其中项目是从CCS3.3中导入到CCS6.0中的,器件型号为28335,调试器是XDS100USB
使用CCS6.0进行调试时打开软件后第一次在线调试可以成功,退出调试模式后重新编译后再次“Debug”是会提示:C28xx: Flash Programmer: Warning: The configured device (TMS320F28335), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: GEL Output:
ADC Calibration not complete, check if device is unlocked and recalibrate.C28xx: GEL Output:
ADC Calibration not complete, check if device is unlocked and recalibrate.C28xx: File Loader: Data verification failed at address 0x00000000 Please verify target memory and memory map.
C28xx: GEL: File: E:\shan\Study\DSP\ZQ28335_CODE\ZQ28335_examples\Ex14_ZQ28335_KEY_LED\Debug\ZQ28335_KEY_LED.out: a data verification error occurred, file load failed.
C28xx: Error connecting to the target: (Error -1156 @ 0x800) Device may be operating in low-power mode. Do you want to bring it out of this mode? (Emulation package 5.1.507.0)
