CSS6.0 XP 安装不成功
Other Parts Discussed in Thread: ENERGYTRACE, CCSTUDIO
我用linux 安装CSS6.0离线包安装可以成功,但是在winXP下用离线包和在线安装都不成功, 安装的时候只选择C2000 那一项中的前两个,其它都不选。安装log ,我截取了后面部分。
我电脑中安装过eclipse,还有其它公司基于eclipse硬件开发套件。
07/01/2014 17:24:28PM - getprefix - installdir for ARM_CGT_HELP: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for C2000_CGT_HELP: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for C5500_CGT_HELP: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for C6000_CGT_HELP: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_DOC. Using Defaults.
07/01/2014 17:24:28PM - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_LAUNCHER. Using Defaults.
07/01/2014 17:24:28PM - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_UTILS. Using Defaults.
07/01/2014 17:24:28PM - getprefix - installdir for DVT_COMMON: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for DVT_TRACE: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for DVT_UIA: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for DVT_VIA_CCS: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for DVT_ENERGYTRACE: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for ECLIPSE: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for EMU_SD: D:/TI/ccsv6/ccs_base
07/01/2014 17:24:28PM - getprefix - installdir for GMF: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for IDE_MAIN: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for IDE_WORKFLOW: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for IDE_ARM: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for IDE_MSP430: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for IDE_C2000: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for IDE_C5400: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for IDE_C5500: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for IDE_C6000: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for IDE_CHROME: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for IDE_GC: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for IDE_TOOLS_COMMON: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for KEYSTONE1: D:/TI/ccsv6/ccs_base
07/01/2014 17:24:28PM - getprefix - installdir for KEYSTONE2: D:/TI/ccsv6/ccs_base
07/01/2014 17:24:28PM - getprefix - installdir for MSP430_CGT_HELP: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getinstalluninstallcmds - Did not find matching component in InstallIni MSVC_REDIST_2005. Using Defaults.
07/01/2014 17:24:28PM - getprefix - installdir for MSVC_REDIST_2005: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getinstalluninstallcmds - Did not find matching component in InstallIni MSVC_REDIST_2012. Using Defaults.
07/01/2014 17:24:28PM - getprefix - installdir for MSVC_REDIST_2012: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for P2APP: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getprefix - installdir for P2TOOLS: D:/TI/ccsv6/
07/01/2014 17:24:28PM - getinstalluninstallcmds - Did not find matching component in InstallIni TARGETDB_DEF_PROPS. Using Defaults.
07/01/2014 17:24:28PM - getprefix - installdir for TARGET_CONTENT_CORE: D:/TI/ccsv6/..
07/01/2014 17:24:28PM - ProgressPane::Run - Starting install process in separate thread
07/01/2014 17:24:28PM - ProgressPane::Run - call = RunInstall D:/TI/ccsv6/eclipse/ccs_config.xml 0 0 0 0 D:/TI/ccsv6/install_logs/ccs_setup_6.0.0.00190_install.log ::progressPane0 tid00000C54
07/01/2014 17:24:28PM - ProgressPane::Run - separate threads
07/01/2014 17:24:29PM - ProgressPane::Run - thread = tid00000F74
07/01/2014 17:24:29PM - RunMain - Started with params pConfigFile=D:/TI/ccsv6/eclipse/ccs_config.xml pProfiling=0 pUpdate=0 logfile=D:/TI/ccsv6/install_logs/ccs_setup_6.0.0.00190_install.log progress=::threadedProgressUpdate0
07/01/2014 17:24:29PM - readConfigFile - Start installing components:
07/01/2014 17:24:29PM - readConfigFile - read config file D:/TI/ccsv6/eclipse/ccs_config.xml
07/01/2014 17:24:29PM - readConfigFile - found D:/TI/ccsv6/eclipse/ccs_config.xml
07/01/2014 17:24:29PM - readConfigFile - Parsing Root Elements
07/01/2014 17:24:29PM - readConfigFile - Done Parsing
07/01/2014 17:24:29PM - readConfigFile - CCSDIR=D:/TI/ccsv6
07/01/2014 17:24:29PM - readConfigFile - EclipseDir=D:/TI/ccsv6/eclipse
07/01/2014 17:24:29PM - readConfigFile - InstallDir=D:/TI
07/01/2014 17:24:29PM - readConfigFile - TempDir=C:/Documents and Settings/yanguang_chen/Local Settings/Temp/ccs_45c0b953-70ad-4d83-7ba9-b0014507c098
07/01/2014 17:24:29PM - readConfigFile - platform=windows
07/01/2014 17:24:29PM - readConfigFile - LocalBaseRepository=D:/setup/TI/CCS6.0.0.00190_win32/baserepo
07/01/2014 17:24:29PM - readConfigFile - baserepourl=D:/setup/TI/CCS6.0.0.00190_win32/baserepo
07/01/2014 17:24:29PM - readConfigFile - featureurl=D:/setup/TI/CCS6.0.0.00190_win32/featurerepo
07/01/2014 17:24:29PM - readConfigFile - LocalRepository_Exists=1
07/01/2014 17:24:29PM - readConfigFile - componentinstaller=false
07/01/2014 17:24:29PM - readConfigFile - eclipseexe=eclipsec.exe
07/01/2014 17:24:29PM - readConfigFile - in install components
07/01/2014 17:24:29PM - readUserProfile - userprofile = C:\Documents and Settings\yanguang_chen
07/01/2014 17:24:29PM - downloadIfRequired - File D:/setup/TI/CCS6.0.0.00190_win32/baserepo/jre_1.6.0_13.zip already exists. Not attempting to download
07/01/2014 17:24:29PM - extract - cmd = "C:/Documents and Settings/yanguang_chen/Local Settings/Temp/ccs_45c0b953-70ad-4d83-7ba9-b0014507c098/util/unzip.exe" -q -o -d "D:/TI/ccsv6/eclipse" "D:/setup/TI/CCS6.0.0.00190_win32/baserepo/jre_1.6.0_13.zip"
07/01/2014 17:24:33PM - extract - successfully unzipped D:/setup/TI/CCS6.0.0.00190_win32/baserepo/jre_1.6.0_13.zip
07/01/2014 17:24:34PM - downloadIfRequired - File D:/setup/TI/CCS6.0.0.00190_win32/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip already exists. Not attempting to download
07/01/2014 17:24:35PM - extract - cmd = "C:/Documents and Settings/yanguang_chen/Local Settings/Temp/ccs_45c0b953-70ad-4d83-7ba9-b0014507c098/util/unzip.exe" -q -o -d "C:/Documents and Settings/yanguang_chen/Local Settings/Temp/ccs_45c0b953-70ad-4d83-7ba9-b0014507c098" "D:/setup/TI/CCS6.0.0.00190_win32/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip"
07/01/2014 17:24:35PM - extract - successfully unzipped D:/setup/TI/CCS6.0.0.00190_win32/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip
07/01/2014 17:24:35PM - findLauncher - launcher version = 1.3.0.v20130327-1440
07/01/2014 17:24:35PM - installEclipse - using D:/TI/ccsv6/eclipse/jre/bin/java.exe
07/01/2014 17:24:35PM - installEclipse - "D:/TI/ccsv6/eclipse/jre/bin/java.exe" -Xmx512m "-Dosgi.configuration.area=C:/Documents and Settings/yanguang_chen/Local Settings/Temp/ccs_45c0b953-70ad-4d83-7ba9-b0014507c098/eclipse/cfg" "-Dosgi.instance.area=C:/Documents and Settings/yanguang_chen/Local Settings/Temp/ccs_45c0b953-70ad-4d83-7ba9-b0014507c098/eclipse/ws" -jar "C:/Documents and Settings/yanguang_chen/Local Settings/Temp/ccs_45c0b953-70ad-4d83-7ba9-b0014507c098/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar" -application org.eclipse.equinox.p2.director -repository "file:/D:/setup/TI/CCS6.0.0.00190_win32/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group -destination "D:/TI/ccsv6/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "D:/TI/ccsv6/eclipse/" -p2.os win32 -p2.ws win32 -p2.arch x86 -roaming
07/01/2014 17:24:35PM - runEclipseApp - running cmd "D:/TI/ccsv6/eclipse/jre/bin/java.exe" -Xmx512m "-Dosgi.configuration.area=C:/Documents and Settings/yanguang_chen/Local Settings/Temp/ccs_45c0b953-70ad-4d83-7ba9-b0014507c098/eclipse/cfg" "-Dosgi.instance.area=C:/Documents and Settings/yanguang_chen/Local Settings/Temp/ccs_45c0b953-70ad-4d83-7ba9-b0014507c098/eclipse/ws" -jar "C:/Documents and Settings/yanguang_chen/Local Settings/Temp/ccs_45c0b953-70ad-4d83-7ba9-b0014507c098/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar" -application org.eclipse.equinox.p2.director -repository "file:/D:/setup/TI/CCS6.0.0.00190_win32/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group -destination "D:/TI/ccsv6/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "D:/TI/ccsv6/eclipse/" -p2.os win32 -p2.ws win32 -p2.arch x86 -roaming
07/01/2014 17:25:09PM - runEclipseApp - Installing org.eclipse.platform.ide 4.3.1.M20130911-1000.
Installing org.eclipse.help.feature.group 2.0.1.v20130911-1000.
Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.100.v20130502-0334.
Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20130828-0031.
Installing org.eclipse.cdt.feature.group 8.2.1.201309180223.
Installing org.eclipse.cdt.debug.ui.memory.feature.group 2.2.0.201309180223.
Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.100.201308290741.
Installing org.eclipse.epp.mpc.feature.group 1.2.1.I20130917-2019.
Installing org.eclipse.egit.feature.group 3.0.3.201309161630-r.
Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf.
Installing org.eclipse.cdt.build.crossgcc.feature.group 1.2.0.201309180223.
Installing org.eclipse.rse.feature.group 3.5.0.201309112143.
Installing org.eclipse.cdt.launch.remote.feature.group 6.2.0.201309180223. done.
07/01/2014 17:25:09PM - installEclipse - eclipse installed successfully, looking for binary
07/01/2014 17:25:09PM - downloadIfRequired - File D:/setup/TI/CCS6.0.0.00190_win32/baserepo/updateinstaller.zip already exists. Not attempting to download
07/01/2014 17:25:10PM - extract - cmd = "C:/Documents and Settings/yanguang_chen/Local Settings/Temp/ccs_45c0b953-70ad-4d83-7ba9-b0014507c098/util/unzip.exe" -q -o -d "D:/TI/ccsv6/eclipse" "D:/setup/TI/CCS6.0.0.00190_win32/baserepo/updateinstaller.zip"
07/01/2014 17:25:10PM - extract - successfully unzipped D:/setup/TI/CCS6.0.0.00190_win32/baserepo/updateinstaller.zip
07/01/2014 17:25:10PM - setEclipseRunner - Couldn't find an eclipse runner
07/01/2014 17:25:10PM - installP2app - "eclipsec.exe" -application org.eclipse.equinox.p2.director -repository "file:/D:/setup/TI/CCS6.0.0.00190_win32/baserepo/p2appfRepo" -installiu com.ti.ccstudio.p2appf.feature.group -nosplash
07/01/2014 17:25:10PM - runEclipseApp - running cmd "eclipsec.exe" -application org.eclipse.equinox.p2.director -repository "file:/D:/setup/TI/CCS6.0.0.00190_win32/baserepo/p2appfRepo" -installiu com.ti.ccstudio.p2appf.feature.group -nosplash
07/01/2014 17:25:20PM - runEclipseApp - Running again
07/01/2014 17:25:20PM - runEclipseApp - couldn't execute "eclipsec.exe": no such file or directory
07/01/2014 17:25:30PM - runEclipseApp - Running again
07/01/2014 17:25:30PM - runEclipseApp - can't run for a fourth time
07/01/2014 17:25:30PM - runEclipseApp - couldn't execute "eclipsec.exe": no such file or directory failed.
07/01/2014 17:25:30PM - processOtherFeatures - length of features = 68; 1; 0
07/01/2014 17:25:30PM - processOtherFeatures - JRE state: feature installed; does not need to be processed
07/01/2014 17:25:30PM - processOtherFeatures - length of features = 68; 2; 0
07/01/2014 17:25:30PM - processOtherFeatures - ECLIPSECORE state: feature installed; does not need to be processed
07/01/2014 17:25:30PM - processOtherFeatures - length of features = 68; 3; 0
07/01/2014 17:25:30PM - processOtherFeatures - processing INSTALLER
07/01/2014 17:25:30PM - processOtherFeatures - state:initial
07/01/2014 17:25:30PM - processOtherFeatures - binary:6.0.0.00190.zip
07/01/2014 17:25:30PM - processOtherFeatures - location = D:/setup/TI/CCS6.0.0.00190_win32/featurerepo
07/01/2014 17:25:30PM - processOtherFeatures - newloc:file:/D:/setup/TI/CCS6.0.0.00190_win32/featurerepo
07/01/2014 17:25:30PM - processOtherFeatures - length of features = 68; 4; 1
07/01/2014 17:25:30PM - processOtherFeatures - ECLIPSE state: feature installed; does not need to be processed
07/01/2014 17:25:30PM - processOtherFeatures - length of features = 68; 5; 1
07/01/2014 17:25:30PM - processOtherFeatures - MSVC_REDIST_2005 state: do not install; does not need to be processed
07/01/2014 17:25:30PM - processOtherFeatures - length of features = 68; 6; 1
07/01/2014 17:25:30PM - processOtherFeatures - MSVC_REDIST_2012 state: do not install; does not need to be processed
07/01/2014 17:25:30PM - processOtherFeatures - length of features = 68; 7; 1
07/01/2014 17:25:30PM - processOtherFeatures - processing DS
07/01/2014 17:25:30PM - processOtherFeatures - binary:ti_dspack_ibsetup_6.0.0.660.exe
07/01/2014 17:25:30PM - processOtherFeatures - counting = 6; 7 68
07/01/2014 17:25:30PM - processOtherFeatures - fullrepolist file:/D:/setup/TI/CCS6.0.0.00190_win32/featurerepo
07/01/2014 17:25:30PM - processOtherFeatures - fullfeaturelist com.ti.ccstudio.installer.win32.feature.group,com.ti.ccstudio.debugserver.win32.feature.group
07/01/2014 17:25:30PM - runEclipseApp - running cmd "eclipsec.exe" -application org.eclipse.equinox.p2.director -repository "file:/D:/setup/TI/CCS6.0.0.00190_win32/featurerepo" -installiu com.ti.ccstudio.installer.win32.feature.group,com.ti.ccstudio.debugserver.win32.feature.group -nosplash
07/01/2014 17:25:40PM - runEclipseApp - Running again
07/01/2014 17:25:40PM - runEclipseApp - couldn't execute "eclipsec.exe": no such file or directory
07/01/2014 17:25:50PM - runEclipseApp - Running again
07/01/2014 17:25:50PM - runEclipseApp - can't run for a fourth time
07/01/2014 17:25:50PM - runEclipseApp - couldn't execute "eclipsec.exe": no such file or directory failed.
07/01/2014 17:25:50PM - processOtherFeatures - Processing INSTALLER to install
07/01/2014 17:25:50PM - processOtherFeatures - current state = initial
07/01/2014 17:25:50PM - processOtherFeatures - location = D:/setup/TI/CCS6.0.0.00190_win32/featurerepo
07/01/2014 17:25:50PM - processOtherFeatures - Binary=D:/TI/ccsv6/eclipse/downloads/6.0.0.00190.zip
07/01/2014 17:25:50PM - runEclipseApp - running cmd "eclipsec.exe" -application org.eclipse.equinox.p2.director -uninstallIU com.ti.ccstudio.installer.win32.feature.group -nosplash
07/01/2014 17:26:00PM - runEclipseApp - Running again
07/01/2014 17:26:00PM - runEclipseApp - couldn't execute "eclipsec.exe": no such file or directory
07/01/2014 17:26:10PM - runEclipseApp - Running again
07/01/2014 17:26:10PM - runEclipseApp - can't run for a fourth time
07/01/2014 17:26:10PM - runEclipseApp - couldn't execute "eclipsec.exe": no such file or directory failed.
07/01/2014 17:26:10PM - runEclipseApp - running cmd "eclipsec.exe" -application org.eclipse.equinox.p2.director -repository "file:/D:/setup/TI/CCS6.0.0.00190_win32/featurerepo" -installIU com.ti.ccstudio.installer.win32.feature.group -nosplash
07/01/2014 17:26:20PM - runEclipseApp - Running again
07/01/2014 17:26:20PM - runEclipseApp - couldn't execute "eclipsec.exe": no such file or directory
07/01/2014 17:26:22PM - cancelConfirmed - CCS_WARNING: User elected to cancel installation.
07/01/2014 17:26:30PM - runEclipseApp - Running again
07/01/2014 17:26:30PM - runEclipseApp - can't run for a fourth time
07/01/2014 17:26:30PM - runEclipseApp - couldn't execute "eclipsec.exe": no such file or directory failed.
07/01/2014 17:26:30PM - processOtherFeatures - 6.0.0.00190.zip does not exist at D:/TI/ccsv6/eclipse/downloads/6.0.0.00190.zip. Setting state to feature downloaded
07/01/2014 17:26:30PM - processOtherFeatures - new state: feature downloaded
07/01/2014 17:26:30PM - checkCancel -
07/01/2014 17:26:32PM - checkCancel - CCS_INFO: saving D:/TI/ccsv6/install_logs
07/01/2014 17:26:32PM - cancel -
07/01/2014 17:26:32PM - cancel - CCS_INFO: saving D:/TI/ccsv6/install_logs
