Part Number: TMS320F28335
The XDS110 comes in a package consisting of:
- XDS110 debug pod
- 20-pin debug cable
- 14-pin auxiliary cable
- TI 20-pin to TI 14-pin converter adapter (使用的该转接头)
- TI 20-pin to ARM Cortex 20-pin converter adapter
- TI 20-pin to ARM Cortex 10-pin converter adapter
- USB cable
- Breakout board for auxiliary cable
- Quick start guide
使用软件版本:CCS6.1.3
测试链接报错内容如下:
[Start: Texas Instruments XDS110 USB Debug Probe_0]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\panxi\AppData\Local\Texas Instruments\
CCS\ti\0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'jioxds110.dll'.
An already open status was returned while soft opening the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-110' (0xffffff92).
The title is 'SC_ERR_OCS_ALREADY_OPEN'.
The explanation is:
This utility opened the controller but found it already in use.
You must exit other debuggers and utilities that access the
controller because this utility must be the only client.
[End: Texas Instruments XDS110 USB Debug Probe_0]
