TMS320F2800157: C2000系列芯片如何使用MD5 库计算MD5
Part Number: TMS320F2800157
C2000 系列芯片一个地址为16个bit,而系统提供的MD5算法库中,输入的数据的类型为unsigned char 类型,如果用提供的接口md5_process进行MD5计算时,将数据组合成u32类型的时候,数据组合会出现错误,是否有其他的算法库可以支持C2000系列芯片计算MD5
 *  RFC 1321 compliant MD5 implementation
 *  Based on XySSL: Copyright (C) 2006-2008  Christophe Devine
 *  Copyright (C) 2009  Paul Bakker <polarssl_maintainer at polarssl dot org>
 *  All rights reserved.
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    * Redistributions of source code must retain the above copyright
 *      notice, this list of conditions and the following disclaimer.
 *    * Redistributions in binary form must reproduce the above copyright
 *      notice, this list of conditions and the following disclaimer in the
 *      documentation and/or other materials provided with the distribution.
 *    * Neither the names of PolarSSL or XySSL nor the names of its contributors
 *      may be used to endorse or promote products derived from this software
 *      without specific prior written permission.
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
 *  FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED
 *  TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
 *  PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
 *  LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
 *  NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
 *  SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  The MD5 algorithm was designed by Ron Rivest in 1991.
 *  http://www.ietf.org/rfc/rfc1321.txt
#include "netif/ppp/ppp_opts.h"
#if PPP_SUPPORT && LWIP_INCLUDED_POLARSSL_MD5
#include "netif/ppp/polarssl/md5.h"
#include <string.h>
 * 32-bit integer manipulation macros (little endian)
#ifndef GET_ULONG_LE
#define GET_ULONG_LE(n,b,i)                             \
    (n) = ( (unsigned long) (b)[(i)    ]       )        \
        | ( (unsigned long) (b)[(i) + 1] <<  8 )        \
        | ( (unsigned long) (b)[(i) + 2] << 16 )        \
        | ( (unsigned long) (b)[(i) + 3] << 24 );       \
#endif
#ifndef PUT_ULONG_LE
#define PUT_ULONG_LE(n,b,i)                             \
    (b)[(i)    ] = (unsigned char) ( (n)       );       \
    (b)[(i) + 1] = (unsigned char) ( (n) >>  8 );       \
    (b)[(i) + 2] = (unsigned char) ( (n) >> 16 );       \
    (b)[(i) + 3] = (unsigned char) ( (n) >> 24 );       \
#endif
 * MD5 context setup
void md5_starts( md5_context *ctx )
    ctx->total[0] = 0;
    ctx->total[1] = 0;
    ctx->state[0] = 0x67452301;
    ctx->state[1] = 0xEFCDAB89;
    ctx->state[2] = 0x98BADCFE;
    ctx->state[3] = 0x10325476;
static void md5_process( md5_context *ctx, const unsigned char data[64] )
    unsigned long X[16], A, B, C, D;
    GET_ULONG_LE( X[ 0], data,  0 );
    GET_ULONG_LE( X[ 1], data,  4 );
    GET_ULONG_LE( X[ 2], data,  8 );
    GET_ULONG_LE( X[ 3], data, 12 );
    GET_ULONG_LE( X[ 4], data, 16 );
    GET_ULONG_LE( X[ 5], data, 20 );
    GET_ULONG_LE( X[ 6], data, 24 );
    GET_ULONG_LE( X[ 7], data, 28 );
    GET_ULONG_LE( X[ 8], data, 32 );
    GET_ULONG_LE( X[ 9], data, 36 );
    GET_ULONG_LE( X[10], data, 40 );
    GET_ULONG_LE( X[11], data, 44 );
    GET_ULONG_LE( X[12], data, 48 );
    GET_ULONG_LE( X[13], data, 52 );
    GET_ULONG_LE( X[14], data, 56 );
    GET_ULONG_LE( X[15], data, 60 );
#define S(x,n) ((x << n) | ((x & 0xFFFFFFFF) >> (32 - n)))
#define P(a,b,c,d,k,s,t)                                \
    a += F(b,c,d) + X[k] + t; a = S(a,s) + b;           \
    A = ctx->state[0];
    B = ctx->state[1];
    C = ctx->state[2];
    D = ctx->state[3];
#define F(x,y,z) (z ^ (x & (y ^ z)))
    P( A, B, C, D,  0,  7, 0xD76AA478 );
    P( D, A, B, C,  1, 12, 0xE8C7B756 );
    P( C, D, A, B,  2, 17, 0x242070DB );
    P( B, C, D, A,  3, 22, 0xC1BDCEEE );
    P( A, B, C, D,  4,  7, 0xF57C0FAF );
    P( D, A, B, C,  5, 12, 0x4787C62A );
    P( C, D, A, B,  6, 17, 0xA8304613 );
    P( B, C, D, A,  7, 22, 0xFD469501 );
    P( A, B, C, D,  8,  7, 0x698098D8 );
    P( D, A, B, C,  9, 12, 0x8B44F7AF );
    P( C, D, A, B, 10, 17, 0xFFFF5BB1 );
    P( B, C, D, A, 11, 22, 0x895CD7BE );
    P( A, B, C, D, 12,  7, 0x6B901122 );
    P( D, A, B, C, 13, 12, 0xFD987193 );
    P( C, D, A, B, 14, 17, 0xA679438E );
    P( B, C, D, A, 15, 22, 0x49B40821 );
#undef F
#define F(x,y,z) (y ^ (z & (x ^ y)))
    P( A, B, C, D,  1,  5, 0xF61E2562 );
    P( D, A, B, C,  6,  9, 0xC040B340 );
    P( C, D, A, B, 11, 14, 0x265E5A51 );
    P( B, C, D, A,  0, 20, 0xE9B6C7AA );
    P( A, B, C, D,  5,  5, 0xD62F105D );
    P( D, A, B, C, 10,  9, 0x02441453 );
    P( C, D, A, B, 15, 14, 0xD8A1E681 );
    P( B, C, D, A,  4, 20, 0xE7D3FBC8 );
    P( A, B, C, D,  9,  5, 0x21E1CDE6 );
    P( D, A, B, C, 14,  9, 0xC33707D6 );
    P( C, D, A, B,  3, 14, 0xF4D50D87 );
    P( B, C, D, A,  8, 20, 0x455A14ED );
    P( A, B, C, D, 13,  5, 0xA9E3E905 );
    P( D, A, B, C,  2,  9, 0xFCEFA3F8 );
    P( C, D, A, B,  7, 14, 0x676F02D9 );
    P( B, C, D, A, 12, 20, 0x8D2A4C8A );
#undef F
#define F(x,y,z) (x ^ y ^ z)
    P( A, B, C, D,  5,  4, 0xFFFA3942 );
    P( D, A, B, C,  8, 11, 0x8771F681 );
    P( C, D, A, B, 11, 16, 0x6D9D6122 );
    P( B, C, D, A, 14, 23, 0xFDE5380C );
    P( A, B, C, D,  1,  4, 0xA4BEEA44 );
    P( D, A, B, C,  4, 11, 0x4BDECFA9 );
    P( C, D, A, B,  7, 16, 0xF6BB4B60 );
    P( B, C, D, A, 10, 23, 0xBEBFBC70 );
    P( A, B, C, D, 13,  4, 0x289B7EC6 );
    P( D, A, B, C,  0, 11, 0xEAA127FA );
    P( C, D, A, B,  3, 16, 0xD4EF3085 );
    P( B, C, D, A,  6, 23, 0x04881D05 );
    P( A, B, C, D,  9,  4, 0xD9D4D039 );
    P( D, A, B, C, 12, 11, 0xE6DB99E5 );
    P( C, D, A, B, 15, 16, 0x1FA27CF8 );
    P( B, C, D, A,  2, 23, 0xC4AC5665 );
#undef F
#define F(x,y,z) (y ^ (x | ~z))
    P( A, B, C, D,  0,  6, 0xF4292244 );
    P( D, A, B, C,  7, 10, 0x432AFF97 );
    P( C, D, A, B, 14, 15, 0xAB9423A7 );
    P( B, C, D, A,  5, 21, 0xFC93A039 );
    P( A, B, C, D, 12,  6, 0x655B59C3 );
    P( D, A, B, C,  3, 10, 0x8F0CCC92 );
    P( C, D, A, B, 10, 15, 0xFFEFF47D );
    P( B, C, D, A,  1, 21, 0x85845DD1 );
    P( A, B, C, D,  8,  6, 0x6FA87E4F );
    P( D, A, B, C, 15, 10, 0xFE2CE6E0 );
    P( C, D, A, B,  6, 15, 0xA3014314 );
    P( B, C, D, A, 13, 21, 0x4E0811A1 );
    P( A, B, C, D,  4,  6, 0xF7537E82 );
    P( D, A, B, C, 11, 10, 0xBD3AF235 );
    P( C, D, A, B,  2, 15, 0x2AD7D2BB );
    P( B, C, D, A,  9, 21, 0xEB86D391 );
#undef F
    ctx->state[0] += A;
    ctx->state[1] += B;
    ctx->state[2] += C;
    ctx->state[3] += D;
 * MD5 process buffer
void md5_update( md5_context *ctx, const unsigned char *input, int ilen )
    int fill;
    unsigned long left;
    if( ilen <= 0 )
        return;
    left = ctx->total[0] & 0x3F;
    fill = 64 - left;
    ctx->total[0] += ilen;
    ctx->total[0] &= 0xFFFFFFFF;
    if( ctx->total[0] < (unsigned long) ilen )
        ctx->total[1]++;
    if( left && ilen >= fill )
        MEMCPY( (void *) (ctx->buffer + left),
                input, fill );
        md5_process( ctx, ctx->buffer );
        input += fill;
        ilen  -= fill;
        left = 0;
    while( ilen >= 64 )
        md5_process( ctx, input );
        input += 64;
        ilen  -= 64;
    if( ilen > 0 )
                input, ilen );
static const unsigned char md5_padding[64] =
 0x80, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
 * MD5 final digest
void md5_finish( md5_context *ctx, unsigned char output[16] )
    unsigned long last, padn;
    unsigned long high, low;
    unsigned char msglen[8];
    high = ( ctx->total[0] >> 29 )
         | ( ctx->total[1] <<  3 );
    low  = ( ctx->total[0] <<  3 );
    PUT_ULONG_LE( low,  msglen, 0 );
    PUT_ULONG_LE( high, msglen, 4 );
    last = ctx->total[0] & 0x3F;
    padn = ( last < 56 ) ? ( 56 - last ) : ( 120 - last );
    md5_update( ctx, md5_padding, padn );
    md5_update( ctx, msglen, 8 );
    PUT_ULONG_LE( ctx->state[0], output,  0 );
    PUT_ULONG_LE( ctx->state[1], output,  4 );
    PUT_ULONG_LE( ctx->state[2], output,  8 );
    PUT_ULONG_LE( ctx->state[3], output, 12 );
 * output = MD5( input buffer )
void md5( unsigned char *input, int ilen, unsigned char output[16] )
    md5_context ctx;
    md5_starts( &ctx );
    md5_update( &ctx, input, ilen );
    md5_finish( &ctx, output );
#endif /* PPP_SUPPORT && LWIP_INCLUDED_POLARSSL_MD5 */
