在调整相位的过程中有点问题,
EPwm1Regs.CMPA.half.CMPA = 835;
EPwm1Regs.CMPB = 745;
EPwm1Regs.TBPRD = 1580;
EPwm2Regs.CMPA.half.CMPA = 835;
EPwm2Regs.CMPB = 745;
EPwm2Regs.TBPRD = 1580;
EPwm2Regs.TBPHS.half.TBPHS = 0;
现象是:
1.逐步增加相位差(即EPwm2Regs.TBPHS.half.TBPHS逐渐增大,每次加1,最大不超过周期EPwm1Regs.TBPRD = 1580),一切正常。
2.但是,再向下减相位时(即EPwm2Regs.TBPHS.half.TBPHS逐渐减少,每次减1,减到0为止),在两个点有问题,EPwm2Regs.TBPHS.half.TBPHS = 835时(刚好是CMPA 的值),再向下减1(即EPwm2Regs.TBPHS.half.TBPHS = 834,有嗒的一声),在EPwm2Regs.TBPHS.half.TBPHS = 745时(刚好是CMPB 值),再向下减1(即EPwm2Regs.TBPHS.half.TBPHS = 744,有嗒的一声),请问这是什么原因,应该不是巧合,是不是那个地方配置还有问题,求解?
初始化代码如下:
void InitEPwm1(void)
// Enable TZ1 and TZ2 as one shot trip sources
EALLOW;
EPwm1Regs.TZSEL.bit.OSHT1 = 1;
EPwm1Regs.TZSEL.bit.OSHT2 = 1;
// What do we want the TZ1 and TZ2 to do?
EPwm1Regs.TZCTL.bit.TZA = TZ_FORCE_HI;
EPwm1Regs.TZCTL.bit.TZB = TZ_FORCE_HI;
// Enable TZ interrupt
//EPwm1Regs.TZEINT.bit.OST = 1;
EDIS;
// Setup TBCLK
EPwm1Regs.TBPRD =EPWM1_TIMER_TBPRD; //600; // Set timer period 801 TBCLKs
EPwm1Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0
EPwm1Regs.TBCTR = 0x0000; // Clear counter
//EPwm1Regs.TBCTL.bit.PRDLD = 0;
// Set Compare values
EPwm1Regs.CMPA.half.CMPA = EPWM1_MIN_CMPA;//324;//; // Set compare A value
EPwm1Regs.CMPB = EPWM1_MIN_CMPB;//276;//; // Set Compare B value
// Setup counter mode
EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up
//EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading
EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;//0x0-1分频,TBCLK = SYSCLKOUT / (HSPCLKDIV × CLKDIV)
EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Master module
EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO; // Sync down-stream module
// Setup shadowing
EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // Load on Zero
EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
#if 1
// Action Qualifier SubModule Registers
//EPwm1Regs.AQCTLA.bit.CAU = AQ_SET;//AQ_CLEAR;
//EPwm1Regs.AQCTLA.bit.CAD = AQ_CLEAR;//AQ_SET;
EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR;//AQ_CLEAR;
EPwm1Regs.AQCTLA.bit.CAD = AQ_SET;//AQ_SET;
EPwm1Regs.AQCTLB.bit.CBU = AQ_SET;
EPwm1Regs.AQCTLB.bit.CBD = AQ_CLEAR;
#endif
#if 1
// Interrupt where we will change the Compare Values
EPwm1Regs.ETSEL.bit.INTSEL = ET_CTRU_CMPB;//ET_CTR_ZERO; // Select INT on Zero event
mPWM1_Disable(); // Disable INT ,close pwm disable,open pwm enable
EPwm1Regs.ETPS.bit.INTPRD = ET_2ND; // Generate INT on 3rd event
#endif
#if 1
EALLOW;
// TZA events can force EPWMxA
// TZB events can force EPWMxB
#if 1
EPwm1Regs.TZCTL.bit.TZA = TZ_FORCE_HI; // EPWM1A will go low //故障产生时的保护
EPwm1Regs.TZCTL.bit.TZB = TZ_FORCE_HI; // EPWM1B will go low
#endif
EPwm1Regs.TZFRC.bit.OST = 1; // Turn off the PWM
EDIS;
#endif
void InitEPwm2(void)
#if 1
EALLOW;
EPwm2Regs.TZSEL.bit.OSHT1 = 1;
EPwm2Regs.TZSEL.bit.OSHT2 = 1;
EPwm2Regs.TZCTL.bit.TZA = TZ_FORCE_HI;
EPwm2Regs.TZCTL.bit.TZB = TZ_FORCE_HI;
//EPwm2Regs.TZEINT.bit.OST = 1;
EDIS;
#endif
// Setup TBCLK
EPwm2Regs.TBPRD =EPWM2_TIMER_TBPRD; //600; // Set timer period 801 TBCLKs
EPwm2Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0
EPwm2Regs.TBCTR = 0x0000; // Clear counter
//EPwm2Regs.TBCTL.bit.PRDLD = 0;
EPwm2Regs.CMPA.half.CMPA = EPWM2_MIN_CMPA;//324;//; // Set compare A value
EPwm2Regs.CMPB = EPWM2_MIN_CMPB;//276;//; // Set Compare B value
EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up
//EPwm2Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading
EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1;//0x0-1分频,TBCLK = SYSCLKOUT / (HSPCLKDIV × CLKDIV)
EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Slave module
EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // sync flow-through
// Setup shadowing
EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // Load on Zero
EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
#if 1
EPwm2Regs.AQCTLA.bit.CAU = AQ_CLEAR;//AQ_CLEAR;
EPwm2Regs.AQCTLA.bit.CAD = AQ_SET;//AQ_SET;
EPwm2Regs.AQCTLB.bit.CBU = AQ_SET;
EPwm2Regs.AQCTLB.bit.CBD = AQ_CLEAR;
#endif
#if 1
EPwm2Regs.ETSEL.bit.INTSEL = ET_CTRU_CMPB;//ET_CTR_ZERO; // Select INT on Zero event
mPWM2_Disable(); // Disable INT ,close pwm disable,open pwm enable
EPwm2Regs.ETPS.bit.INTPRD = ET_2ND; // Generate INT on 3rd event
#endif
#if 1
EALLOW;
#if 1
EPwm2Regs.TZCTL.bit.TZA = TZ_FORCE_HI;//硬件反向了 // EPWM1A will go low //故障产生时的保护
EPwm2Regs.TZCTL.bit.TZB = TZ_FORCE_HI; // EPWM1B will go low
#endif
EPwm2Regs.TZFRC.bit.OST = 1; // Turn off the PWM
EDIS;
#endif
