支持RM46L852的RTOS有哪些?我从哪里可以获得移植相关的教程。
Other Parts Discussed in Thread: RM46L852, HALCOGEN
请问一下支持RM46L852 HDK的RTOS有哪些?我从哪里可以获得移植相关的教程。
  • 谢谢,非常有帮助
  • 谢谢楼上回答!
    您可以使用WHIS-3P-MCURTOS,这个是第三方公司WITTENSTEIN提供的。WITTENSTEIN 的产品支持 TI 的 Hercules™ Arm® Cortex®-R MCU,适用于功能安全(RM48x、TMS570 和 TMS470M)、C2000™ 32 位微控制器和 Arm Cortex-M3 Concerto 系列。
    如需了解有关 WITTENSTEIN high integrity systems 的更多信息,请访问:www.highintegritysystems.com/safertos。
  • 对于FreeRTOS更多例子,你可以先安装安全控制器的开发工具HALCoGen
    在目录Hercules\HALCoGen\v04.07.01\examples\RM46x
    中,提供了2个实例演示。
    example_freeRTOSBlinky
    example_freeRTOSRestrictedTask
    /** @example example_freeRTOSBlinky.c
    *  This is an example which descibes the steps to create an example application which
    *  toggles the High End Timer (HET) pin 17 (LED in USB & HDK) based on the FreeRTOS timer tick of one second.
    *  @b Step @b 1:
    *  Create a new project.
    *  Navigate: -> File -> New -> Project
    *  @image html example_createProject.jpg "Figure: Create a new Project"
    *  @b Step @b 2:
    *  Configure driver code generation:
    *  - Enable GIO driver
    *  - Disable others
    *  Navigate: -> TMS570LSxx /RM4 -> Driver Enable
    *  @image html example_freeRTOSBlinky_enableDrivers_TMS570LS3x-RMx.jpg "Figure: Driver Configuration"
    *  @b Step @b 3:
    *  Configure Interrupt handling:
    *  - Enable SVC
    *  - Enter FreeRTOS SVC handler name 'vPortSWI'
    *  Navigate: -> TMS570LSxx /RM4 -> Interrupts
    *  @image html example_freeRTOSBlinky_interrupts.jpg "Figure: Interrupt Configuration"
    *  @b Step @b 4:
    *  Configure VIM RAM:
    *  - Enter FreeRTOS Timer Tick handler name 'vPortPreemptiveTick' at offset 0x0000000C
    *  - Enter SSI handler name 'vPortYeildWithinAPI ' at offset 0x00000058
    *  Navigate: -> TMS570LSxx /RM4 -> VIM RAM
    *  @image html example_freeRTOSBlinky_VimRam.jpg "Figure: VIM RAM Configuration"
    *  @b Step @b 5:
    *  Configure Vectored Interrupt Module Channels:
    *  - Enable VIM Channel 2
    *  - Map VIM Channel 2 to IRQ
    *  - Enable VIM Channel 21
    *  - Map VIM Channel 21 to IRQ
    *  Navigate: -> TMS570LSxx /RM4 -> VIM Channel 0-31
    *  @image html example_freeRTOSBlinky_vimChannelView.jpg "Figure: VIM Channel Configuration"
    *  @b Step @b 6:
    *  Configure OS timer tick to 1 ms:
    *  - Enter Tick Rate of 1000
    *  Navigate: -> OS -> General
    *  @image html example_freeRTOSBlinky_osGeneral.jpg "Figure: OS General Configuration"
    *  @b Step @b 7:
    *  Generate code
    *  Navigate: -> File -> Generate Code
    *  @image html example_freeRTOS_generateCode.jpg "Figure: Generate Code"
    *  @b Step @b 8:
    *  Copy source code below into your application.
    *  The example file example_freeRTOSBlinky.c can also be found in the examples folder: ../HALCoGen/examples
    *  @note HALCoGen generates an enpty main function in sys_main.c,
    *        please make sure that you link in the right main function or copy the source into the user code sections of this file.
    *  @note Enable GCC extension in the CCS project (Project properties -> Build -> ARM Compiler -> Advanced options -> Language options -> Enable support for GCC extensions)
    * Copyright (C) 2009-2015 Texas Instruments Incorporated - www.ti.com
    *  Redistribution and use in source and binary forms, with or without
    *  modification, are permitted provided that the following conditions
    *  are met:
    *    Redistributions of source code must retain the above copyright
    *    notice, this list of conditions and the following disclaimer.
    *    Redistributions in binary form must reproduce the above copyright
    *    notice, this list of conditions and the following disclaimer in the
    *    documentation and/or other materials provided with the
    *    distribution.
    *    Neither the name of Texas Instruments Incorporated nor the names of
    *    its contributors may be used to endorse or promote products derived
    *    from this software without specific prior written permission.
    *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES INCLUDING, BUT NOT
    *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION HOWEVER CAUSED AND ON ANY
    *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    *  INCLUDING NEGLIGENCE OR OTHERWISE ARISING IN ANY WAY OUT OF THE USE
    *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    /* USER CODE BEGIN (0) */
    /* USER CODE END */
    /* Include Files */
    #include "sys_common.h"
    #include "system.h"
    /* USER CODE BEGIN (1) */
    /* Include FreeRTOS scheduler files */
    #include "FreeRTOS.h"
    #include "os_task.h"
    /* Include HET header file - types, definitions and function declarations for system driver */
    #include "het.h"
    #include "gio.h"
    /* Define Task Handles */
    xTaskHandle xTask1Handle;
    /* Task1 */
    void vTask1(void *pvParameters)
        for(;;)
            /* Taggle HET[1] with timer tick */
            gioSetBit(hetPORT1, 17, gioGetBit(hetPORT1, 17) ^ 1);
            vTaskDelay(100);
    /* USER CODE END */
    /** @fn void main(void)
    *   @brief Application main function
    /* USER CODE BEGIN (2) */
    /* USER CODE END */
    void main(void)
    /* USER CODE BEGIN (3) */
        /* Set high end timer GIO port hetPort pin direction to all output */
        gioSetDirection(hetPORT1, 0xFFFFFFFF);
        /* Create Task 1 */
        if (xTaskCreate(vTask1,"Task1", configMINIMAL_STACK_SIZE, NULL, 1, &xTask1Handle) != pdTRUE)
            /* Task could not be created */
            while(1);
        /* Start Scheduler */
        vTaskStartScheduler();
        /* Run forever */
        while(1);
    /* USER CODE END */
    /* USER CODE BEGIN (4) */
    /* USER CODE END */
  • 是的,我发现了halcogen的妙处,省去了移植的麻烦,直接会生成相应的工程,谢谢你呀,非常感谢!
