TMS320F28335: 将定点类型的FFT改为浮点FFT
Part Number: TMS320F28335
Other Parts Discussed in Thread: C2000WARE, CONTROLSUITE
目的:在CCS9.2编译环境中,将定点类型的FFT(定点类型的用的是CCS3.3)改为浮点类型的FFT
操作办法:添加rts2800_fpu32.lib并在Specify floating point support(--float_support)选fpu32;
现象:报了好多error #16008-D: file "C:/Users/xinyu/Desktop/FFT/DSP-FreqChange_208_ok/Lib/rts2800_fpu32.lib<errno.obj>" specifies ISA revision "C28FPU32", which is not compatible with ISA revision "C2700" specified in a previous file or on the command line
请问这样的情况改怎么解决啊
x 出现错误。请重试或与管理员联系。
