TMS320F28377S: This project does not contain a buildable RTSC Configuration (.cfg) file.
Part Number: TMS320F28377S
新建工程的时候选择的是empty project,一直都可以使用,今天打开来编译了一回后就显示Buildfile generation error occurred..
This project does not contain a buildable RTSC Configuration (.cfg) file. In order for it to build, this project must contain one RTSC Configuration file that is not excluded from build.
再看project properties的output file被设置为了RTST Application,还没有办法修改,
