ccs3.3环境下进行28027编程求解
Other Parts Discussed in Thread: CCSTUDIO
实验室的仿真器只支持ccs3.3的版本啊,但是现在control suite里面的例程都是ccs4以上版本的,3.3的打不开啊!
求问一下怎么把4以上的例程移植到3.3里面啊?或者是有没有人能提供3.3版本的例程啊?
我试着将高版本里面的例程文件全都include进3.3的project里面,最后在build的时候出现了以下的问题,球高人解决!
------------------------- srtp_pwm_test1.pjt - Debug -------------------------
[Linking...] "C:\CCStudio_v3.3\C2000\cgtools\bin\cl2000" -@"Debug.lkf"
<Linking>
error: symbol "_USER10_ISR" redefined: first defined in
"E:\\ccsv3.3\\srtpproject\\srtp_pwm_test1\\Debug\\F2802x_DefaultIsr.obj";
redefined in
"E:\\ccsv3.3\\srtpproject\\srtp_pwm_test1\\Debug\\F2802x_SWPrioritizedDefaul
tIsr.obj"
error: symbol "_USER5_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_INT14_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_USER4_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_ADCINT4_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_XINT1_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_USER12_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_USER7_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_EMUINT_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_ADCINT5_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_rsvd_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_USER6_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_ILLEGAL_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_ADCINT6_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_SPITXINTA_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_SPIRXINTA_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_XINT3_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_SCITXINTA_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_SCIRXINTA_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_USER1_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_ADCINT7_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_XINT2_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_USER3_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_ADCINT1_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_EPWM4_INT_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_USER2_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_ADCINT2_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_INT13_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_ECAP1_INT_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_ADCINT3_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_EPWM3_TZINT_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_NMI_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_EPWM3_INT_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_WAKEINT_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_EPWM2_INT_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_RTOSINT_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_ADCINT8_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_I2CINT1A_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_TINT0_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_ADCINT9_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_EPWM1_INT_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_EPWM2_TZINT_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_I2CINT2A_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_DATALOG_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_USER9_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_EPWM1_TZINT_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_USER8_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_EPWM4_TZINT_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_PIE_RESERVED" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_USER11_ISR" redefined: first defined in
redefined in
tIsr.obj"
error: symbol "_PieVectTableInit" redefined: first defined in
"E:\\ccsv3.3\\srtpproject\\srtp_pwm_test1\\Debug\\F2802x_PieVect.obj";
redefined in
"E:\\ccsv3.3\\srtpproject\\srtp_pwm_test1\\Debug\\F2802x_SWPrioritizedPieVec
t.obj"
error: symbol "_InitPieVectTable" redefined: first defined in
redefined in
t.obj"
warning: creating output section "csm_rsvd" without a SECTIONS specification
warning: creating output section "csmpasswds" without a SECTIONS specification
"E:\\ccsv3.3\\srtpproject\\srtp_pwm_test1\\f2802x_common\\cmd\\28027_RAM_lnk.cmd", line 114: error:
placement fails for object ".text", size 0x25f4 (page 0). Available ranges:
PRAML0 size: 0x900 unused: 0x900 max hole: 0x900
error: errors encountered during linking; "./Debug/srtp_pwm_test1.out" not
built
>> Compilation failure
Build Complete,
2 Errors, 2 Warnings, 0 Remarks.
  • 把debug下面的.obj都删掉,另外,编译后的代码放不下
  • error: symbol "_ECAN1INTA_ISR" redefined: first defined in
    "V:\\chengxusheji\\DSPTMS320F28335zhiliuDCchengxu\\DCMOTOR\\Debug\\DSP2833x_
    DefaultIsr.obj"; redefined in
    SWPrioritizedDefaultIsr.obj"
    error: symbol "_ECAP4_INT_ISR" redefined: first defined in
    error: symbol "_ECAN1INTB_ISR" redefined: first defined in
    error: symbol "_SCITXINTB_ISR" redefined: first defined in
    error: symbol "_SCIRXINTB_ISR" redefined: first defined in
    error: symbol "_EPWM6_INT_ISR" redefined: first defined in
    error: symbol "_ECAN0INTA_ISR" redefined: first defined in
    error: symbol "_ECAP3_INT_ISR" redefined: first defined in
    error: symbol "_ECAN0INTB_ISR" redefined: first defined in
    error: symbol "_EPWM5_INT_ISR" redefined: first defined in
    error: symbol "_ECAP2_INT_ISR" redefined: first defined in
    error: symbol "_EPWM6_TZINT_ISR" redefined: first defined in
    error: symbol "_ADCINT_ISR" redefined: first defined in
    error: symbol "_SEQ2INT_ISR" redefined: first defined in
    error: symbol "_EPWM5_TZINT_ISR" redefined: first defined in
    error: symbol "_EQEP2_INT_ISR" redefined: first defined in
    error: symbol "_SEQ1INT_ISR" redefined: first defined in
    error: symbol "_EQEP1_INT_ISR" redefined: first defined in
    error: symbol "_EMPTY_ISR" redefined: first defined in
    PieVect.obj"; redefined in
    SWPrioritizedPieVect.obj"
    "./Debug/Example_2833xEPwmUpDownAQ.out" not built
    >> Compilation failure
    Build Complete,
    1 Errors, 0 Warnings, 0 Remarks.
    DSP28335编译出现这个问题,求大神解决啊先行谢谢
  • 建议你先从最简单的工程开始
    源文件  头文件   cmd等都考到3.3的工程目录下
