BOOSTXL-3PHGANINV: BOOSTXL-3PHGANINV
Part Number: BOOSTXL-3PHGANINV
Other Parts Discussed in Thread: LAUNCHXL-F28379D,
Hello ,
I have a LAUNCHXL-F28379D connected to BOOSTXL-3PhGaNInv and the program is only set to PWM output. Using an oscilloscope to measure the corresponding PWM pins, the output waveform is normal, but there is no voltage output from the inverter, what is the reason for this?
