C28xx: Flash Programmer: Warning: The configured device (TMS320F28335), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: GEL Output:
ADC Calibration not complete, check if device is unlocked and recalibrate.C28xx: GEL Output:
ADC Calibration not complete, check if device is unlocked and recalibrate.C28xx: Breakpoint Manager: Retrying with a AET breakpoint
C28xx: Trouble Setting Breakpoint with the Action "Finish Auto Run" at 0x9453: (Error -1066 @ 0x9453) Unable to set/clear requested breakpoint. Verify that the breakpoint address is in valid memory. (Emulation package 5.1.641.0)
各位大神,请教一下,我在win7 64位系统下使用ccs5.3 debug出现这样的错误,但我用芯片的确是F28335,另外他提示device被锁,我这块板子在另一个电脑上使用ccs3.3进行烧写都没有问题,一直不知道是什么原因,仿真器是xds100v1
