TMS320F280021: 2800X系列的ADC的PIE中断和ADCINT1、ADCINT2的问题
Part Number: TMS320F280021
Dear all:
在使用2800X系列的ADC中断时发现下列问题:
2800x系列有ADCINT1、ADCINT2、ADCINT3、ADCINT4 共4个中断,
使用ADCINT1中断时,做了以下3个测试
1、使用PIE中断向量表的ADCA1作为中断入口时,中断程序能正常运行,运行结果正确,LED_FLASH管脚翻转的时间是17.2us,翻转80次
PieVectTable.ADCA1_INT  = &adc_A1ISR;     // Function for ADCA interrupt 1
IER |= M_INT1;//T0 ADCINT1
PieCtrlRegs.PIEIER1.bit.INTx1 = 1;// ADCINT1
EPwm1Regs.ETSEL.bit.SOCAEN = 0;     // Disable SOC on A group
EPwm1Regs.ETSEL.bit.SOCASEL = 3;    // Select SOC on up-count
EPwm1Regs.ETPS.bit.SOCAPRD = 1;     // Generate pulse on 1st event
EPwm1Regs.CMPA.bit.CMPA = 430;   // Set compare A value to 2048 counts
EPwm1Regs.TBPRD = 862;           // Set period to 4096 counts
EPwm1Regs.TBCTL.bit.CTRMODE = 3;    // Freeze counter
AdcaRegs.ADCSOC0CTL.bit.CHSEL = 7;     // SOC0 will convert pin A1
                                           // 0:A0  1:A1  2:A2  3:A3
                                           // 4:A4   5:A5   6:A6   7:A7
                                           // 8:A8   9:A9   A:A10  B:A11
                                           // C:A12  D:A13  E:A14  F:A15
AdcaRegs.ADCSOC0CTL.bit.ACQPS = 9;     // Sample window is 10 SYSCLK cycles
AdcaRegs.ADCSOC0CTL.bit.TRIGSEL = 5;   // Trigger on ePWM1 SOCA
AdcaRegs.ADCINTSEL1N2.bit.INT1SEL = 0; // End of SOC1 will set INT1 flag
AdcaRegs.ADCINTSEL1N2.bit.INT1E = 1;   // Enable INT1 flag
AdcaRegs.ADCINTSEL1N2.bit.INT1CONT = 0;       //不连续
AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; // Make sure INT1 flag is cleared
定时器函数里25ms启动ePWM 转换
EPwm1Regs.ETSEL.bit.SOCAEN  = 1;        // Enable SOC on A group
EPwm1Regs.TBCTL.bit.CTRMODE = 0;   // Unfreeze, and enter up count mode
ADC1中断函数
__interrupt void adc_A1ISR(void)
    LED_FLASH=1;
    Current.Sum+=AdcaResultRegs.ADCRESULT1;
    if(++Current.ConversionCount==80)
        Current.ConversionCount=0;
        Current.Data=(Current.Sum/80);
        Current.Sum=0;
        EALLOW;
        EPwm1Regs.ETSEL.bit.SOCAEN  = 0;        // Enable SOC on A group
        EPwm1Regs.TBCTL.bit.CTRMODE = 3;   // Unfreeze, and enter up count mode
        EDIS;
    // Clear the interrupt flag
    // Check if overflow has occurred
    if(1 == AdcaRegs.ADCINTOVF.bit.ADCINT1)
        AdcaRegs.ADCINTOVFCLR.bit.ADCINT1 = 1; //clear INT1 overflow flag
        AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //clear INT1 flag
    // Acknowledge the interrupt
    PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
2、使用PIE中断向量表的ADCC1作为中断入口时,中断程序不能运行,进不了中断
PieVectTable.ADCC1_INT  = &adc_C1ISR;     // Function for ADCC interrupt 1
PieCtrlRegs.PIEIER1.bit.INTx3 = 1;// ADCINT1
定时器函数里25ms启动ePWM 转换
ADC1中断函数
__interrupt void adc_C1ISR(void)
    LED_FLASH=1;
        Current.Sum=0;
        EALLOW;
        EDIS;
3、使用PIE中断向量表的ADCA2作为中断入口时,中断程序不能运行,进不了中断
PieVectTable.ADCA2_INT  = &adc_A2ISR;     // Function for ADCA interrupt 1
IER |= M_INT10; //ADCINT1
PieCtrlRegs.PIEIER10.bit.INTx2 = 1;// ADCINT1
定时器函数里25ms启动ePWM 转换
ADC1中断函数
__interrupt void adc_A2ISR(void)
    LED_FLASH=1;
        Current.Sum=0;
        EALLOW;
        EDIS;
使用ADCINT2中断时,做了以下2个测试
4、使用PIE中断向量表的ADCA1作为中断入口时,中断程序不能运行,进不了中断
AdcaRegs.ADCINTSEL1N2.bit.INT2SEL = 0; // End of SOC1 will set INT2 flag
AdcaRegs.ADCINTSEL1N2.bit.INT2E = 1;   // Enable INT1 flag
AdcaRegs.ADCINTSEL1N2.bit.INT2CONT = 0;       //不连续
AdcaRegs.ADCINTFLGCLR.bit.ADC2NT1 = 1; // Make sure INT2 flag is cleared
定时器函数里25ms启动ePWM 转换
ADC1中断函数
    LED_FLASH=1;
        Current.Sum=0;
        EALLOW;
        EDIS;
    AdcaRegs.ADCINTFLGCLR.bit.ADCINT2 = 1;
    if(1 == AdcaRegs.ADCINTOVF.bit.ADCINT2)
        AdcaRegs.ADCINTOVFCLR.bit.ADCINT2 = 1; //clear INT2 overflow flag
        AdcaRegs.ADCINTFLGCLR.bit.ADCINT2 = 1; //clear INT2 flag
5、使用PIE中断向量表的ADCA2作为中断入口时,中断程序可以运行,但是运行结果不正常,LED_FLASH管脚翻转的时间是20ms(我设定的是17.2us)
AdcaRegs.ADCINTSEL1N2.bit.INT2E = 1;   // Enable INT2 flag
AdcaRegs.ADCINTFLGCLR.bit.ADCINT2 = 1; // Make sure INT1 flag is cleared
定时器函数里25ms启动ePWM 转换
ADC1中断函数
    LED_FLASH=1;
        Current.Sum=0;
        EALLOW;
        EDIS;
        AdcaRegs.ADCINTOVFCLR.bit.ADCINT2 = 1; //clear INT1 overflow flag
        AdcaRegs.ADCINTFLGCLR.bit.ADCINT2 = 1; //clear INT1 flag
我的问题:
1、如何配置在ADCINT1中断1时,使用PIE中断向量表的ADCA2中断入口,中断程序正常运行。
2、如何配置在ADCINT2中断2时,使用PIE中断向量表的ADCA1中断入口,中断程序正常运行。
3、如何配置在ADCINT2中断2时,使用PIE中断向量表的ADCA2中断入口,中断程序正常运行,目前能进行中断,运行不正常。
  • 您好,我们已收到您的问题并升级到英文论坛寻求帮助,如有答复将尽快回复您。谢谢!
  • 您好,在您进行的测试2中,虽然 ADCC1 是中断配置,但并未配置ADCC,因此不会生成 ADCC1 中断。
    测试3中,没有设置ADCINT2 的 EOC 触发器:
    AdcaRegs.ADCINTSEL1N2.bit.INT1CONT = 0; //discontinous
  • 我总共做了5个分类测试,测试3我本身就是使用ADCINT1中断,只是把中断PIE配置为ADCA2向量也就是INT10.2 ,所以配置的是ADCINT1的EOC触发,
    我也英文论坛也可以到了类似的问题,分了两组ADC-A和ADC-C ,
    ADC-A组
    ADCINT1对应的PIE中断是ADCA1 ,ADCINT2对应的PIE中断是ADCA2,ADCINT3对应的PIE中断是ADCA3,ADCINT4对应的PIE中断是ADCA4
    ADC-C组
    ADCINT1对应的PIE中断是ADCC1 ,ADCINT2对应的PIE中断是ADCC2,ADCINT3对应的PIE中断是ADCC3,ADCINT4对应的PIE中断是ADCC4
    现在我使用的是ADC-A组,使用ADCINT2对应的PIE中断是ADCA2的配置,使用epwm触发ADC中断,我把我这个程序再上传,但是中断转换的时间是20ms,
    不管是怎么配置epwm触发的周期。
    PieVectTable.ADCA2_INT  = &adc_A2ISR;     // Function for ADCA interrupt 2
    IER |= M_INT10; //ADCINT2
    PieCtrlRegs.PIEIER10.bit.INTx2 = 1;// ADCINT2
    AdcaRegs.ADCINTSEL1N2.bit.INT2SEL = 0; // End of SOC0 will set INT2 flag
    定时器函数里25ms启动ePWM 转换
    ADC1中断函数
        LED_FLASH=1;
            Current.Sum=0;
            EALLOW;
            EDIS;
    帮忙分析使用ADCINT2对应的PIE中断是ADCA2,中断转换时间异常一直20ms这个问题。
  • 我重新又测试了一把,使用ADCINT3对应的PIE中断是ADCA3,ADCINT4对应的PIE中断是ADCA4测试,结果和ADCINT2对应的PIE中断是ADCA2,中断转换时间异常一直20ms,但是使用使用ADCINT1对应的PIE中断是ADCA1就是正常的,
    是不epwm触发这块要特别配置?
  • 好的感谢您提供的信息,因负责该问题的专家休假,预计给到您答复会在下周工作日之内,给您带来的不便敬请谅解!
  • 犯了一个不该错误导致,中断清零出错了,使用了IER |= M_INT10; //ADCINT2
    清零要使用PieCtrlRegs.PIEACK.bit.ACK10=1;
  • 感谢你们的帮助
