TMS320F28335: 新安装的CCS 10.4版本,编译C2000的代码,报奇怪的错误信息
Part Number: TMS320F28335
Other Parts Discussed in Thread: DRV8301
台式机,win10系统,MCU是TMS320F28335,代码里有TI官方给出的一些必要的汇编代码,编译时候这些汇编代码报不能识别的特殊字符的错误信
这是报错的一种情况,比较奇怪,怎么会报这种错误。同样的代码,在我的笔记本上就好好的,也是10.4版本的CCS
  • Hi,
    你双击错误描述的话会跳转到哪里?
    能否将控制台的完整信息上传上来?
  • 双击错误就是跳到了对应的错误位置
  • **** Build of configuration Debug for project DRV8301_ACIM_FOC ****
    "D:\\ti\\ccs1040\\ccs\\utils\\bin\\gmake" -k all
    Building file: "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm"
    Invoking: C2000 Compiler
    "D:/ti/ccs1040/ccs/tools/compiler/ti-cgt-c2000_20.2.5.LTS/bin/cl2000" -v28 -ml -mt --float_support=fpu32 --include_path="D:/ti/ccs1040/ccs/tools/compiler/ti-cgt-c2000_20.2.5.LTS/include" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/INCLUDE" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/DRV8301" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/System_Config" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/Data_Convert" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/Data_Communication" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/Motor_Parameter" -g --diag_warning=225 --diag_wrap=off --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.d_raw" --obj_directory="F2833x_RAM_RunCode" "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm"
    37 Assembly Errors, No Assembly Warnings
    >> Compilation failure
    F2833x_RAM_RunCode/subdir_rules.mk:9: recipe for target 'F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.obj' failed
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 1: [E0000] Unrecognized special character
    坿B
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 2: [E0000] Unrecognized special character
    鹙?功鮌?T? U叶4踮M厬|N?1魖a?/?Y?;餸?匆?醥泟石Da%*?骽蒃揣z镮??5⒒韣A\踥遊驑蠂伬?&歰?:|t逍r敔\<e騤0蒮輡勭},,(<赢?%H4]浛孰*dF跊?胱?+跠瘶u呄 \遢屼奔櫑鋡8麞(茒鉯鯆楙?
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 3: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    -[材Z摗a嘖@鴌脠QXDF悧? ;?"?4w鳧瑁7耯肱V罤8党3百峠i襾╊?5Je?f潣Y媚^艠?8n3?<偂涵#{? ??GA/?
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 3: [E0002] Invalid mnemonic specification
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 3: [E0000] Unrecognized special character
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 4: [E0000] Unrecognized special character
    e?'??旗WI/%蓧J_b01q痮??倏旻rg圭欌w_Q &G3;旗隀岛言
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 5: [E0000] Unrecognized special character
    ?,\u?嵕寝|!臈割?"}甐%贋i哉`臉?&,??2珠嬪9)??8GA/?R堮4摇?;yh癱? 燣T麚&毛鞑~b妱?(畒卒 !?9Qo覩.鲊ㄓ?*d偵~oIcQRJ孔?噙h0=鰀?<
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 6: [E0000] Unrecognized special character
    l??N,腷﨩旵?JJ'd該 K}9,q╡F?)悓?
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 7: [E0000] Unrecognized special character
    jq姐_迠_&{@3&@嚕飿瘵绹?.冉'硾燥?&|槏&q?'?鶿?!秣W^员?讂赂q?4DD鳠?=歜泮縋6??E癫qeK媺V? ?%2鈞臡泸Y韂d??
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 8: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    +炌?8?)绹??G,i}稥M?8?颏8笿}簆趑宭?ビ墑^菚耭躡?Ul檐q簤D
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 8: [E0002] Invalid mnemonic specification
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 8: [E0000] Unrecognized special character
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 9: [E0000] Unrecognized special character
    悜柃??
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 10: [E0000] Missing right quote of string constant
    'G翆g糑\?-毱[繘~翡IE崒? v?*詑v絉蚣c?&傦D
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 10: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 10: [E0002] Invalid mnemonic specification
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 11: [E0000] Unrecognized special character
    ?7G嗉~樗百?3缴汜? J{鉥]#污S烧d膲耫[2?<暒昏$9}?聕K@j?SR嵖-嵢m歟53皒?1隟? 肭&洛Wy召?6?:>斮<&?)A0僐%箑顔x
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 12: [E0000] Unrecognized special character
    _n~?#臞Eo?? ==謦\咛^G]%(yk啝而喿W穌咜m筚儵?g&钉/}?$Q蔆鵕?"牻掄儧)曑?5ⅵw~-%?"違耢郟朖睸SHQ薏5獔e~媹jI沄齲q???)嚠V?%?=綜G鐡镾?4褲蛇2rl_Z饄躂范i鷀<?嫴鮮M\踥遊驑蠂伬?&歰?:|t逍r敔\<e騤0蒮輡勭}<嵘 刷簗@"[;偧蓪sh;tV佺醫吙郣?耩-螊i釚眨挍苟醨蹏-脌兺?殯潛J怚d笀??.?^?7?蘘[Q豳顑
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 13: [E0000] Unrecognized special character
    卧蝑1妌璠襮脫?a<鏺A腓饯謵辷u梿n宮_5?+邨S圅E毺?&+z傞[z絧紎\4廮X晾<=陕p?0[M?,騮錦?
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 14: [E0000] Unrecognized special character
    Y?栽鹂x6摍?1?A爪uf?1b耞J"鰫悻? m
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 15: [E0000] Unrecognized special character
    wU備?;?
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 16: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    =R鹞P罽糮?/8T?=娙螇簟霓?Y??l禦伏c蘦骑
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 16: [E0002] Invalid mnemonic specification
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 16: [E0000] Unrecognized special character
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 17: [E0000] Unrecognized special character
    Y蝒 填}馕穻質!膯蒻D5?>摎E蕘h靥?(n6縹劏v@)梋東\C鉎YQ戞
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 18: [E0000] Unrecognized special character
    Y?
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 19: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    1uuq? 艻Fl慄?
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 19: [E0300] Symbol Y has already been defined
    1uuq? 艻Fl慄?
    1uuq? 艻Fl慄?
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 19: [E0002] Invalid mnemonic specification
    1uuq? 艻Fl慄?
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 19: [E0000] Unrecognized special character
    1uuq? 艻Fl慄?
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 20: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    %Z鞀翠櫹8%2jI\*:[焰韴鹂厗?.窄+②灵7v槏,~?<>獲?裩黻 戙??*栺>?!萧2D胱?!歳鲨?b獆?D_鳏
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 20: [E0002] Invalid mnemonic specification
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 20: [E0000] Unrecognized special character
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 21: [E0000] Unrecognized special character
    qej斗/V襜?73??Y誻!?7y鐡猚?/谠煞%0ggQ?
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 22: [E0000] Unrecognized special character
    \縦? 琮??铞絇h_豣?_篙岙菎?%?(陖6$=規u"K跠叙=?嶩鬡q"??>占^<E%湤讙mv%jH燍?D矎譩?骁:贉~ 鰜麓厡鰁虗:詶斱?崒妱]嘵s療???
    "../F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.asm", ERROR! at line 23: [E0000] Unrecognized special character
    T辳纹[瓪ㄌ賸嗣賡&漼漧8?厚~製垓D觴场!睈鈻?.<娤耋?p\(鯧@w??殰<嬔泈Fsg?!唆獍Fw4夽媋A?
    Errors in Source - Assembler Aborted
    gmake: *** [F2833x_RAM_RunCode/DSP2833x_CodeStartBranch.obj] Error 1
    Building file: "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm"
    "D:/ti/ccs1040/ccs/tools/compiler/ti-cgt-c2000_20.2.5.LTS/bin/cl2000" -v28 -ml -mt --float_support=fpu32 --include_path="D:/ti/ccs1040/ccs/tools/compiler/ti-cgt-c2000_20.2.5.LTS/include" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/INCLUDE" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/DRV8301" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/System_Config" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/Data_Convert" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/Data_Communication" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/Motor_Parameter" -g --diag_warning=225 --diag_wrap=off --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.d_raw" --obj_directory="F2833x_RAM_RunCode" "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm"
    21 Assembly Errors, No Assembly Warnings
    >> Compilation failure
    F2833x_RAM_RunCode/subdir_rules.mk:9: recipe for target 'F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.obj' failed
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 1: [E0000] Unrecognized special character
    坿?
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 2: [E0000] Unrecognized special character
    栃@燈踣`觥?)o絎Ro??鰱/滼嚹BL;悪凥L琹*$塘|cw?E辔n@r_h铱鱞廧mX賀P?_?Ccu嬝瞝?2蚦? j`釧??!qsBS?z呗铒粊{譧W辰業?2p+B鷐彦t▂Q櫿T芮?7_&??.?4?)酏?>?>蠡鮴倒蘠氍
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 3: [E0000] Unrecognized special character
    F?%/豹?貢A[噓?eデー慻?cI瞆G鉼繎紵o檏霢狉%稡崯bCa #妶H1'>市?
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 4: [E0000] Unrecognized special character
    穘Cl裺呋绳4眣秭早號?7nr?a.P?G汋蚚?!c懺X毎sU乂鄰B壇鉔E]z|贃原貉鎲贡酦$?e? ?毡孋幫KE2檺岮E#-湃uj~?L榍gI\.Vk烽?"?!繯供?JDBu?M\傱'籵?#瞛@=*??#F?jsWSL屡怫簄C罕嶢榺?=I蕇M札|?4皽枝襒|,h焀揂p趓匢g圤`?KX??&泪?&豺]R?/Z{浰4?%?4E喼?-?"猡?
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 5: [E0000] Unrecognized special character
    o?貅3兂f韣"缠?9LAs燬 虥ai衞Ъ霻内L沟厝[9e嚆岱wIM岽燡R瀛晜5|x擼馰鍪?=T芅銻煕嬱dTㄦ摷in莟?'鳓?/扉椥'亱X
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 6: [E0000] Unrecognized special character
    洵蓐@B?/彴?Y敧?te區╣c摌醞瘝/鞦蛬踙B/y*?:}0薯4罃?癐?榎~?Kc&saQ:?8<8?+耽鼈8嵳?<幅褲?7nr?a.P?b常??!S愗瘥 ?;?冹76[鶞蕨g瀸厨?w?=3F?*?哔W?菑Aw擓C?b匓7< t梲lS镂
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 7: [E0000] Unrecognized special character
    卽f?'俎<諫裞莉"?岳5Cp:#姸H0em嵋? 攃懁敤}?0龥z%9鑝q6顩ak馞?,佧鲋咛ㄈi?坼浗幡uSG纡魐?稞呩)3蟂?O仹?*縇9璹ù2.葧n搸=-:態?酄?驿藐!曃+耔祭mo裧嫒俍仱;ir檦鞩R?青U?.勥?=qh&?62呥9殺???"紂5镾t巐\&.\?vK塯Qsv?褍艿搦!?捰蠘雵?1T ?s>?
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 8: [E0000] Unrecognized special character
    绒蠵巙}嗁⑻&銠1?$嬿^畯镈OWk`ヰζ绿矬鲽?
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 9: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    }籯H:鯬沑嶏,痐熐2w吝??mZu姂,`=?f'戁@iq\k市?孻-?酉z?)0(\^?#>垙B?廰桵?:@x?-∣%蔔Q#P攍L嘏顎籊9舟?m>鰗气r?7嵽!跷諎?3H糉?$紉? ?$?8h{撥?7蕟謟$Q鑜笺貨{歚羅,锺?艵囏?dk?磚硳h瞗馮琛礯楀(u;$憶_eGq糇?=t?揄8囩N鎡#韱?w/k"贚gR姏}
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 9: [E0002] Invalid mnemonic specification
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 9: [E0000] Unrecognized special character
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 10: [E0000] Unrecognized special character
    8r:溳A嶓駢P钮ɑ?a絈鰾?D?蛪OY邹^??&g_iM^?F鵂5$
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 11: [E0000] Unrecognized special character
    +鴅?
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 12: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    9?矙癗JU@hi價{v麖B?*繡?.郆T-1??#l?/[WvD?枌轰窍#S阿?!?dR2?>/鲤s?4碍艘誼[9?+鮇?
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 12: [E0002] Invalid mnemonic specification
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 12: [E0000] Unrecognized special character
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 13: [E0000] Unrecognized special character
    歄n佚?>癇?軙沭檁旆蟕Κ>吡MA攋羨尋芔?聡癮jf齯w?摝湬)??<呟A鬬寶s<@0$梿TeXw镏蘯?+榍[晡B虵ō苀(mh%飡)+咦2A暞?-姭?3q[机Q骨諟澁}仒篝祶se昃騶H犱捥Mek餰鰘9恣?$?55軱?%膣啳%瞻y镩GP`胑泒淊?麒沛nY书f<?輷?Tggbi鷔俒*扦鈛粪U?.饿踆kVY6c&?)呄?惥鄌?7〢運2闔葀R&)~`4?2;?+囨猴T?!緃篾?讟??"Ct?tzS?斔蔛?<R嘛匉u-?敞b畯?j$[g搋鯊Q韭哭歮?=3F?蟧氾P?剮OY瘗?O?*{Q'乾0`'猉J瑑m>$佸齃Dr?$槃S刢z
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 14: [E0000] Unrecognized special character
    Mj噏`v堐?繮?
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 15: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    9@J萲?#F?z6w╤L俾簷?_径趇搗z(H卝繘=?7'熬-殁?7v,?/嶨z?
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 15: [E0002] Invalid mnemonic specification
    "../F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.asm", ERROR! at line 15: [E0000] Unrecognized special character
    gmake: *** [F2833x_RAM_RunCode/DSP28xxx_SectionCopy_nonBIOS.obj] Error 1
    Building file: "../SRC/DSP2833x_ADC_cal.asm"
    "D:/ti/ccs1040/ccs/tools/compiler/ti-cgt-c2000_20.2.5.LTS/bin/cl2000" -v28 -ml -mt --float_support=fpu32 --include_path="D:/ti/ccs1040/ccs/tools/compiler/ti-cgt-c2000_20.2.5.LTS/include" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/INCLUDE" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/DRV8301" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/System_Config" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/Data_Convert" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/Data_Communication" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/Motor_Parameter" -g --diag_warning=225 --diag_wrap=off --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="SRC/DSP2833x_ADC_cal.d_raw" --obj_directory="SRC" "../SRC/DSP2833x_ADC_cal.asm"
    30 Assembly Errors, No Assembly Warnings
    >> Compilation failure
    SRC/subdir_rules.mk:16: recipe for target 'SRC/DSP2833x_ADC_cal.obj' failed
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 1: [E0000] Unrecognized special character
    坿_
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 2: [E0000] Unrecognized special character
    曼6?=f孾郟m艚蘖? iA竲@[醻獪?o?+PwW錹?W??!V揫nⅶ偽?咡#i?.e晴8OdL8-消<呱峍妓O6奓qР佾鶂Cp鶽?/〈u?,"肢?:龉?$f俪咰舭捍?%鮵L"覌? 鶌蒅馑76!7Y稣挘{踸.貽tDHM?8汵
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 3: [E0000] Missing right quote of string constant
    "詼沌
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 3: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    "詼沌
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 3: [E0002] Invalid mnemonic specification
    "詼沌
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 4: [E0000] Unrecognized special character
    ?綄S#彭k?2顖S?5
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 5: [E0002] Invalid mnemonic specification
    g?,Y4縟F灼给\?4/?'韒鎾<厊P蠣篿>緓?仟l?9`H戫筘潠 Fc@杴UgC!徵?鮹涘歕笣\vフ邢{1I澪睬?8
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 5: [E0000] Unrecognized special character
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 6: [E0000] Unrecognized special character
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 7: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    ~?M`,]U翢? 駩 対T?<违蛚L?
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 7: [E0002] Invalid mnemonic specification
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 7: [E0000] Unrecognized special character
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 8: [E0000] Unrecognized special character
    曼6?=f孾蝭C菥萋?-.]?m';?>栌&=bt駗痙X?
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 9: [E0000] Unrecognized special character
    綜1?*亲洹譼闉蠷吅?B疡5$
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 10: [E0000] Unrecognized special character
    夕??:扢?"尽K騩"藚?
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 11: [E0000] Unrecognized special character
    増? -忧暂S荖忭媐絲l墨?6飮u?瑨stbiN烛劦?薏m講#訠?2:<:瀥朜
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 12: [E0000] Unrecognized special character
    K頓??4?Cr渓B
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 13: [E0002] Invalid mnemonic specification
    A7nj@4鍶m榊b櫻笏]?3j?;?吳_R儃嚶? R?.塁泥!僓:N4P捈祱矍\
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 13: [E0000] Unrecognized special character
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 14: [E0000] Unrecognized special character
    ?1$?蓄*iS"C潟?
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 15: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    p舐E劵5祋e?撦輳璯?^礢&XU飌1a?%^yY隺?
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 15: [E0002] Invalid mnemonic specification
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 15: [E0000] Unrecognized special character
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 16: [E0000] Unrecognized special character
    Y?
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 17: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    t)"#溇?*靖廠澈M竞峿G犵aθ颡vP瞛?/沉 ?"磤蚥鏊鏡Ec级-?/贀?儐u畐w%9搔?;忓? ?lacdC仫奄S厕`踸.貽?'7坱?
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 17: [E0002] Invalid mnemonic specification
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 17: [E0000] Unrecognized special character
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 18: [E0002] Invalid mnemonic specification
    S
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 19: [E0000] Unrecognized special character
    ju狫?[蚅h兞俭?!&?1?
    "../SRC/DSP2833x_ADC_cal.asm", ERROR! at line 20: [E0000] Unrecognized special character
    嵭厊悕?*q??*瞟o譜{?嗝诶圳LEmN榮[iM/镩?4
    gmake: *** [SRC/DSP2833x_ADC_cal.obj] Error 1
    Building file: "../SRC/DSP2833x_usDelay.asm"
    "D:/ti/ccs1040/ccs/tools/compiler/ti-cgt-c2000_20.2.5.LTS/bin/cl2000" -v28 -ml -mt --float_support=fpu32 --include_path="D:/ti/ccs1040/ccs/tools/compiler/ti-cgt-c2000_20.2.5.LTS/include" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/INCLUDE" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/DRV8301" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/System_Config" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/Data_Convert" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/Data_Communication" --include_path="D:/ti/workspace_v10/TMS320F28335/DRV8301_ACIM_FOC/Motor_Parameter" -g --diag_warning=225 --diag_wrap=off --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="SRC/DSP2833x_usDelay.d_raw" --obj_directory="SRC" "../SRC/DSP2833x_usDelay.asm"
    29 Assembly Errors, No Assembly Warnings
    >> Compilation failure
    SRC/subdir_rules.mk:16: recipe for target 'SRC/DSP2833x_usDelay.obj' failed
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 1: [E0000] Unrecognized special character
    坿?
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 2: [E0000] Unrecognized special character
    綫磡3?,?彚?窦?餙?'?03?幷LJ?
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 3: [E0000] Unrecognized special character
    ?2X?9?銬31沷沋b?K]╨溫Z梞wt?鈟惬倇?劵E岌
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 4: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    ~?$蜾2殕捦笎$,?72迎軘喀蝼尶?6篚9l_$覆
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 4: [E0002] Invalid mnemonic specification
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 4: [E0000] Unrecognized special character
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 5: [E0000] Unrecognized special character
    M?/旘鶿w>S轘8鐧]v笧(觑K羪萡汭?+(戞Pc?0厖DF?&VD嘆图弑?5W?-|%纨
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 6: [E0000] Unrecognized special character
    衧i~鋮圳I?x閐C瓷O衋?>i豹Q諗鮔O2F偵邲?=?)?T?崈逆('?9?y3?屣}cx:闲鄛凢?.q垅鱎窾E幹邝P;?*O晉w[櫼偝D>?:姩@Lj?{w?叫栖 尻?R?,叨燢昫?>译?嬧騖?=骆鹆3e?0?91?腭,?V?4掕?q娆%?%匆窦镛29挩
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 7: [E0000] Unrecognized special character
    D罷?3??(O娽4 蘡菃J?!ZO?畺愽??Wsc穿Q?+嚠?琑瑚
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 8: [E0000] Unrecognized special character
    b赌tU蹁N#笐
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 9: [E0000] Unrecognized special character
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 10: [E0000] Unrecognized special character
    i?:nwL杽囇陝$+?:9z朵枦淹G北聹??臏Mx傖Bk6!|
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 11: [E0000] Unrecognized special character
    煰?朇X%醳Д扳T縱垎MW僲`蛊嚁巘怴馤纸H0?檄g?27姆釕??$鮇樴y坟嬓x4?0緎走v碦0DF吗顕f玍|鏸悍e?&?>(蟒P軝宺nI茖櫼莤萳?
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 12: [E0000] Unrecognized special character
    ?壼犠5巈?C藽厱*)$?;V?<衚/P
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 13: [E0000] Unrecognized special character
    R沛鏠?罆桏i?.?0q翅珋iA?屈GTb偤磺wc^停谪遷姴峉茅?
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 14: [E0000] Unrecognized special character
    ?-?5硩鬋A戔遶焲檮跊<&?.;?咖%?@?:羽騑b畨9Y?0$⑷禚盒2赋襦D罷鈡擣榰|藰?xOE?c吤宺rd縕鄸ヒ?纔j┘c?;愙?圜^2髧=瑖[8窞L,例?麜?
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 15: [E0000] Unrecognized special character
    I??砉鏩恱琾??/<尅恷懲??3笶h舑阦珢犚}^? 鍆W筳?7莔e~蘕?!9?J倃?&et駗?'Z鞐緈鶷袦%?
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 16: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    %淙\s
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 16: [E0002] Invalid mnemonic specification
    %淙\s
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 16: [E0000] Unrecognized special character
    %淙\s
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 17: [E0000] Unrecognized special character
    熜浻雄uV?#卫芢XV阅舗*魬僚?"?贞vQ▔傚d鉾垑/然鈷命?'?
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 18: [E0000] Unrecognized special character
    綦e险>翩@軉銪5稙伭? 孉??儒橘f耚?^G翯厱*)$4儮鉿??.a
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 19: [E0000] Unrecognized special character
    栃鮅?2膵阱F7鷔蒾4茴=太
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 20: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword.
    $埞鯀72西悧怸*乢?/忓?O?.儁?堘馹噋暘髢0*鈢銀}擲简i颲がA砢乜?4兿v怱k鲉斗鋿Mp嗣楦;??>?靣M牡c@J?0纮E? ^F?椉?2P?"s%骒
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 20: [E0002] Invalid mnemonic specification
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 20: [E0000] Unrecognized special character
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 21: [E0000] Unrecognized special character
    掎粬辛|鈉G城毞O?=
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 22: [E0000] Unrecognized special character
    蹃FM僲j巸?/纕?謪O:扰?真.硉堂z庼嵊櫼??鮇敵?骨寝a}?6?5烙nK?;_洈途I憓V豏n槤??>t背栒碦j. 栵謬?,?罽8?樴锢a?7慩b3?"牙RV^K洎臱3睭?.EPD儙v??7仈洿t?f?MkⅦ蟺>?7濐AKj睾⑽}b幍咦?猃?X么錛?
    "../SRC/DSP2833x_usDelay.asm", ERROR! at line 23: [E0000] Unrecognized special character
    铫?頠?9?.-輆箓愬{|5
    gmake: *** [SRC/DSP2833x_usDelay.obj] Error 1
    gmake: Target 'all' not remade because of errors.
    **** Build Finished ****
  • 根据错误信息来看是你文件的编码方式不正确。
  • 那我该如何操作来修复这个问题呢,代码是从我的笔记本复制过去的,我笔记本上就好好的
  • 你在两台电脑上分别查看一下这个工程的编码方式:
    另外你的工程是如何导出的?
  • 刚看了,两边电脑都是GBK编码方式,我是直接把笔记本那边的工程复制到台式机那边,然后台式机那边按正常操作在CCS里面导入
  • 我是直接把笔记本那边的工程复制到台式机那边
    工程是怎么导出的?
  • 找到原因了,电脑是公司的,上面装了个文件加密的软件,是这个软件造成的。TI的CCS,microchip的MPLAB,这两家的IDE上的代码工程都出现了一样的字符识别问题。
  • 谢谢你的帮助
  • 客气了。也非常感谢您的反馈
