program will not fit into available memory.
program will not fit into available memory.  placement with alignment/blocking fails for section ".text" size 0x95c page 0.  Available memory ranges: 28027_RAM_lnk.cmd /Example_2802xAdcSoc line 114 C/C++ Problem
图1 是RAM CMD配置文件,
图2 是debug 编译后的map图
请问,从map图中看.txt 占用的孔见是0x6dd,而我给。txt分配的空间是0x900,为什么还说空间不足呢?谢谢解惑!
