Other Parts Discussed in Thread: TMDSHVMTRINSPIN
请问一下,TMDSHVMTRINSPIN — High Voltage Motor Control Kit with InstaSPIN-FOC enabled Piccolo MCU这个套件可以接高压和仿真器一起调试吗?另外,这个高压驱动器适用于 InstaSPIN Projects and Labs User’s Guide中的demo程序吗?谢谢!
Can the TMDSHVMTRINSPIN — High Voltage Motor Control Kit with InstaSPIN-FOC enabled Piccolo MCU be debugged together with the high voltage and simulator? Also, does this high-voltage driver work with the demo program in the InstaSPIN Projects and Labs User's Guide? Thank you!
