCSAppCenter.java:240)
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:39:29.186
!MESSAGE Unable to connect to repository software-dl.ti.com/.../site.xml
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:39:50.234
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:39:57.033
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:40:18.260
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:40:35.174
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:40:39.281
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:40:56.297
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:41:42.578
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:42:00.158
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:42:03.598
!STACK 0
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:42:25.566
!STACK 0
at com.ti.ccstudio.p2app.DirectorApplication.initializeRepositories(DirectorApplication.java:775)
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:42:47.078
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:43:03.529
!STACK 1
at org.eclipse.equinox.p2.engine.ProvisioningContext.loadMetadataRepository(ProvisioningContext.java:216)
at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedMetadataRepositories(ProvisioningContext.java:199)
at org.eclipse.equinox.p2.engine.ProvisioningContext.getMetadata(ProvisioningContext.java:280)
at org.eclipse.equinox.internal.p2.director.SimplePlanner.updatesFor(SimplePlanner.java:784)
at org.eclipse.equinox.p2.operations.UpdateOperation.updatesFor(UpdateOperation.java:142)
at org.eclipse.equinox.p2.operations.UpdateOperation.computeProfileChangeRequest(UpdateOperation.java:179)
at org.eclipse.equinox.p2.operations.UpdateOperation$1.run(UpdateOperation.java:323)
at org.eclipse.equinox.internal.p2.operations.SearchForUpdatesResolutionJob.runModal(SearchForUpdatesResolutionJob.java:37)
at org.eclipse.equinox.p2.operations.ProfileChangeOperation.resolveModal(ProfileChangeOperation.java:115)
at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdater.updatesAvailable(AutomaticUpdater.java:117)
at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdater.updatesAvailable(AutomaticUpdater.java:98)
at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdateScheduler$1.updatesAvailable(AutomaticUpdateScheduler.java:146)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker$UpdateCheckThread.run(UpdateChecker.java:79)
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:43:03.530
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:43:35.223
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:43:47.634
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:43:47.635
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:44:08.677
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:44:39.050
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:45:02.749
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:45:11.977
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:45:11.978
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:45:33.026
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:46:07.236
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:46:18.923
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:46:34.322
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:46:41.497
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:46:41.497
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:47:53.770
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:48:15.003
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to connect to repository software-dl.ti.com/.../site.xml
at org.eclipse.equinox.internal.p2.updatesite.UpdateSite.loadActualSiteFile(UpdateSite.java:236)
at org.eclipse.equinox.internal.p2.updatesite.UpdateSite.load(UpdateSite.java:147)
at org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSiteMetadataRepositoryFactory.initializeRepository(UpdateSiteMetadataRepositoryFactory.java:99)
at org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSiteMetadataRepositoryFactory.load(UpdateSiteMetadataRepositoryFactory.java:59)
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:48:15.004
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:48:36.100
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:48:41.904
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../device_support_radar.
Caused by: java.io.IOException: software-dl.ti.com/.../device_support_radar is not a valid repository location.
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:48:41.904
!MESSAGE Unable to read repository at software-dl.ti.com/.../device_support_radar.
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:49:11.294
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:49:32.550
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:49:32.550
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:49:53.608
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:50:15.940
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:50:15.940
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:50:22.810
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:50:22.810
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:51:13.590
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:51:13.591
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:51:57.088
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:51:57.089
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:52:18.122
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:52:23.176
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../gcc.
Caused by: java.io.IOException: software-dl.ti.com/.../gcc is not a valid repository location.
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:52:23.176
!MESSAGE Unable to read repository at software-dl.ti.com/.../gcc.
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:52:32.207
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at software-dl.ti.com/.../.
Caused by: java.io.IOException: software-dl.ti.com/.../ is not a valid repository location.
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:52:32.207
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:52:53.272
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:54:00.301
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:54:00.302
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:54:03.546
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:54:03.547
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:54:48.717
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:54:48.717
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:55:09.738
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:56:13.068
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:56:13.069
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:56:16.138
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:56:16.138
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:57:22.758
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:57:22.758
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 14:57:43.813
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:58:47.117
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-05-26 14:58:47.118
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:58:51.424
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:58:51.425
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-05-26 14:58:55.227
!STACK 1
... 26 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2021-05-26 14:58:55.227
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-05-26 15:00:41.753
!STACK 0
!ENTRY org.eclipse.cdt.core 1 0 2021-05-26 15:35:15.799
!MESSAGE Indexed 'OBC6600W_280049_Boot_Sci_20200402_V3' (23 sources, 163 headers) in 7.13 sec: 29,434 declarations; 29,349 references; 40 unresolved inclusions; 242 syntax errors; 311 unresolved names (0.53%)
!ENTRY org.eclipse.cdt.core 1 0 2021-05-26 18:50:04.870
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (34 sources, 168 headers) in 3.26 sec: 28,088 declarations; 33,213 references; 35 unresolved inclusions; 246 syntax errors; 464 unresolved names (0.75%)
!ENTRY org.eclipse.cdt.core 1 0 2021-05-26 18:51:02.815
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_TEST_V9104' (33 sources, 82 headers) in 0.9 sec: 15,571 declarations; 22,273 references; 40 unresolved inclusions; 241 syntax errors; 270 unresolved names (0.71%)
!ENTRY org.eclipse.cdt.core 1 0 2021-05-26 18:52:53.419
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_TEST_V9104' (33 sources, 88 headers) in 0.97 sec: 15,584 declarations; 22,540 references; 35 unresolved inclusions; 241 syntax errors; 267 unresolved names (0.7%)
!ENTRY org.eclipse.cdt.core 1 0 2021-05-27 10:29:47.518
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_V9102' (65 sources, 244 headers) in 2.11 sec: 31,133 declarations; 44,686 references; 35 unresolved inclusions; 482 syntax errors; 522 unresolved names (0.68%)
!ENTRY org.eclipse.cdt.core 1 0 2021-05-27 10:29:53.708
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_V9102' (33 sources, 88 headers) in 1.29 sec: 15,585 declarations; 22,519 references; 35 unresolved inclusions; 241 syntax errors; 267 unresolved names (0.7%)
!ENTRY org.eclipse.cdt.core 1 0 2021-05-27 10:35:44.322
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_V9104_TEST' (33 sources, 82 headers) in 1 sec: 15,571 declarations; 22,275 references; 40 unresolved inclusions; 241 syntax errors; 271 unresolved names (0.71%)
!SESSION 2021-06-04 15:17:00.142 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-06-04 15:17:08.567
!ENTRY com.ti.common.core 4 0 2021-06-04 15:17:08.689
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-04 15:17:45.811
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-04 15:17:46.059
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-04 15:17:46.060
!SESSION 2021-06-21 17:45:23.979 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-06-21 17:45:58.039
!ENTRY com.ti.common.core 4 0 2021-06-21 17:45:58.166
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-21 17:46:25.288
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-21 17:46:25.357
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-21 17:46:25.360
!ENTRY com.ti.ccstudio.app.center 4 0 2021-06-21 17:46:40.122
!MESSAGE Unable to read software-dl.ti.com/.../apps_8.1.0.json file.
!STACK 0
at sun.net.NetworkClient.doConnect(NetworkClient.java:178)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1474)
at java.net.URL.openStream(URL.java:1045)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.readFile(CCSAppCenter.java:196)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.getAppJson_0(CCSAppCenter.java:212)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.access$1(CCSAppCenter.java:211)
at com.ti.ccstudio.app.center.internal.CCSAppCenter$1.run(CCSAppCenter.java:183)
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:46:57.543
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:47:41.443
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:48:02.654
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:48:23.672
!STACK 0
!ENTRY org.eclipse.cdt.core 1 0 2021-06-21 17:48:42.927
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 88 headers) in 2.5 sec: 15,601 declarations; 22,597 references; 35 unresolved inclusions; 243 syntax errors; 240 unresolved names (0.62%)
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-06-21 17:48:44.100
!STACK 0
at com.ti.ccstudio.errorparser.parsers.CoffErrorParser.doProcessLine(CoffErrorParser.java:103)
at org.eclipse.cdt.core.errorparsers.ErrorParserNamedWrapper.processLine(ErrorParserNamedWrapper.java:48)
at com.ti.ccstudio.project.core.internal.build.ProjectAdviceManager$AdviceContentHandler.endElement(ProjectAdviceManager.java:129)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:609)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(XMLDocumentFragmentScannerImpl.java:1782)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2967)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:841)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:770)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:327)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:328)
at com.ti.ccstudio.project.core.internal.build.ProjectAdviceManager.processAdvice(ProjectAdviceManager.java:506)
at com.ti.ccstudio.project.core.internal.build.ProjectAdviceManager.handleAdviceChangingEvent(ProjectAdviceManager.java:467)
at com.ti.ccstudio.project.core.internal.build.ProjectAdviceManager.handleAdviceChangingEvent(ProjectAdviceManager.java:447)
at com.ti.ccstudio.project.core.internal.build.ProjectAdviceManager.onProjectImported(ProjectAdviceManager.java:423)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener$6.visit(ProjectStateMonitor.java:390)
at com.ti.common.project.core.internal.events.ProjectStateMonitor.notifyListeners(ProjectStateMonitor.java:859)
at com.ti.common.project.core.internal.events.ProjectStateMonitor.access$2(ProjectStateMonitor.java:848)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener.resourceChanged(ProjectStateMonitor.java:388)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:299)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:289)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:152)
at org.eclipse.core.internal.resources.Workspace.broadcastBuildEvent(Workspace.java:360)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:138)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:232)
!ENTRY org.eclipse.cdt.core 1 0 2021-06-21 17:48:46.446
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 89 headers) in 1.26 sec: 15,592 declarations; 22,549 references; 35 unresolved inclusions; 241 syntax errors; 273 unresolved names (0.71%)
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:49:13.458
!STACK 0
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2021-06-21 17:50:10.404
!MESSAGE No repository found at software-dl.ti.com/.../device_support_digital_power.
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:50:31.415
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:50:53.884
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:51:18.118
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:51:40.933
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:52:02.143
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:52:23.156
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:52:45.701
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:53:32.044
!STACK 0
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2021-06-21 17:54:21.423
!MESSAGE No repository found at software-dl.ti.com/.../device_support_keystone2.
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2021-06-21 17:54:49.774
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-06-21 17:56:03.655
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:56:03.656
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-06-21 17:56:48.515
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2021-06-21 17:56:48.516
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2021-06-21 17:56:53.967
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at software-dl.ti.com/.../device_support_keystone2.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:653)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2021-06-21 17:56:53.967
!ENTRY org.eclipse.ui 2 2 2021-06-22 18:51:32.505
!MESSAGE com.ti.ccstudio.system.setup.ui.views.TargetConfigurationView: Deprecated relationship "fast" should be converted to "stack".
!ENTRY org.eclipse.core.resources 4 2 2021-06-22 18:54:44.305
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
!STACK 0
java.lang.NullPointerException
at com.ti.ccstudio.system.setup.ui.editors.internal.MultiPageXMLEditor.resourceChanged(MultiPageXMLEditor.java:710)
at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:374)
at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1469)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:46)
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:26.432
!MESSAGE DS_ERROR: IcePick_C_0: Error connecting to the target: (Error -260 @ 0x0) An attempt to connect to the XDS110 failed. The cause may be one or more of: no XDS110 is connected, invalid firmware update, invalid XDS110 serial number, or faulty USB cable. The firmware and serial number may be updated using the xdsdfu utility found in the .../ccs_base/common/uscif/xds110 directory of your installation. View the ReadMe.txt file there for instructions. (Emulation package 8.0.27.9)
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:26.551
!MESSAGE DS_ERROR: Error connecting to the target:
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:29.119
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:29.172
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:33.679
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:33.731
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:39.238
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:39.252
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:42.719
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:04:42.775
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:06:05.365
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:06:05.385
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:06:37.095
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 19:06:37.140
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 20:07:44.863
!MESSAGE DS_ERROR: C28xx_CPU1: Error: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 8.0.27.9)
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 20:07:44.893
!MESSAGE DS_ERROR: C28xx_CPU1: Unable to determine target status after 20 attempts
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-22 20:07:44.904
!MESSAGE DS_ERROR: C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:32:21.150
!MESSAGE DS_ERROR: C28xx_CPU1: GEL: Target must be connected before calling the function
!ENTRY org.eclipse.cdt.dsf 4 10005 2021-06-23 09:32:21.157
!MESSAGE Request for monitor: 'RequestMonitor (org.eclipse.cdt.dsf.concurrent.RequestMonitor@160fb9c): Status ERROR: com.ti.ccstudio.debug code=20003 Target must be connected before calling the function null' resulted in an error.
!SUBENTRY 1 com.ti.ccstudio.debug 4 20003 2021-06-23 09:32:21.157
!MESSAGE Target must be connected before calling the function
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:40:24.763
!ENTRY org.eclipse.cdt.dsf 4 10005 2021-06-23 09:40:24.766
!MESSAGE Request for monitor: 'RequestMonitor (org.eclipse.cdt.dsf.concurrent.RequestMonitor@1ade893): Status ERROR: com.ti.ccstudio.debug code=20003 Target must be connected before calling the function null' resulted in an error.
!SUBENTRY 1 com.ti.ccstudio.debug 4 20003 2021-06-23 09:40:24.766
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:47:57.535
!MESSAGE DS_ERROR: IcePick_C_0: Error: (Error -261 @ 0xFFFFFEFB) Invalid response was received from the XDS110. (Emulation package 8.0.27.9)
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:47:57.839
!MESSAGE DS_ERROR: IcePick_C_0: Unable to determine target status after 20 attempts
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:47:57.853
!MESSAGE DS_ERROR: IcePick_C_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:47:58.005
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:47:58.009
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 09:47:58.010
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-23 15:29:43.900
!ENTRY org.eclipse.cdt.dsf 4 10005 2021-06-23 15:29:43.904
!MESSAGE Request for monitor: 'RequestMonitor (org.eclipse.cdt.dsf.concurrent.RequestMonitor@15d84f8): Status ERROR: com.ti.ccstudio.debug code=20003 Target must be connected before calling the function null' resulted in an error.
!SUBENTRY 1 com.ti.ccstudio.debug 4 20003 2021-06-23 15:29:43.904
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-25 16:03:11.990
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-25 16:03:12.242
(Error -260 @ 0x0)
for instructions.
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-25 16:03:18.205
!ENTRY com.ti.ccstudio.debug 1 0 2021-06-25 16:03:18.341
(Error -260 @ 0x0)
for instructions.
!SESSION 2021-06-28 12:04:35.847 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-06-28 12:25:27.364
!ENTRY com.ti.common.core 4 0 2021-06-28 12:25:27.493
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-28 12:25:40.945
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-28 12:25:40.957
!ENTRY org.eclipse.launchbar.core 2 0 2021-06-28 12:25:40.958
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-06-28 12:31:58.695
!STACK 0
!ENTRY org.eclipse.cdt.core 1 0 2021-07-02 11:53:29.456
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_Fabo' (33 sources, 82 headers) in 1.27 sec: 15,570 declarations; 21,392 references; 40 unresolved inclusions; 241 syntax errors; 271 unresolved names (0.73%)
!SESSION 2021-07-06 11:25:56.082 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-07-06 11:26:28.992
!ENTRY com.ti.common.core 4 0 2021-07-06 11:26:29.123
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-06 11:26:41.342
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-06 11:26:41.386
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-06 11:26:41.387
!ENTRY org.eclipse.cdt.core 1 0 2021-07-06 11:27:29.542
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 88 headers) in 2.29 sec: 15,599 declarations; 22,559 references; 35 unresolved inclusions; 243 syntax errors; 240 unresolved names (0.63%)
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-07-06 11:27:30.489
!STACK 0
!ENTRY org.eclipse.cdt.core 1 0 2021-07-06 11:27:31.671
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 89 headers) in 1 sec: 15,590 declarations; 22,508 references; 35 unresolved inclusions; 241 syntax errors; 275 unresolved names (0.72%)
!SESSION 2021-07-08 10:27:17.481 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2021-07-08 10:30:00.735
!ENTRY com.ti.common.core 4 0 2021-07-08 10:30:01.251
!ENTRY com.ti.common.core 4 0 2021-07-08 10:30:01.253
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-08 10:30:06.688
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-08 10:30:06.695
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-08 10:30:06.696
!ENTRY com.ti.ccstudio.debug.server 4 214294189 2021-07-08 10:30:16.075
!MESSAGE Unexpected CCS exit detected [21-7-6 上午11:26]!!!
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-07-08 10:33:04.341
!STACK 0
!SESSION 2021-07-12 11:58:58.585 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-07-12 12:24:06.995
!ENTRY com.ti.common.core 4 0 2021-07-12 12:24:07.148
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-12 12:24:19.929
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-12 12:24:19.971
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-12 12:24:19.972
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-07-12 12:28:11.156
!STACK 0
!ENTRY org.eclipse.cdt.core 1 0 2021-07-12 13:51:35.075
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_V9102New' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2021-07-12 13:55:19.778
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 82 headers) in 1.77 sec: 15,567 declarations; 22,160 references; 40 unresolved inclusions; 241 syntax errors; 270 unresolved names (0.71%)
!ENTRY org.eclipse.cdt.core 1 0 2021-07-12 13:55:27.409
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 89 headers) in 0.923 sec: 15,589 declarations; 22,438 references; 35 unresolved inclusions; 241 syntax errors; 275 unresolved names (0.72%)
!ENTRY org.eclipse.cdt.core 1 0 2021-07-12 13:57:50.613
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_DF_HV' (33 sources, 129 headers) in 1.43 sec: 28,075 declarations; 33,036 references; 40 unresolved inclusions; 242 syntax errors; 514 unresolved names (0.83%)
!SESSION 2021-07-17 12:21:54.661 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2021-07-17 12:22:31.824
!ENTRY com.ti.common.core 4 0 2021-07-17 12:22:32.353
!ENTRY com.ti.common.core 4 0 2021-07-17 12:22:32.355
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-17 12:22:37.711
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-17 12:22:37.721
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-17 12:22:37.723
!ENTRY com.ti.ccstudio.debug.server 4 214294189 2021-07-17 12:22:41.269
!MESSAGE Unexpected CCS exit detected [21-7-12 下午12:24]!!!
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-07-17 12:23:26.932
!STACK 0
!SESSION 2021-07-19 09:10:25.594 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-07-19 09:11:54.458
!ENTRY com.ti.common.core 4 0 2021-07-19 09:11:54.587
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-19 09:12:12.145
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-19 09:12:12.180
!ENTRY org.eclipse.launchbar.core 2 0 2021-07-19 09:12:12.181
!ENTRY com.ti.ccstudio.errorparser 4 0 2021-07-19 11:28:52.577
!STACK 0
at com.ti.ccstudio.project.core.internal.build.ProjectAdviceManager.onProjectBuild_Post(ProjectAdviceManager.java:440)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener$8.visit(ProjectStateMonitor.java:416)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener.resourceChanged(ProjectStateMonitor.java:414)
at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:496)
at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:406)
at com.ti.ccstudio.project.core.services.ProjectBuilder.internalBuildProjects(ProjectBuilder.java:279)
at com.ti.ccstudio.project.core.services.ProjectBuilder.buildProjects(ProjectBuilder.java:197)
at com.ti.ccstudio.project.ui.internal.actions.BuildActiveConfigMenuAction_hack$BuildAction_hack$2.run(BuildActiveConfigMenuAction_hack.java:83)
!ENTRY org.eclipse.cdt.core 1 0 2021-07-20 14:02:16.164
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL' (33 sources, 88 headers) in 2.68 sec: 15,601 declarations; 22,597 references; 35 unresolved inclusions; 243 syntax errors; 240 unresolved names (0.62%)
!ENTRY org.eclipse.cdt.core 1 0 2021-07-20 14:02:41.312
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_V9104' (33 sources, 82 headers) in 0.996 sec: 15,570 declarations; 22,267 references; 40 unresolved inclusions; 241 syntax errors; 270 unresolved names (0.71%)
!ENTRY org.eclipse.cdt.core 1 0 2021-07-20 14:02:45.095
!MESSAGE Indexed 'Obc6600KwApp_F280049_E300P_WL_V9104' (33 sources, 89 headers) in 1.02 sec: 15,592 declarations; 22,546 references; 35 unresolved inclusions; 241 syntax errors; 275 unresolved names (0.72%)
!ENTRY org.eclipse.ui 4 4 2021-07-22 14:24:17.866
!MESSAGE Unable to create part
!SUBENTRY 1 org.eclipse.core.filebuffers 4 0 2021-07-22 14:24:17.867
!MESSAGE Cannot determine URI for '/Obc6600KwApp_F280049_E300P_WL_V9104/source/ObcSciComm.c'.
!STACK 1
org.eclipse.core.runtime.CoreException: Cannot determine URI for '/Obc6600KwApp_F280049_E300P_WL_V9104/source/ObcSciComm.c'.
at org.eclipse.core.internal.filebuffers.ResourceFileBuffer.create(ResourceFileBuffer.java:236)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager.connect(TextFileBufferManager.java:112)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.createFileInfo(TextFileDocumentProvider.java:560)
at org.eclipse.cdt.internal.ui.editor.CDocumentProvider.createFileInfo(CDocumentProvider.java:791)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.connect(TextFileDocumentProvider.java:478)
at org.eclipse.cdt.internal.ui.editor.CDocumentProvider.connect(CDocumentProvider.java:723)
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4178)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:257)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1466)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:150)
at org.eclipse.cdt.internal.ui.editor.CEditor.internalDoSetInput(CEditor.java:1440)
at org.eclipse.cdt.internal.ui.editor.CEditor.doSetInput(CEditor.java:1405)
at org.eclipse.ui.texteditor.AbstractTextEditor$5.run(AbstractTextEditor.java:3154)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
at org.eclipse.ui.internal.WorkbenchWindow$14.run(WorkbenchWindow.java:2195)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2191)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3172)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3197)
at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:362)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:333)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:990)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:955)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:124)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:399)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:318)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:992)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:661)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:767)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:738)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:732)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:716)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:104)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:144)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4889)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:212)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:52)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:620)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:584)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:769)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1185)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3261)
at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3176)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3158)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3153)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3117)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3098)
at org.eclipse.ui.texteditor.GotoLastEditPositionAction.run(GotoLastEditPositionAction.java:85)
at org.eclipse.ui.texteditor.GotoLastEditPositionAction.run(GotoLastEditPositionAction.java:64)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:247)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:219)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$5(ActionContributionItem.java:436)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4428)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4238)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3817)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
!SUBENTRY 2 org.eclipse.core.filebuffers 4 0 2021-07-22 14:24:17.957
!ENTRY com.ti.ccstudio.ui 4 0 2021-07-22 14:24:18.005
!MESSAGE Exception during context menu override initialization for part ObcSciComm.c
!STACK 0
at com.ti.ccstudio.internal.ui.contribution.filters.PartContributionFilter.handlePartOpened(PartContributionFilter.java:147)
at com.ti.ccstudio.ui.internal.decorations.DecorationManager$PartListener.partOpened(DecorationManager.java:217)
at org.eclipse.ui.internal.PartService$10.run(PartService.java:191)
at org.eclipse.ui.internal.PartService.partOpened(PartService.java:188)
at org.eclipse.ui.internal.WorkbenchPage$23.run(WorkbenchPage.java:5106)
at org.eclipse.ui.internal.WorkbenchPage.firePartOpened(WorkbenchPage.java:5103)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.lambda$1(CompatibilityPart.java:119)
at org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl.setObject(PartImpl.java:422)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:130)
请您以插入-->文件的形式来上传log文件,以便于阅读
日志中的所有错误似乎都与 Internet 连接问题有关(尽管有关 wiki 站点的错误也有过时链接的问题)。您的 PC 是否具有 Internet 连接?
1、有,正常连接,网络正常;今天开机打开CCS又出现了现象,但log文件时间没有更新还是7.22;必须重新安装CCS才能用,不关CCS或电脑
2、有没可能其它软件或工具影响CCS,比如加密软件等
