目前使用28335在做平均电流控制,如果我希望adc采样的位置在pwm的中间位置请问我该怎么设定
以下是我目前的代码
int main(void) { InitSysCtrl(); InitEPwm1Gpio(); InitEPwm2Gpio(); Gpio_Setup(); InitEPwm1Example(); DINT; InitPieCtrl(); IER = 0x0000; IFR = 0x0000; InitPieVectTable(); adc_init(); AdcRegs.ADCTRL2.bit.SOC_SEQ1=1; EALLOW; SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0; EDIS; EALLOW;// This is needed to write to EALLOW protected registers PieVectTable.EPWM1_INT = &epwm1_isr; EDIS; EALLOW; SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1; EDIS; IER |= M_INT3; // Enable EPWM INTn in the PIE: Group 3 interrupt 1-3 PieCtrlRegs.PIEIER3.bit.INTx1 = 1; // Enable global Interrupts and higher priority real-time debug events: EINT; // Enable Global interrupt INTM ERTM; // Enable Global realtime interrupt DBGM //for(;;){ // __asm(" NOP"); while(1) { } } void adc_init(void) { EALLOW; #if (CPU_FRQ_150MHZ) #define ADC_MODCLK 0x3; #endif #if (CPU_FRQ_100MHZ) #define ADC_MODCLK 0x2; #endif EDIS; // Initialize ADC InitAdc(); EALLOW; SysCtrlRegs.HISPCP.all = ADC_MODCLK; //HSPCLK = SYSCLKOUT/2*HISPCP = 150/(2*3) = 25.0 MHz EDIS; AdcRegs.ADCTRL3.bit.SMODE_SEL = 1; AdcRegs.ADCTRL1.bit.ACQ_PS = 0xf; AdcRegs.ADCTRL3.bit.ADCCLKPS = 0x1; // Core clock driver Fclk = HSPCLK/(2*ADCCLKPS),但?ADCCLKPS=0?,Fclk = HSPCLK AdcRegs.ADCTRL1.bit.CPS = 0x0; //ADCCLK = Fclk / (CPS+1) AdcRegs.ADCMAXCONV.bit.MAX_CONV1 = 15; // Set up ADC to perform (value+1) conversions for every SOC AdcRegs.ADCTRL1.bit.SEQ_CASC = 1; // 0: Dual-sequencer mode, 1: Cascaded mode AdcRegs.ADCTRL1.bit.CONT_RUN = 1; AdcRegs.ADCTRL2.bit.EPWM_SOCA_SEQ1 = 1; AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1 = 1; AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x0; // ADCINA0 to ADCRESULT0 AdcRegs.ADCCHSELSEQ1.bit.CONV01 = 0x1; // ADCINA1 to ADCRESULT2 } void read_adcresults(void) { AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1; // Immediately reset sequencer to state CONV00 AdcRegs.ADCTRL2.bit.SOC_SEQ1 = 1; // Software trigger while(AdcRegs.ADCST.bit.INT_SEQ1 == 0); // Interrupt request by INT_SEQ1 is enabled AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1; // Clear the SEQ1 interrupt flag bit p0= (AdcRegs.ADCRESULT0 >> 4); //A0 // Convert 16 bits registers to 12 bits ADC results by right-shift 4 bits p1= (AdcRegs.ADCRESULT1 >> 4); //B0 } void InitEPwm1Example(void){ // Setup TBCLK EPwm1Regs.TBPRD = 1500; // 100KHz EPwm1Regs.TBPHS.half.TBPHS =0; // Phase is 0 EPwm1Regs.TBCTR = 0; // ?基??器清零 EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up EPwm1Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading EPwm1Regs.TBCTL.bit.HSPCLKDIV = 0; // Clock ratio to SYSCLKOUT 除1 EPwm1Regs.TBCTL.bit.CLKDIV = 0; //1 EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO; // Setup shadowing EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // Load on Zero EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // Set Dead-band EPwm1Regs.DBCTL.bit.OUT_MODE = 0x0; // Enable Dead-band module EPwm1Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; // Active high // EPwm1Regs.DBFED = 30; // EPwm1Regs.DBRED = 30; // Set actions EPwm1Regs.AQCTLA.bit.ZRO = AQ_SET; // set actions for EPWM1A EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR; EPwm1Regs.AQCTLB.bit.ZRO = AQ_SET ; EPwm1Regs.AQCTLB.bit.CBU = AQ_CLEAR; // Interrupt where we will change the Compare Values EPwm1Regs.ETSEL.bit.SOCAEN = 1; // Enable SOC on A group EPwm1Regs.ETSEL.bit.SOCASEL = 0x6; // CTRU = CMPB EPwm1Regs.ETPS.bit.SOCAPRD = 0x1; //EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Zero event EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_PRD; // Select INT on PRD event EPwm1Regs.ETSEL.bit.INTEN = 1; // Enable INT EPwm1Regs.ETPS.bit.INTPRD = ET_1ST; // Generate INT on 1ST event } interrupt void epwm1_isr(void) { read_adcresults(); EPwm1Regs.CMPB=750; }
我在epwm1_isr中读取adc的数值,这样感觉是在开关导通就采样而不是在中点采样
