你好,用CCS12.0.0版本软件 芯片28335,想直接用CCS生成 .bin文件,
通过该指令"${CCS_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/ofd2000" "${CG_TOOL_ROOT}/bin/hex2000" "${CCS_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin"
报错如下:
D:/ti/ccs1200/ccs/utils/tiobj2bin/mkhex4bin failure occurred. Giving up.
Encode/Config.pm did not return a true value at C:/Perl/lib/Encode.pm line 52.
Compilation failed in require at C:/Perl/lib/Archive/Zip/Archive.pm line 21.
BEGIN failed--compilation aborted at C:/Perl/lib/Archive/Zip/Archive.pm line 24.
Compilation failed in require at C:/Perl/lib/Archive/Zip.pm line 251.
Compilation failed in require at -e line 153.
debug文件中并没有bin文件,如何解决呢?
