在例程的基础上,我改了C28X1的程序,接收也采用中断的形式。代码如下:
// Included Files
#include "driverlib.h"
#include "device.h"
// Defines
#define IPC_CMD_READ_MEM 0x1001
#define IPC_CMD_RESP 0x2001
#define TEST_PASS 0x5555
#define TEST_FAIL 0xAAAA
#pragma DATA_SECTION(readData, "MSGRAM_CPU_TO_CM")
uint32_t readData[10];
uint32_t pass;
// Main
void main(void)
int i;
IPC_MessageQueue_t messageQueue;
IPC_Message_t TxMsg, RxMsg;
// Initialize device clock and peripherals
Device_init();
// Boot CM core
#ifdef _FLASH
Device_bootCM(BOOTMODE_BOOT_TO_FLASH_SECTOR0);
#else
Device_bootCM(BOOTMODE_BOOT_TO_S0RAM);
#endif
// Initialize PIE and clear PIE registers. Disables CPU interrupts.
Interrupt_initModule();
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
Interrupt_initVectorTable();
// Clear any IPC flags if set already
IPC_clearFlagLtoR(IPC_CPU1_L_CM_R, IPC_FLAG_ALL);
// Initialize message queue
IPC_initMessageQueue(IPC_CPU1_L_CM_R, &messageQueue, IPC_INT1, IPC_INT1);
// Synchronize both the cores
IPC_sync(IPC_CPU1_L_CM_R, IPC_FLAG31);
// Enable Global Interrupt (INTM) and realtime interrupt (DBGM)
EINT;
ERTM;
// Fill in the data to be sent
for(i=0; i<10; i++)
readData[i] = i;
// Update the message
TxMsg.command = IPC_CMD_READ_MEM;
TxMsg.address = (uint32_t)readData;
TxMsg.dataw1 = 10; // Using dataw1 as data length
TxMsg.dataw2 = 1; // Message identifier
// Send message to the queue
// Since C28x and CM does not share the same address space for shared RAM,
// ADDRESS_CORRECTION is enabled
IPC_sendMessageToQueue(IPC_CPU1_L_CM_R, &messageQueue, IPC_ADDR_CORRECTION_ENABLE,
&TxMsg, IPC_BLOCKING_CALL);
// Read message from the queue
// Return message from CM does not use the address field, hence
// ADDRESS_COREECTION feature is not used
IPC_readMessageFromQueue(IPC_CPU1_L_CM_R, &messageQueue, IPC_ADDR_CORRECTION_DISABLE,
&RxMsg, IPC_BLOCKING_CALL);
if((RxMsg.command == IPC_CMD_RESP) && (RxMsg.dataw1 == TEST_PASS) && (RxMsg.dataw2 == 1))
pass = 1;
else
pass = 0;
// End of example. Loop forever
while(1);
// End of File
但是,CPU1不能进入接收中断,CM4则运行正常。请问这是什么原因呢?
在另外一个例程中,CPU1与CPU2 IPC通讯,我改了CPU1的代码则可以正常进入接收中断,代码如下:
// Included Files
#include "device.h"
// Defines
#pragma DATA_SECTION(readData, "MSGRAM_CPU1_TO_CPU2")
uint32_t pass;
// IPC ISR for Flag 1
// C28x core sends data with message queue using Flag 0
__interrupt void IPC_ISR1()
int i;
// IPC_Message_t TxMsg, RxMsg;
bool status = false;
// Read the message from the message queue
IPC_readMessageFromQueue(IPC_CPU1_L_CPU2_R, &messageQueue, IPC_ADDR_CORRECTION_ENABLE,
&RxMsg, IPC_NONBLOCKING_CALL);
if(RxMsg.command == IPC_CMD_READ_MEM)
status = true;
// Read and compare data
for(i=0; i<RxMsg.dataw1; i++)
if((*(uint32_t *)RxMsg.address + i) != i)
status = false;
// Acknowledge the flag
IPC_ackFlagRtoL(IPC_CPU1_L_CPU2_R, IPC_FLAG1);
// Acknowledge the PIE interrupt.
Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP1);
// Main
void main(void)
int i;
Device_init();
// Boot CPU2 core
#ifdef _FLASH
Device_bootCPU2(BOOTMODE_BOOT_TO_FLASH_SECTOR0);
#else
Device_bootCPU2(BOOTMODE_BOOT_TO_M0RAM);
#endif
// // Clear any IPC flags if set already
// IPC_clearFlagLtoR(IPC_CPU1_L_CPU2_R, IPC_FLAG_ALL);
// // Initialize message queue
// IPC_initMessageQueue(IPC_CPU1_L_CPU2_R, &messageQueue, IPC_INT1, IPC_INT1);
// Enable IPC interrupts
IPC_registerInterrupt(IPC_CPU1_L_CPU2_R, IPC_INT1, IPC_ISR1);
EINT;
ERTM;
IPC_sync(IPC_CPU1_L_CPU2_R, IPC_FLAG31);
for(i=0; i<10; i++)
readData[i] = i;
// IPC_sendMessageToQueue(IPC_CPU1_L_CPU2_R, &messageQueue, IPC_ADDR_CORRECTION_ENABLE,
// &TxMsg, IPC_BLOCKING_CALL);
// IPC_readMessageFromQueue(IPC_CPU1_L_CPU2_R, &messageQueue, IPC_ADDR_CORRECTION_DISABLE,
// &RxMsg, IPC_BLOCKING_CALL);
// if((RxMsg.command == IPC_CMD_RESP) && (RxMsg.dataw1 == TEST_PASS) && (RxMsg.dataw2 == 1))
// pass = 1;
// else
// pass = 0;
while(1)
DEVICE_DELAY_US(100000);
&TxMsg, IPC_NONBLOCKING_CALL);
// End of File
