/* * main.c * * Created on: 2023年9月14日 * Author: CHENJIE */ #include "RFFT.h" #include "epwm.h" #include "DSP2833x_Device.h" #include "DSP2833x_Examples.h" #include "adc.h" #include "epwm.h" #include "stdio.h" #include "uart.h" #include "dma.h" #include "leds.h" __interrupt void adc_isr(void); __interrupt void ocal_DINTCH1_ISR(void); float freq; Uint16 array_index; Uint16 check_flag; Uint16 LoopCount; Uint16 ConversionCount; //#pragma DATA_SECTION(DMABuf1,"DMARAML4"); //#define DMA_BUF_SIZE 60 //volatile Uint16 DMABuf1[DMA_BUF_SIZE]; #pragma DATA_SECTION(Voltage1, "DMARAML4"); Uint16 Voltage1[2048]; volatile Uint16 *DMADest; volatile Uint16 *DMASource; void main() { check_flag=0; // // Step 1. Initialize System Control: // PLL, WatchDog, enable Peripheral Clocks // This example function is found in the DSP2833x_SysCtrl.c file. // InitSysCtrl(); // MemCopy(&RamfuncsLoadStart,&RamfuncsLoadEnd,&RamfuncsRunStart); // InitFlash(); EALLOW; #if (CPU_FRQ_150MHZ) // Default - 150 MHz SYSCLKOUT // // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 150/(2*3) = 25.0 MHz // #define ADC_MODCLK 0x3 #endif #if (CPU_FRQ_100MHZ) // // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 100/(2*2) = 25.0 MHz // #define ADC_MODCLK 0x2 #endif EDIS; // // Define ADCCLK clock frequency ( less than or equal to 25 MHz ) // Assuming InitSysCtrl() has set SYSCLKOUT to 150 MHz // EALLOW; SysCtrlRegs.HISPCP.all = ADC_MODCLK; EDIS; // // Step 2. Initialize GPIO: // This example function is found in the DSP2833x_Gpio.c file and // illustrates how to set the GPIO to it's default state. // // InitGpio(); // Skipped for this example // // Step 3. Clear all interrupts and initialize PIE vector table: // Disable CPU interrupts // DINT; // // Initialize the PIE control registers to their default state. // The default state is all PIE interrupts disabled and flags // are cleared. // This function is found in the DSP2833x_PieCtrl.c file. // InitPieCtrl(); // // Disable CPU interrupts and clear all CPU interrupt flags: // IER = 0x0000; IFR = 0x0000; // // Initialize the PIE vector table with pointers to the shell Interrupt // Service Routines (ISR). // This will populate the entire table, even if the interrupt // is not used in this example. This is useful for debug purposes. // The shell ISR routines are found in DSP2833x_DefaultIsr.c. // This function is found in DSP2833x_PieVect.c. // InitPieVectTable(); // // Interrupts that are used in this example are re-mapped to // ISR functions found within this file. // // EALLOW; // This is needed to write to EALLOW protected register // PieVectTable.ADCINT = &adc_isr; // EDIS; // This is needed to disable write to EALLOW protected registers EALLOW; // Allow access to EALLOW protected registers PieVectTable.DINTCH1= &local_DINTCH1_ISR; EDIS; // Disable access to EALLOW protected registers PieCtrlRegs.PIEIER1.bit.INTx1 = 1; IER |= M_INT7; // Enable CPU Interrupt 1 // // Step 4. Initialize all the Device Peripherals: // This function is found in DSP2833x_InitPeripherals.c // // InitPeripherals(); // Not required for this example InitAdc(); // For this example, init the ADC // // Step 5. User specific code, enable interrupts: // // // Enable ADCINT in PIE // // PieCtrlRegs.PIEIER1.bit.INTx6 = 1; // IER |= M_INT1; // Enable CPU Interrupt 1 EINT; // Enable Global interrupt INTM //ERTM; // Enable Global realtime interrupt DBGM LoopCount = 0; ConversionCount = 0; // // Configure ADC // AdcRegs.ADCTRL1.bit.ACQ_PS = 0Xf; AdcRegs.ADCTRL3.bit.ADCCLKPS = 0x0; //不对高速时钟分频 AdcRegs.ADCTRL1.bit.CONT_RUN = 0; // Setup continuous run AdcRegs.ADCMAXCONV.all = 0x0000; // Setup 2 conv's on SEQ1 AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x0; // Setup ADCINA3 as 1st SEQ1 conv. // // Enable SOCA from ePWM to start SEQ1 // AdcRegs.ADCTRL2.bit.EPWM_SOCA_SEQ1 = 1; AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1 = 1; // Enable SEQ1 interrupt (every EOS) // // Assumes ePWM1 clock is already enabled in InitSysCtrl(); // EPwm1Regs.ETSEL.bit.SOCAEN = 1; // Enable SOC on A group EPwm1Regs.ETSEL.bit.SOCASEL = 4; // Select SOC from from CPMA on upcount EPwm1Regs.ETPS.bit.SOCAPRD = 1; // Generate pulse on 1st event EPwm1Regs.CMPA.half.CMPA = 20; // Set compare A value EPwm1Regs.TBPRD = 75-1; // Set period for ePWM1 EPwm1Regs.TBCTL.bit.CTRMODE = 0; // count up and start EALLOW; SysCtrlRegs.PCLKCR3.bit.DMAENCLK = 1; // DMA Clock EDIS; // Initialize DMA DMAInitialize(); // Configure DMA Channel DMADest=&Voltage1[0]; DMASource=&AdcMirror.ADCRESULT0; DMACH1AddrConfig(DMADest,DMASource); DMACH1BurstConfig(31,0,2); // // so need to increment by 2 to grab the correct location // DMACH1TransferConfig(31,0,2); DMACH1WrapConfig(0xFFFF,0,0xFFFF,0); //Use timer0 to start the x-fer. //Since this is a static copy use one shot mode, so only one trigger is needed //Also using 32-bit mode to decrease x-fer time DMACH1ModeConfig(DMA_SEQ1INT,PERINT_ENABLE,ONESHOT_DISABLE,CONT_ENABLE,SYNC_DISABLE, SYNC_DST,OVRFLOW_DISABLE,THIRTYTWO_BIT,CHINT_END,CHINT_ENABLE); StartDMACH1(); // // Wait for ADC interrupt // for(;;) { if(check_flag==1) { RFFT_ADC_Init(Voltage1); RFFT_ADC_Caculate(); EPwm1Regs.ETSEL.bit.SOCAEN = 1; StartDMACH1(); check_flag=0; } } } // // adc_isr - // __interrupt void local_DINTCH1_ISR(void) { // // EALLOW; // SysCtrlRegs.PCLKCR3.bit.DMAENCLK = 0; // DMA Clock // EDIS; // Voltage1[ConversionCount] = AdcRegs.ADCRESULT0 >>4; // // // // // If 40 conversions have been logged, start over // // // if(ConversionCount > 2048) // { // // ConversionCount = 0; // EPwm1Regs.ETSEL.bit.SOCAEN = 0; // Enable SOC on A group // check_flag=1; // // } // else // { // ConversionCount++; // } // // // // // Reinitialize for next ADC sequence // // EPwm1Regs.ETSEL.bit.SOCAEN = 0; // Enable SOC on A group AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1; // Reset SEQ1 AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1; // Clear INT SEQ1 bit PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; // Acknowledge interrupt to PIE // // return; check_flag=1; PieCtrlRegs.PIEACK.bit.ACK7 = 1; }
使用epwm触发adc采样,dma传输时数据异常
