Part Number: TMS320F28379D
Other Parts Discussed in Thread: CCSTUDIO
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ff90e2881d9, pid=11132, tid=0x00000000000030d4
# JRE version: Java(TM) SE Runtime Environment (8.0_144-b01) (build 1.8.0_144-b01)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.144-b01 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [DebugServer.dll+0xa81d9]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# bugreport.java.com/.../crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0000026b1e345000): JavaThread "polling thread" daemon [_thread_in_native, id=12500, stack(0x000000dab0f00000,0x000000dab1000000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x0000000000000008
Registers:
RAX=0x0000000000000015, RBX=0x0000026b26976b60, RCX=0x0000000000000008, RDX=0x000000dab0ffe0f0
RSP=0x000000dab0ffdd30, RBP=0x000000dab0ffde70, RSI=0x000000dab0ffe0f0, RDI=0x0000026b26976b10
R8 =0x0000026b247f98b0, R9 =0x0000026b247f98b0, R10=0x0000000000000000, R11=0x0000026b247f98b0
R12=0x0000000000000000, R13=0x0000000000000000, R14=0x0000026b249196f0, R15=0x000000dab0ffe0f0
RIP=0x00007ff90e2881d9, EFLAGS=0x0000000000010202
Top of Stack: (sp=0x000000dab0ffdd30)
0x000000dab0ffdd30: 0000026b2a754ed0 000000dab0ffde70
0x000000dab0ffdd40: 000000dab0ffe0f0 0000026b26976b10
0x000000dab0ffdd50: 0000026b247f98b0 0000026b24919601
0x000000dab0ffdd60: 0000026b24919698 00007ff90e23c631
0x000000dab0ffdd70: 0000026b2a856990 0000026b2a754ed0
0x000000dab0ffdd80: 0000026b2a754db0 000000dab0ffde90
0x000000dab0ffdd90: 0000026b26812d70 0000026b26813310
0x000000dab0ffdda0: 0000026b26813310 000000dab0ffde90
0x000000dab0ffddb0: 0000026b00000000 0000026b2a754ed0
0x000000dab0ffddc0: 0000026b26812d10 0000026b2680b6b0
0x000000dab0ffddd0: 0000000000000000 0000000000000000
0x000000dab0ffdde0: 0000026b269730e0 00007ff97ef947b1
0x000000dab0ffddf0: 0000026b2485b230 0000026b2485b258
0x000000dab0ffde00: 0000000000000000 0000000000000000
0x000000dab0ffde10: 0000026b187421a0 00007ff97ef947b1
0x000000dab0ffde20: 0000026b269730e0 0000026b79be0000
Instructions: (pc=0x00007ff90e2881d9)
0x00007ff90e2881b9: 8b 74 24 50 48 83 c4 30 5f e9 59 04 00 00 80 7e
0x00007ff90e2881c9: 30 00 0f 84 ac 00 00 00 48 8b 4b 08 48 83 c1 08
0x00007ff90e2881d9: 48 8b 01 ff 50 20 85 c0 74 6f 48 8b cb e8 e5 04
0x00007ff90e2881e9: 00 00 84 c0 74 63 48 8d 4b 20 c6 46 30 00 4c 8d
Register to memory mapping:
RAX=0x0000000000000015 is an unknown value
RBX=0x0000026b26976b60 is an unknown value
RCX=0x0000000000000008 is an unknown value
RDX=0x000000dab0ffe0f0 is pointing into the stack for thread: 0x0000026b1e345000
RSP=0x000000dab0ffdd30 is pointing into the stack for thread: 0x0000026b1e345000
RBP=0x000000dab0ffde70 is pointing into the stack for thread: 0x0000026b1e345000
RSI=0x000000dab0ffe0f0 is pointing into the stack for thread: 0x0000026b1e345000
RDI=0x0000026b26976b10 is an unknown value
R8 =0x0000026b247f98b0 is an unknown value
R9 =0x0000026b247f98b0 is an unknown value
R10=0x0000000000000000 is an unknown value
R11=0x0000026b247f98b0 is an unknown value
R12=0x0000000000000000 is an unknown value
R13=0x0000000000000000 is an unknown value
R14=0x0000026b249196f0 is an unknown value
R15=0x000000dab0ffe0f0 is pointing into the stack for thread: 0x0000026b1e345000
Stack: [0x000000dab0f00000,0x000000dab1000000], sp=0x000000dab0ffdd30, free space=1015k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [DebugServer.dll+0x5c631]
C [DebugServer.dll+0x69327]
C [DebugServer.dll+0xa866a]
C [DebugServer.dll+0xa853e]
C [DebugServer.dll+0xa811a]
C [DebugServer.dll+0x5a5dc]
C [DebugServer.dll+0x1043d2]
C [DebugServer.dll+0x69c5e]
C [DebugServer.dll+0x1062b2]
C [DebugServer.dll+0x6bc2f]
C [DebugServer.dll+0x2ebd5]
C [DebugServer.dll+0x2617c]
C [DebugServer.dll+0x21be9]
C [ti_xpcom.dll+0x334c9]
C [ti_xpcom.dll+0xddc0]
C [ti_xpcom.dll+0xf49a]
C 0x0000026b0001925b
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j com.ti.xpcom.internal.XPCOMJavaProxy.callXPCOMMethod(JLjava/lang/String;[Ljava/lang/Object;)Ljava/lang/Object;+0
j com.ti.xpcom.internal.XPCOMJavaProxy.invoke(Ljava/lang/Object;Ljava/lang/reflect/Method;[Ljava/lang/Object;)Ljava/lang/Object;+107
j com.sun.proxy.$Proxy22.pollThreadMain()V+9
j com.ti.debug.engine.cce.CCEDebugEngine$1.run()V+10
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0000026b1df7f800 JavaThread "Thread-54" daemon [_thread_in_native, id=9180, stack(0x000000dab1f00000,0x000000dab2000000)]
0x0000026b1df78000 JavaThread "MemoryServer.EventQueue" [_thread_blocked, id=9080, stack(0x000000dab0800000,0x000000dab0900000)]
0x0000026b1df76800 JavaThread "com.ti.ccstudio.debug.debugModel - 0" [_thread_blocked, id=10376, stack(0x000000daac600000,0x000000daac700000)]
0x0000026b1df79800 JavaThread "org.eclipse.cdt.internal.ui.text.CReconciler" daemon [_thread_blocked, id=13168, stack(0x000000daac500000,0x000000daac600000)]
0x0000026b1df7c000 JavaThread "Provisioning Event Dispatcher" daemon [_thread_blocked, id=13600, stack(0x000000daac400000,0x000000daac500000)]
0x0000026b1df77800 JavaThread "qtp637612109-72-acceptor-1@240a5ab2-ServerConnector@7a9d5f15{HTTP/1.1,[http/1.1]}{127.0.0.1:49843}" [_thread_in_native, id=4940, stack(0x000000dab1e00000,0x000000dab1f00000)]
0x0000026b1df7b000 JavaThread "qtp637612109-71-acceptor-0@331385a1-ServerConnector@7a9d5f15{HTTP/1.1,[http/1.1]}{127.0.0.1:49843}" [_thread_blocked, id=4676, stack(0x000000dab1d00000,0x000000dab1e00000)]
0x0000026b1df7a800 JavaThread "qtp637612109-70" [_thread_in_native, id=4860, stack(0x000000dab1c00000,0x000000dab1d00000)]
0x0000026b1e342000 JavaThread "qtp637612109-69" [_thread_in_native, id=4828, stack(0x000000dab1b00000,0x000000dab1c00000)]
0x0000026b174eb800 JavaThread "qtp637612109-67" [_thread_in_native, id=4212, stack(0x000000dab1a00000,0x000000dab1b00000)]
0x0000026b1e351000 JavaThread "qtp637612109-66" [_thread_in_native, id=4100, stack(0x000000dab1900000,0x000000dab1a00000)]
0x0000026b1e349800 JavaThread "qtp637612109-65" [_thread_in_native, id=4736, stack(0x000000dab1800000,0x000000dab1900000)]
0x0000026b1e34f800 JavaThread "qtp637612109-64" [_thread_in_native, id=3152, stack(0x000000dab1700000,0x000000dab1800000)]
0x0000026b1e34e000 JavaThread "qtp637612109-63" [_thread_in_native, id=1028, stack(0x000000dab1600000,0x000000dab1700000)]
0x0000026b1e34c800 JavaThread "qtp637612109-62" [_thread_in_native, id=8, stack(0x000000dab1500000,0x000000dab1600000)]
0x0000026b1e350800 JavaThread "qtp637612109-61" [_thread_in_native, id=6712, stack(0x000000dab1400000,0x000000dab1500000)]
0x0000026b1e34b000 JavaThread "qtp637612109-60" [_thread_in_native, id=6496, stack(0x000000dab1300000,0x000000dab1400000)]
0x0000026b1e34a800 JavaThread "Worker-15" [_thread_blocked, id=4308, stack(0x000000dab1200000,0x000000dab1300000)]
0x0000026b1e34d800 JavaThread "Worker-14" [_thread_blocked, id=11376, stack(0x000000dab1100000,0x000000dab1200000)]
=>0x0000026b1e345000 JavaThread "polling thread" daemon [_thread_in_native, id=12500, stack(0x000000dab0f00000,0x000000dab1000000)]
0x0000026b1e34c000 JavaThread "Worker-13: Launching LAN9252_SPI_379" [_thread_blocked, id=12912, stack(0x000000daaf000000,0x000000daaf100000)]
0x0000026b1e349000 JavaThread "Scripting Console - Rhino" [_thread_blocked, id=9772, stack(0x000000daaed00000,0x000000daaee00000)]
0x0000026b1e344800 JavaThread "xpcom dispose thread" daemon [_thread_blocked, id=13908, stack(0x000000dab0a00000,0x000000dab0b00000)]
0x0000026b1e348000 JavaThread "Timer-2" [_thread_blocked, id=10088, stack(0x000000dab0600000,0x000000dab0700000)]
0x0000026b1e347800 JavaThread "Worker-12" [_thread_blocked, id=11368, stack(0x000000dab0500000,0x000000dab0600000)]
0x0000026b174f4000 JavaThread "Worker-11" [_thread_blocked, id=11332, stack(0x000000dab0400000,0x000000dab0500000)]
0x0000026b174f3000 JavaThread "Worker-10" [_thread_blocked, id=11040, stack(0x000000dab0300000,0x000000dab0400000)]
0x0000026b174f2800 JavaThread "Worker-9" [_thread_blocked, id=11436, stack(0x000000dab0200000,0x000000dab0300000)]
0x0000026b174f1800 JavaThread "Worker-8" [_thread_blocked, id=10512, stack(0x000000dab0100000,0x000000dab0200000)]
0x0000026b174f1000 JavaThread "Worker-7" [_thread_blocked, id=11028, stack(0x000000dab0000000,0x000000dab0100000)]
0x0000026b174f0000 JavaThread "Worker-6" [_thread_blocked, id=3656, stack(0x000000daaff00000,0x000000dab0000000)]
0x0000026b174e9800 JavaThread "Worker-5" [_thread_blocked, id=11324, stack(0x000000daafe00000,0x000000daaff00000)]
0x0000026b174ef800 JavaThread "Worker-4" [_thread_blocked, id=5300, stack(0x000000daafd00000,0x000000daafe00000)]
0x0000026b174ee800 JavaThread "Worker-3" [_thread_blocked, id=9812, stack(0x000000daafc00000,0x000000daafd00000)]
0x0000026b174ec800 JavaThread "Worker-1" [_thread_blocked, id=11568, stack(0x000000daafa00000,0x000000daafb00000)]
0x0000026b174ee000 JavaThread "EventAdmin Async Event Dispatcher Thread" daemon [_thread_blocked, id=8576, stack(0x000000daaf900000,0x000000daafa00000)]
0x0000026b174e6800 JavaThread "Git Repository Closer" daemon [_thread_blocked, id=14176, stack(0x000000daaf800000,0x000000daaf900000)]
0x0000026b174e8800 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=14120, stack(0x000000daaf700000,0x000000daaf800000)]
0x0000026b170cc000 JavaThread "EMF Reference Cleaner" daemon [_thread_blocked, id=13992, stack(0x000000daaf600000,0x000000daaf700000)]
0x0000026b17a69000 JavaThread "Worker-0" [_thread_blocked, id=13984, stack(0x000000daaf500000,0x000000daaf600000)]
0x0000026b15eaf800 JavaThread "Worker-JM" [_thread_blocked, id=6480, stack(0x000000daaef00000,0x000000daaf000000)]
0x0000026b15c9a800 JavaThread "Gogo shell" [_thread_blocked, id=7508, stack(0x000000daaee00000,0x000000daaef00000)]
0x0000026b156c3000 JavaThread "SCR Component Actor" daemon [_thread_blocked, id=6540, stack(0x000000daaec00000,0x000000daaed00000)]
0x0000026b15596800 JavaThread "Start Level: Equinox Container: 54b3a3f5-f34f-412c-99bc-4aac3c1948e0" daemon [_thread_blocked, id=1700, stack(0x000000daaeb00000,0x000000daaec00000)]
0x0000026b15504000 JavaThread "Framework Event Dispatcher: Equinox Container: 54b3a3f5-f34f-412c-99bc-4aac3c1948e0" daemon [_thread_blocked, id=1708, stack(0x000000daaea00000,0x000000daaeb00000)]
0x0000026b158b0000 JavaThread "Active Thread: Equinox Container: 54b3a3f5-f34f-412c-99bc-4aac3c1948e0" [_thread_blocked, id=2076, stack(0x000000daae900000,0x000000daaea00000)]
0x0000026b13262800 JavaThread "Service Thread" daemon [_thread_blocked, id=10828, stack(0x000000daae700000,0x000000daae800000)]
0x0000026b1318f800 JavaThread "C1 CompilerThread11" daemon [_thread_blocked, id=6720, stack(0x000000daae600000,0x000000daae700000)]
0x0000026b1318e800 JavaThread "C1 CompilerThread10" daemon [_thread_blocked, id=988, stack(0x000000daae500000,0x000000daae600000)]
0x0000026b1318e000 JavaThread "C1 CompilerThread9" daemon [_thread_blocked, id=10540, stack(0x000000daae400000,0x000000daae500000)]
0x0000026b1318d000 JavaThread "C1 CompilerThread8" daemon [_thread_blocked, id=10808, stack(0x000000daae300000,0x000000daae400000)]
0x0000026b1318a800 JavaThread "C2 CompilerThread7" daemon [_thread_blocked, id=10852, stack(0x000000daae200000,0x000000daae300000)]
0x0000026b13189000 JavaThread "C2 CompilerThread6" daemon [_thread_blocked, id=10856, stack(0x000000daae100000,0x000000daae200000)]
0x0000026b1318a000 JavaThread "C2 CompilerThread5" daemon [_thread_blocked, id=10824, stack(0x000000daae000000,0x000000daae100000)]
0x0000026b1318c000 JavaThread "C2 CompilerThread4" daemon [_thread_blocked, id=10820, stack(0x000000daadf00000,0x000000daae000000)]
0x0000026b1318b800 JavaThread "C2 CompilerThread3" daemon [_thread_blocked, id=10816, stack(0x000000daade00000,0x000000daadf00000)]
0x0000026b1317b800 JavaThread "C2 CompilerThread2" daemon [_thread_blocked, id=1164, stack(0x000000daadd00000,0x000000daade00000)]
0x0000026b1317a000 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=10812, stack(0x000000daadc00000,0x000000daadd00000)]
0x0000026b1312c800 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=1660, stack(0x000000daadb00000,0x000000daadc00000)]
0x0000026b1312c000 JavaThread "Attach Listener" daemon [_thread_blocked, id=6632, stack(0x000000daada00000,0x000000daadb00000)]
0x0000026b1312b000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=6628, stack(0x000000daad900000,0x000000daada00000)]
0x0000026b13108800 JavaThread "Finalizer" daemon [_thread_blocked, id=6636, stack(0x000000daad800000,0x000000daad900000)]
0x0000026b7e1d4000 JavaThread "Reference Handler" daemon [_thread_blocked, id=10860, stack(0x000000daad700000,0x000000daad800000)]
0x0000026b7c860800 JavaThread "main" [_thread_in_native, id=11128, stack(0x000000daac0d0000,0x000000daac1d0000)]
Other Threads:
0x0000026b130e4800 VMThread [stack: 0x000000daad600000,0x000000daad700000] [id=10836]
0x0000026b132af800 WatcherThread [stack: 0x000000daae800000,0x000000daae900000] [id=10544]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
PSYoungGen total 502784K, used 246463K [0x00000000d5580000, 0x00000000f8380000, 0x0000000100000000)
eden space 447488K, 45% used [0x00000000d5580000,0x00000000e1ada900,0x00000000f0a80000)
from space 55296K, 80% used [0x00000000f4d80000,0x00000000f78d5660,0x00000000f8380000)
to space 61952K, 0% used [0x00000000f0a80000,0x00000000f0a80000,0x00000000f4700000)
ParOldGen total 452608K, used 155415K [0x0000000080000000, 0x000000009ba00000, 0x00000000d5580000)
object space 452608K, 34% used [0x0000000080000000,0x00000000897c5cd0,0x000000009ba00000)
Metaspace used 126807K, capacity 143650K, committed 143768K, reserved 1173504K
class space used 15422K, capacity 19786K, committed 19888K, reserved 1048576K
Card table byte_map: [0x0000026b7cd20000,0x0000026b7d130000] byte_map_base: 0x0000026b7c920000
Marking Bits: (ParMarkBitMap*) 0x0000000068aed850
Begin Bits: [0x0000026b0f000000, 0x0000026b11000000)
End Bits: [0x0000026b11000000, 0x0000026b13000000)
Polling page: 0x0000026b7bab0000
CodeCache: size=245760Kb used=64946Kb max_used=65207Kb free=180813Kb
bounds [0x0000026b00000000, 0x0000026b04030000, 0x0000026b0f000000]
total_blobs=18036 nmethods=17052 adapters=886
compilation: enabled
Compilation events (10 events):
Event: 161.929 Thread 0x0000026b1318d000 nmethod 22112 0x0000026b00a1bd50 code [0x0000026b00a1c100, 0x0000026b00a1e2d0]
Event: 161.979 Thread 0x0000026b1318b800 nmethod 22114 0x0000026b04013dd0 code [0x0000026b040143c0, 0x0000026b040195f8]
Event: 162.936 Thread 0x0000026b1318f800 22115 3 java.lang.String::<init> (21 bytes)
Event: 162.937 Thread 0x0000026b1318f800 nmethod 22115 0x0000026b01495e10 code [0x0000026b01495f80, 0x0000026b01496158]
Event: 163.102 Thread 0x0000026b1318e800 22116 1 com.ti.ccstudio.ui.JavaHeapDetector::access$0 (5 bytes)
Event: 163.102 Thread 0x0000026b1318e800 nmethod 22116 0x0000026b03460e50 code [0x0000026b03460fa0, 0x0000026b03461098]
Event: 163.102 Thread 0x0000026b1318e000 22117 1 com.ti.ccstudio.ui.JavaHeapDetector::access$2 (5 bytes)
Event: 163.102 Thread 0x0000026b1318d000 22118 1 com.ti.ccstudio.ui.JavaHeapDetector::access$6 (5 bytes)
Event: 163.102 Thread 0x0000026b1318e000 nmethod 22117 0x0000026b035d19d0 code [0x0000026b035d1b20, 0x0000026b035d1c18]
Event: 163.103 Thread 0x0000026b1318d000 nmethod 22118 0x0000026b03df7250 code [0x0000026b03df73a0, 0x0000026b03df7498]
GC Heap History (10 events):
Event: 46.733 GC heap before
{Heap before GC invocations=22 (full 4):
PSYoungGen total 319488K, used 314762K [0x00000000d5580000, 0x00000000f1500000, 0x0000000100000000)
eden space 269824K, 98% used [0x00000000d5580000,0x00000000e5869d38,0x00000000e5d00000)
from space 49664K, 99% used [0x00000000e5d00000,0x00000000e8d78cf0,0x00000000e8d80000)
to space 60416K, 0% used [0x00000000eda00000,0x00000000eda00000,0x00000000f1500000)
ParOldGen total 452608K, used 103745K [0x0000000080000000, 0x000000009ba00000, 0x00000000d5580000)
object space 452608K, 22% used [0x0000000080000000,0x00000000865506b8,0x000000009ba00000)
Metaspace used 105868K, capacity 120934K, committed 121112K, reserved 1153024K
class space used 12693K, capacity 16576K, committed 16688K, reserved 1048576K
Event: 46.761 GC heap after
Heap after GC invocations=22 (full 4):
PSYoungGen total 384512K, used 27364K [0x00000000d5580000, 0x00000000f0c80000, 0x0000000100000000)
eden space 332800K, 0% used [0x00000000d5580000,0x00000000d5580000,0x00000000e9a80000)
from space 51712K, 52% used [0x00000000eda00000,0x00000000ef4b9308,0x00000000f0c80000)
to space 58368K, 0% used [0x00000000e9a80000,0x00000000e9a80000,0x00000000ed380000)
ParOldGen total 452608K, used 123956K [0x0000000080000000, 0x000000009ba00000, 0x00000000d5580000)
object space 452608K, 27% used [0x0000000080000000,0x000000008790d388,0x000000009ba00000)
Event: 52.402 GC heap before
{Heap before GC invocations=23 (full 4):
PSYoungGen total 384512K, used 360164K [0x00000000d5580000, 0x00000000f0c80000, 0x0000000100000000)
eden space 332800K, 100% used [0x00000000d5580000,0x00000000e9a80000,0x00000000e9a80000)
Metaspace used 106195K, capacity 121244K, committed 121368K, reserved 1155072K
class space used 12717K, capacity 16614K, committed 16688K, reserved 1048576K
Event: 52.410 GC heap after
Heap after GC invocations=23 (full 4):
PSYoungGen total 391168K, used 5865K [0x00000000d5580000, 0x00000000f5380000, 0x0000000100000000)
from space 58368K, 10% used [0x00000000e9a80000,0x00000000ea03a7e0,0x00000000ed380000)
to space 59904K, 0% used [0x00000000f1900000,0x00000000f1900000,0x00000000f5380000)
ParOldGen total 452608K, used 150044K [0x0000000080000000, 0x000000009ba00000, 0x00000000d5580000)
object space 452608K, 33% used [0x0000000080000000,0x0000000089287200,0x000000009ba00000)
Event: 55.292 GC heap before
{Heap before GC invocations=24 (full 4):
PSYoungGen total 391168K, used 338665K [0x00000000d5580000, 0x00000000f5380000, 0x0000000100000000)
Metaspace used 106249K, capacity 121254K, committed 121368K, reserved 1155072K
class space used 12718K, capacity 16615K, committed 16688K, reserved 1048576K
Event: 55.299 GC heap after
Heap after GC invocations=24 (full 4):
PSYoungGen total 449024K, used 4664K [0x00000000d5580000, 0x00000000f4e00000, 0x0000000100000000)
eden space 394752K, 0% used [0x00000000d5580000,0x00000000d5580000,0x00000000ed700000)
from space 54272K, 8% used [0x00000000f1900000,0x00000000f1d8e2b8,0x00000000f4e00000)
to space 60928K, 0% used [0x00000000ed700000,0x00000000ed700000,0x00000000f1280000)
ParOldGen total 452608K, used 155380K [0x0000000080000000, 0x000000009ba00000, 0x00000000d5580000)
object space 452608K, 34% used [0x0000000080000000,0x00000000897bd080,0x000000009ba00000)
Event: 71.978 GC heap before
{Heap before GC invocations=25 (full 4):
PSYoungGen total 449024K, used 399416K [0x00000000d5580000, 0x00000000f4e00000, 0x0000000100000000)
eden space 394752K, 100% used [0x00000000d5580000,0x00000000ed700000,0x00000000ed700000)
Metaspace used 107881K, capacity 123182K, committed 123416K, reserved 1155072K
class space used 12896K, capacity 16897K, committed 16944K, reserved 1048576K
Event: 71.984 GC heap after
Heap after GC invocations=25 (full 4):
PSYoungGen total 455680K, used 19951K [0x00000000d5580000, 0x00000000f8680000, 0x0000000100000000)
from space 60928K, 32% used [0x00000000ed700000,0x00000000eea7bfe0,0x00000000f1280000)
to space 58368K, 0% used [0x00000000f4d80000,0x00000000f4d80000,0x00000000f8680000)
ParOldGen total 452608K, used 155388K [0x0000000080000000, 0x000000009ba00000, 0x00000000d5580000)
object space 452608K, 34% used [0x0000000080000000,0x00000000897bf080,0x000000009ba00000)
Event: 158.424 GC heap before
{Heap before GC invocations=26 (full 4):
PSYoungGen total 455680K, used 414703K [0x00000000d5580000, 0x00000000f8680000, 0x0000000100000000)
Metaspace used 121732K, capacity 138016K, committed 138264K, reserved 1169408K
class space used 14694K, capacity 18884K, committed 18992K, reserved 1048576K
Event: 158.437 GC heap after
Heap after GC invocations=26 (full 4):
PSYoungGen total 502784K, used 44373K [0x00000000d5580000, 0x00000000f8380000, 0x0000000100000000)
eden space 447488K, 0% used [0x00000000d5580000,0x00000000d5580000,0x00000000f0a80000)
Deoptimization events (10 events):
Event: 160.139 Thread 0x0000026b174f1000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000026b0102895c method=java.util.LinkedHashMap.afterNodeInsertion(Z)V @ 18
Event: 160.381 Thread 0x0000026b1df76800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000026b0235ad80 method=com.ti.ccstudio.system.setup.SystemSetupReader$CpuIdentifier.compareTo(Lcom/ti/ccstudio/system/setup/SystemSetupReader$CpuIdentifier;)I @ 18
Event: 160.604 Thread 0x0000026b1df76800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000026b0277bd48 method=org.eclipse.osgi.internal.framework.FilterImpl.matches(Ljava/util/Map;)Z @ 177
Event: 160.889 Thread 0x0000026b7c860800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x0000026b00fb5a28 method=org.eclipse.swt.widgets.Control.windowProc(JIJJ)J @ 1623
Event: 160.893 Thread 0x0000026b7c860800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x0000026b00fb5a28 method=org.eclipse.swt.widgets.Control.windowProc(JIJJ)J @ 1623
Event: 161.624 Thread 0x0000026b1df76800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000026b03729260 method=java.io.WinNTFileSystem.prefixLength(Ljava/lang/String;)I @ 11
Event: 161.624 Thread 0x0000026b1df76800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000026b01437eac method=java.io.WinNTFileSystem.prefixLength(Ljava/lang/String;)I @ 11
Event: 161.688 Thread 0x0000026b1df76800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000026b034fbec8 method=java.math.BigInteger.bitLength()I @ 21
Event: 161.688 Thread 0x0000026b1df76800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000026b00ed7374 method=java.math.BigInteger.add([I[I)[I @ 116
Event: 162.931 Thread 0x0000026b1df7f800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000026b0258ecac method=java.lang.Thread.getContextClassLoader()Ljava/lang/ClassLoader; @ 4
Internal exceptions (10 events):
Event: 158.696 Thread 0x0000026b1e34c000 Implicit null exception at 0x0000026b021fa74b to 0x0000026b021faea5
Event: 158.752 Thread 0x0000026b1e34c000 Implicit null exception at 0x0000026b00907fe7 to 0x0000026b00908125
Event: 158.752 Thread 0x0000026b1e34c000 Implicit null exception at 0x0000026b01f25585 to 0x0000026b01f256b5
Event: 158.884 Thread 0x0000026b7c860800 Implicit null exception at 0x0000026b036715a5 to 0x0000026b0367202d
Event: 158.886 Thread 0x0000026b7c860800 Implicit null exception at 0x0000026b03567a04 to 0x0000026b03568871
Event: 158.888 Thread 0x0000026b7c860800 Implicit null exception at 0x0000026b006e16ab to 0x0000026b006e18e1
Event: 160.121 Thread 0x0000026b1e34c000 Exception <a 'java/io/FileNotFoundException'> (0x00000000da7303d0) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u144\9417\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 160.121 Thread 0x0000026b1e34c000 Exception <a 'java/io/FileNotFoundException'> (0x00000000da731890) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u144\9417\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 160.211 Thread 0x0000026b1df76800 Exception <a 'java/io/FileNotFoundException'> (0x00000000db37eaf0) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u144\9417\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 160.604 Thread 0x0000026b1df76800 Implicit null exception at 0x0000026b027795c3 to 0x0000026b0277bd15
Events (10 events):
Event: 162.937 Thread 0x0000026b1318f800 flushing nmethod 0x0000026b037cc6d0
Event: 162.937 Thread 0x0000026b1318f800 flushing nmethod 0x0000026b0381a290
Event: 162.937 Thread 0x0000026b1318f800 flushing nmethod 0x0000026b0382fbd0
Event: 162.950 Executing VM operation: RevokeBias
Event: 162.950 Executing VM operation: RevokeBias done
Event: 163.102 Thread 0x0000026b1318e800 flushing nmethod 0x0000026b0399a050
Event: 163.102 Thread 0x0000026b1318e800 flushing nmethod 0x0000026b039a66d0
Event: 163.103 Thread 0x0000026b1318e800 flushing nmethod 0x0000026b03a1a990
Event: 163.103 Thread 0x0000026b1318e800 flushing nmethod 0x0000026b03dfd810
Event: 163.103 Thread 0x0000026b1318e800 flushing nmethod 0x0000026b03dfe7d0
Dynamic libraries:
0x00007ff65b060000 - 0x00007ff65b0a4000 D:\ti\ccs1040\ccs\eclipse\ccstudio.exe
0x00007ff97ef70000 - 0x00007ff97f168000 C:\Windows\SYSTEM32\ntdll.dll
0x00007ff97e460000 - 0x00007ff97e51f000 C:\Windows\System32\KERNEL32.DLL
0x00007ff97c8a0000 - 0x00007ff97cb96000 C:\Windows\System32\KERNELBASE.dll
0x00007ff97e210000 - 0x00007ff97e3ad000 C:\Windows\System32\USER32.dll
0x00007ff97ccd0000 - 0x00007ff97ccf2000 C:\Windows\System32\win32u.dll
0x00007ff97d960000 - 0x00007ff97d98c000 C:\Windows\System32\GDI32.dll
0x00007ff97ceb0000 - 0x00007ff97cfc5000 C:\Windows\System32\gdi32full.dll
0x00007ff97c650000 - 0x00007ff97c6ed000 C:\Windows\System32\msvcp_win.dll
0x00007ff97cbd0000 - 0x00007ff97ccd0000 C:\Windows\System32\ucrtbase.dll
0x00007ff9569c0000 - 0x00007ff956c5a000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.1110_none_60b5254171f9507e\COMCTL32.dll
0x00007ff97da80000 - 0x00007ff97db1e000 C:\Windows\System32\msvcrt.dll
0x00007ff97cfd0000 - 0x00007ff97d000000 C:\Windows\System32\IMM32.DLL
0x00007ff931320000 - 0x00007ff931349000 D:\ti\ccs1040\ccs\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.1100.v20190907-0426\eclipse_1902.dll
0x00007ff97eb40000 - 0x00007ff97ebef000 C:\Windows\System32\ADVAPI32.dll
0x00007ff97e150000 - 0x00007ff97e1ec000 C:\Windows\System32\sechost.dll
0x00007ff97ec50000 - 0x00007ff97ed76000 C:\Windows\System32\RPCRT4.dll
0x00007ff9746e0000 - 0x00007ff9746ea000 C:\Windows\SYSTEM32\VERSION.dll
0x00007ff979800000 - 0x00007ff97989e000 C:\Windows\system32\uxtheme.dll
0x00007ff97dc50000 - 0x00007ff97dfa4000 C:\Windows\System32\combase.dll
0x00007ff97d0f0000 - 0x00007ff97d204000 C:\Windows\System32\MSCTF.dll
0x00007ff97db20000 - 0x00007ff97dbed000 C:\Windows\System32\OLEAUT32.dll
0x00007ff97ae90000 - 0x00007ff97aea2000 C:\Windows\SYSTEM32\kernel.appcore.dll
0x00007ff97cd00000 - 0x00007ff97cd82000 C:\Windows\System32\bcryptPrimitives.dll
0x00007ff95afa0000 - 0x00007ff95b099000 C:\Windows\SYSTEM32\textinputframework.dll
0x00007ff9794c0000 - 0x00007ff9795b2000 C:\Windows\System32\CoreMessaging.dll
0x00007ff97dfb0000 - 0x00007ff97e01b000 C:\Windows\System32\WS2_32.dll
0x00007ff978de0000 - 0x00007ff97913e000 C:\Windows\System32\CoreUIComponents.dll
0x00007ff97e030000 - 0x00007ff97e0dd000 C:\Windows\System32\SHCORE.dll
0x00007ff97b7e0000 - 0x00007ff97b813000 C:\Windows\SYSTEM32\ntmarta.dll
0x00007ff977e00000 - 0x00007ff977f54000 C:\Windows\SYSTEM32\wintypes.dll
0x00007ff97e520000 - 0x00007ff97e64a000 C:\Windows\System32\ole32.dll
0x00007ff97e3b0000 - 0x00007ff97e459000 C:\Windows\System32\clbcatq.dll
0x00000000682d0000 - 0x0000000068b6d000 D:\ti\ccs1040\ccs\eclipse\jre\bin\server\jvm.dll
0x00007ff95de90000 - 0x00007ff95deb7000 C:\Windows\SYSTEM32\WINMM.dll
0x00007ff97da70000 - 0x00007ff97da78000 C:\Windows\System32\PSAPI.DLL
0x00007ff95de80000 - 0x00007ff95de89000 C:\Windows\SYSTEM32\WSOCK32.dll
0x00000000681f0000 - 0x00000000682c2000 D:\ti\ccs1040\ccs\eclipse\jre\bin\MSVCR100.dll
0x00000000681e0000 - 0x00000000681ef000 D:\ti\ccs1040\ccs\eclipse\jre\bin\verify.dll
0x00000000681b0000 - 0x00000000681d9000 D:\ti\ccs1040\ccs\eclipse\jre\bin\java.dll
0x0000000068190000 - 0x00000000681a6000 D:\ti\ccs1040\ccs\eclipse\jre\bin\zip.dll
0x00007ff97d210000 - 0x00007ff97d954000 C:\Windows\System32\SHELL32.dll
0x00007ff97a6e0000 - 0x00007ff97ae74000 C:\Windows\SYSTEM32\windows.storage.dll
0x00007ff97c090000 - 0x00007ff97c0be000 C:\Windows\SYSTEM32\Wldp.dll
0x00007ff97e0e0000 - 0x00007ff97e135000 C:\Windows\System32\shlwapi.dll
0x00007ff97c580000 - 0x00007ff97c5a5000 C:\Windows\SYSTEM32\profapi.dll
0x00007ff97bfe0000 - 0x00007ff97bff8000 C:\Windows\SYSTEM32\CRYPTSP.dll
0x00007ff97b6a0000 - 0x00007ff97b6d4000 C:\Windows\system32\rsaenh.dll
0x00007ff97cba0000 - 0x00007ff97cbc7000 C:\Windows\System32\bcrypt.dll
0x00007ff97c500000 - 0x00007ff97c52e000 C:\Windows\SYSTEM32\USERENV.dll
0x00007ff97c000000 - 0x00007ff97c00c000 C:\Windows\SYSTEM32\CRYPTBASE.dll
0x0000000068170000 - 0x000000006818a000 D:\ti\ccs1040\ccs\eclipse\jre\bin\net.dll
0x00007ff97bdf0000 - 0x00007ff97be5a000 C:\Windows\system32\mswsock.dll
0x00007ff97ba90000 - 0x00007ff97bacc000 C:\Windows\SYSTEM32\IPHLPAPI.DLL
0x00007ff97e140000 - 0x00007ff97e148000 C:\Windows\System32\NSI.dll
0x00007ff9773a0000 - 0x00007ff9773b7000 C:\Windows\SYSTEM32\dhcpcsvc6.DLL
0x00007ff977180000 - 0x00007ff97719d000 C:\Windows\SYSTEM32\dhcpcsvc.DLL
0x00007ff97bae0000 - 0x00007ff97bbaa000 C:\Windows\SYSTEM32\DNSAPI.dll
0x0000000068150000 - 0x0000000068161000 D:\ti\ccs1040\ccs\eclipse\jre\bin\nio.dll
0x00007ff93ed60000 - 0x00007ff93edf6000 D:\ti\ccs1040\ccs\eclipse\configuration\org.eclipse.osgi\478\0\.cp\swt-win32-4930r7.dll
0x00007ff97d990000 - 0x00007ff97da6a000 C:\Windows\System32\COMDLG32.dll
0x00007ff97c6f0000 - 0x00007ff97c84e000 C:\Windows\System32\CRYPT32.dll
0x00007ff952b40000 - 0x00007ff953016000 C:\Windows\SYSTEM32\WININET.dll
0x00007ff93ed40000 - 0x00007ff93ed59000 C:\Windows\SYSTEM32\USP10.dll
0x00007ff9547e0000 - 0x00007ff95487d000 C:\Windows\SYSTEM32\WINSPOOL.DRV
0x00007ff977520000 - 0x00007ff977616000 C:\Windows\SYSTEM32\PROPSYS.dll
0x00007ff969500000 - 0x00007ff9696ec000 C:\Windows\SYSTEM32\urlmon.dll
0x00007ff969160000 - 0x00007ff969411000 C:\Windows\SYSTEM32\iertutil.dll
0x00007ff969420000 - 0x00007ff969449000 C:\Windows\SYSTEM32\srvcli.dll
0x00007ff97bad0000 - 0x00007ff97badc000 C:\Windows\SYSTEM32\netutils.dll
0x00007ff957180000 - 0x00007ff957187000 C:\Windows\SYSTEM32\MSIMG32.dll
0x00007ff94a920000 - 0x00007ff94aa9e000 C:\Windows\System32\TaskFlowDataEngine.dll
0x00007ff951230000 - 0x00007ff9516fb000 C:\Windows\System32\cdp.dll
0x00007ff97c850000 - 0x00007ff97c89e000 C:\Windows\System32\cfgmgr32.dll
0x00007ff97ba70000 - 0x00007ff97ba82000 C:\Windows\System32\UMPDC.dll
0x00007ff9778c0000 - 0x00007ff977a0d000 C:\Windows\System32\dsreg.dll
0x00007ff97b730000 - 0x00007ff97b7ba000 C:\Windows\System32\msvcp110_win.dll
0x00007ff956ee0000 - 0x00007ff956f5f000 C:\Windows\System32\OneCoreCommonProxyStub.dll
0x00007ff93ed00000 - 0x00007ff93ed26000 D:\ti\ccs1040\ccs\eclipse\configuration\org.eclipse.osgi\478\0\.cp\swt-gdip-win32-4930r7.dll
0x00007ff956810000 - 0x00007ff9569b5000 C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.2251_none_91a40448cc8846c1\gdiplus.dll
0x00007ff976ce0000 - 0x00007ff976e94000 C:\Windows\SYSTEM32\WindowsCodecs.dll
0x00007ff96df10000 - 0x00007ff96dfbc000 C:\Windows\SYSTEM32\TextShaping.dll
0x00007ff957110000 - 0x00007ff957176000 C:\Windows\SYSTEM32\oleacc.dll
0x00007ff953580000 - 0x00007ff9535c2000 C:\Windows\system32\mlang.dll
0x0000000180000000 - 0x0000000180012000 D:\ti\ccs1040\ccs\eclipse\configuration\org.eclipse.osgi\281\0\.cp\os\win32\x86_64\localfile_1_0_0.dll
0x00007ff911860000 - 0x00007ff91187b000 D:\ti\ccs1040\ccs\eclipse\configuration\org.eclipse.osgi\286\0\.cp\os\win32\x86_64\win32refresh.dll
0x00007ff956660000 - 0x00007ff956677000 C:\Windows\system32\napinsp.dll
0x00007ff950340000 - 0x00007ff95035b000 C:\Windows\system32\pnrpnsp.dll
0x00007ff950320000 - 0x00007ff950335000 C:\Windows\system32\wshbth.dll
0x00007ff977c00000 - 0x00007ff977c1d000 C:\Windows\system32\NLAapi.dll
0x00007ff950300000 - 0x00007ff950312000 C:\Windows\System32\winrnr.dll
0x00007ff976600000 - 0x00007ff97660a000 C:\Windows\System32\rasadhlp.dll
0x00007ff976170000 - 0x00007ff9761f2000 C:\Windows\System32\fwpuclnt.dll
0x00007ff911800000 - 0x00007ff911811000 D:\ti\ccs1040\ccs\eclipse\configuration\org.eclipse.osgi\284\0\.cp\jWinHttp-1.0.0.dll
0x00007ff977af0000 - 0x00007ff977bfa000 C:\Windows\SYSTEM32\WINHTTP.dll
0x00007ff94c5e0000 - 0x00007ff94c61e000 C:\Windows\system32\dataexchange.dll
0x00007ff977f60000 - 0x00007ff9781c3000 C:\Windows\system32\d3d11.dll
0x00007ff978bf0000 - 0x00007ff978dd3000 C:\Windows\system32\dcomp.dll
0x00007ff97af00000 - 0x00007ff97aff3000 C:\Windows\system32\dxgi.dll
0x00007ff9767c0000 - 0x00007ff9769c7000 C:\Windows\system32\twinapi.appcore.dll
0x00007ff94c3c0000 - 0x00007ff94c5e0000 C:\Windows\system32\explorerframe.dll
0x00007ff959d50000 - 0x00007ff959fcf000 C:\Windows\SYSTEM32\DWrite.dll
0x00007ff9531f0000 - 0x00007ff9531fa000 D:\ti\ccs1040\ccs\ccs_base\DebugServer\bin\LibraryLoader.dll
0x00007ff93fc60000 - 0x00007ff93fcee000 C:\Windows\SYSTEM32\MSVCP140.dll
0x00007ff96e120000 - 0x00007ff96e12c000 C:\Windows\SYSTEM32\VCRUNTIME140_1.dll
0x00007ff9751b0000 - 0x00007ff9751cb000 C:\Windows\SYSTEM32\VCRUNTIME140.dll
0x00007ff9112d0000 - 0x00007ff911308000 D:\ti\ccs1040\ccs\ccs_base\common\bin\ti_logger.dll
0x00007ff911880000 - 0x00007ff911892000 D:\ti\ccs1040\ccs\ccs_base\common\bin\CCReg.dll
0x00007ff911200000 - 0x00007ff9112d0000 D:\ti\ccs1040\ccs\ccs_base\common\bin\fsutil.dll
0x00007ff911160000 - 0x00007ff9111fb000 D:\ti\ccs1040\ccs\ccs_base\common\bin\libusb-1.0.dll
0x00007ff911130000 - 0x00007ff91115e000 D:\ti\ccs1040\ccs\ccs_base\common\bin\MiniDump.dll
0x00007ff910f30000 - 0x00007ff911122000 D:\ti\ccs1040\ccs\ccs_base\common\bin\setup_parser.dll
0x00007ff910c00000 - 0x00007ff910f27000 D:\ti\ccs1040\ccs\ccs_base\common\bin\xerces-c_2_8.dll
0x0000026b1fc00000 - 0x0000026b1fc16000 D:\ti\ccs1040\ccs\ccs_base\common\bin\ti_targetdb_parser.dll
0x00007ff910ba0000 - 0x00007ff910bf8000 D:\ti\ccs1040\ccs\ccs_base\DebugServer\bin\ti_xpcom.dll
0x00007ff910b80000 - 0x00007ff910b96000 D:\ti\ccs1040\ccs\ccs_base\DebugServer\bin\DirectoryService.dll
0x00007ff910b40000 - 0x00007ff910b74000 D:\ti\ccs1040\ccs\ccs_base\DebugServer\bin\XPCOMUtility.dll
0x00007ff94c080000 - 0x00007ff94c0a4000 C:\Windows\SYSTEM32\edputil.dll
0x00007ff93d140000 - 0x00007ff93d14f000 C:\Users\dell\AppData\Local\Temp\proxy_vole6078420122033082100.dll
0x0000000068120000 - 0x0000000068144000 D:\ti\ccs1040\ccs\eclipse\jre\bin\sunec.dll
0x0000000068110000 - 0x000000006811d000 D:\ti\ccs1040\ccs\eclipse\jre\bin\management.dll
0x00007ff90eac0000 - 0x00007ff90eae4000 D:\ti\ccs1040\ccs\ccs_base\emulation\analysis\bin\cToolsIF.dll
0x00007ff90ef40000 - 0x00007ff90f028000 D:\ti\ccs1040\ccs\ccs_base\emulation\analysis\bin\ctools.dll
0x00007ff90f190000 - 0x00007ff90f1ca000 D:\ti\ccs1040\ccs\ccs_base\emulation\analysis\bin\TraceFactory.dll
0x00007ff90e1e0000 - 0x00007ff90eabc000 D:\ti\ccs1040\ccs\ccs_base\DebugServer\bin\DebugServer.dll
0x00007ff90ee50000 - 0x00007ff90ef34000 D:\ti\ccs1040\ccs\ccs_base\DebugServer\bin\tiofr11.dll
0x00007ff90e150000 - 0x00007ff90e1dd000 D:\ti\ccs1040\ccs\ccs_base\DebugServer\bin\CollectorServer.dll
0x00007ff90f140000 - 0x00007ff90f183000 D:\ti\ccs1040\ccs\ccs_base\DebugServer\bin\DatasetServer.dll
VM Arguments:
jvm_args: -Dosgi.instance.area.default=@user.home/workspace_v10 -Djxbrowser.ipc.external=true -Dorg.eclipse.equinox.http.jetty.customizer.class=com.ti.ccstudio.gui.composer.http.jetty.MaqettaJettyCustomizer -Dccs.minXDCVersion=3.25.5.1 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=30000 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.closeTimeout=10000 -Dsun.net.client.defaultReadTimeout=30000 -Dsun.net.client.defaultConnectTimeout=10000 -Xms256m -Xmx2048m -XX:ErrorFile=C:\Users\dell\AppData\Local\Texas Instruments\CCS\ccs1040\0\dmp\\hs_err_%p.log
java_command: <unknown>
java_class_path (initial): D:\ti\ccs1040\ccs\eclipse\\plugins/org.eclipse.equinox.launcher_1.5.600.v20191014-2022.jar
Launcher Type: generic
Environment Variables:
PATH=D:\ti\ccs1040\ccs\ccs_base\emulation\analysis\bin\..\..\..\common\bin;D:\ti\ccs1040\ccs\ccs_base\emulation\analysis\bin\..\..\..\DebugServer\bin;D:\ti\ccs1040\ccs\ccs_base\emulation\analysis\bin\ofs;D:\ti\ccs1040\ccs\ccs_base\common\bin;D:\ti\ccs1040\ccs\ccs_base\common\uscif;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\MATLAB\R2022b\runtime\win64;C:\Program Files\MATLAB\R2022b\bin;C:\Program Files (x86)\Altium Designer Summer 09\System;D:\Microchip\xc32\v4.10\bin;C:\Users\dell\AppData\Local\Microsoft\WindowsApps;;D:\ti\ccs1040\ccs\ccs_base\emulation\analysis\bin\.;D:\ti\ccs1040\ccs\ccs_base\emulation\analysis\bin\../xmldb/aet_config;D:\ti\ccs1040\ccs\ccs_base\emulation\analysis\bin\../xmldb/trace_config/setup;D:\ti\ccs1040\ccs\ccs_base\emulation\analysis\bin\../xmldb/trace_config/devices;D:\ti\ccs1040\ccs\ccs_base\emulation\analysis\bin\../../../common/bin;D:\ti\ccs1040\ccs\ccs_base\emulation\analysis\bin\../../../common/uscif;D:\ti\ccs1040\ccs\ccs_base\emulation\analysis\bin\../../tpi;D:\ti\ccs1040\ccs\ccs_base\emulation\drivers
USERNAME=dell
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 151 Stepping 2, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 10.0 , 64 bit Build 19041 (10.0.19041.3155)
CPU:total 20 (initial active 20) (10 cores per cpu, 2 threads per core) family 6 model 151 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, erms, 3dnowpref, lzcnt, ht, tsc, tscinvbit, bmi1, bmi2, adx
Memory: 4k page, physical 16458476k(9670512k free), swap 25371372k(17454704k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (25.144-b01) for windows-amd64 JRE (1.8.0_144-b01), built on Jul 21 2017 21:57:33 by "java_re" with MS VC++ 10.0 (VS2010)
time: Wed Aug 16 18:19:48 2023
elapsed time: 163 seconds (0d 0h 2m 43s)
