I created a program for the 28377 in version 9.0, and it can run in the CCS 9. However, when I open this program in CCS 20 for programming, the following error occurs: C:\Users\Admin\AppData\Local\Texas Instruments\CCS\CCS\0\theia\workspaces\Untitled-873.theia-workspace.theia\launch.json' (EntryNotFound (FileSystemError): Error: ENOENT: no such file or directory, open 'c:\Users\Admin\AppData\Local\Texas Instruments\CCS\CCS\0\theia\workspaces\Untitled-873.theia-workspace.theia\launch.json')
Hi,
Thank you for your interest in TI products! In order to solve your problem more effectively, I need some more time to look at this chip, which will be answered for you later.
你好,
打开目标配置需要执行哪些步骤?似乎您没有指定 launch.json。
您能否看一下以下内容: https://software-dl.ti.com/ccs/esd/documents/users_guide/ccs_debug-main.html
