Part Number: TMS320F28034
请问,当作为主机时,请求从机数据的指令值什么或者设置是什么?
是LINID。我们在上面提供给您的LIN例程中,演示了如何写入LINID寄存器,以及如何配置RXIDMASK/TXIDMASK:
// LIN MASK Configuration 2
LinaRegs.LINMASK.bit.RXIDMASK = RXID_MASK; // 0xA
LinaRegs.LINMASK.bit.TXIDMASK = TXID_MASK; // 0xA
// Initialize the Slave LINIDNUM register
LinaRegs.LINID.bit.IDSLAVETASKBYTE = LINIDNUM_Slave; // 0x30
// Release SCI from software reset state - End of Config
LinaRegs.SCIGCR1.bit.SWnRST = 1;
// LIN Response Length
LinaRegs.SCIFORMAT.bit.LENGTH = RESP_LENGTH;
for(i=0;i<8;i++)
// Transmit Data - This populates the LIN transmit
// buffers - no data is actually sent yet.
LinaRegs.LINTD0.all = *Tx_DataPtr++;
LinaRegs.LINTD1.all = *Tx_DataPtr++;
// Send ID by writing to LINIDNUM register
// This causes the ID to be written to the bus. In turn,
// this causes both TX and RX ID matches in the slave task
// to occur - causing the data in the transmit buffers to
// be placed on the bus and also read into the receive buffers
LinaRegs.LINID.bit.IDBYTE = LIN_ID; // 0x3A
