板卡: MSP432P401R
因为 从设备需求,需要将MSP432 SPI 输出 clk的空闲电平为高电平, CS 空闲电平为高电平, MOSI 空闲电平为高电平, MISO空闲电平为低电平。
但我现在可以配置clk的空闲电平为高电平, CS 空闲电平为高电平。 但 MOSI 和 MISO一直为低电平。
请问该如何配置MOSI的空闲电平为高电平?? 我的SPI初始化配置如下所示:
void SR_SPI_Init(void){
volatile uint32_t delay;
EUSCI_A3->CTLW0 = 0x0001; // hold the eUSCI module in reset mode
EUSCI_A3->CTLW0 = 0x6D83;
EUSCI_A3->BRW = 10000; //8 -- 1500kHz
EUSCI_A3->MCTLW = 0;
P9->SEL0 |= 0xF0;
P9->SEL1 &= ~0xF0; // configure P9.7, P9.6, P9.5, and P9.4 as primary module function
EUSCI_A3->CTLW0 &= ~0x0001; // enable eUSCI module
EUSCI_A3->IE &= ~0x0003; // disable interrupts
SPI所有可配置的项可以查看库函数。
/* * ------------------------------------------- * MSP432 DriverLib - v3_21_00_05 * ------------------------------------------- * * --COPYRIGHT--,BSD,BSD * Copyright (c) 2016, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * --/COPYRIGHT--*/ #ifndef SPI_H_ #define SPI_H_ //***************************************************************************** // //! \addtogroup spi_api //! @{ // //***************************************************************************** //***************************************************************************** // // If building with a C++ compiler, make all of the definitions in this header // have a C binding. // //***************************************************************************** #ifdef __cplusplus extern "C" { #endif #include <stdbool.h> #include <stdint.h> #include <msp.h> #include "eusci.h" /* Configuration Defines */ #define EUSCI_SPI_CLOCKSOURCE_ACLK EUSCI_B_CTLW0_SSEL__ACLK #define EUSCI_SPI_CLOCKSOURCE_SMCLK EUSCI_B_CTLW0_SSEL__SMCLK #define EUSCI_SPI_MSB_FIRST EUSCI_B_CTLW0_MSB #define EUSCI_SPI_LSB_FIRST 0x00 #define EUSCI_SPI_BUSY EUSCI_A_STATW_BUSY #define EUSCI_SPI_NOT_BUSY 0x00 #define EUSCI_SPI_PHASE_DATA_CHANGED_ONFIRST_CAPTURED_ON_NEXT 0x00 #define EUSCI_SPI_PHASE_DATA_CAPTURED_ONFIRST_CHANGED_ON_NEXT EUSCI_B_CTLW0_CKPH #define EUSCI_SPI_3PIN EUSCI_B_CTLW0_MODE_0 #define EUSCI_SPI_4PIN_UCxSTE_ACTIVE_HIGH EUSCI_B_CTLW0_MODE_1 #define EUSCI_SPI_4PIN_UCxSTE_ACTIVE_LOW EUSCI_B_CTLW0_MODE_2 #define EUSCI_SPI_CLOCKPOLARITY_INACTIVITY_HIGH EUSCI_B_CTLW0_CKPL #define EUSCI_SPI_CLOCKPOLARITY_INACTIVITY_LOW 0x00 #define EUSCI_SPI_TRANSMIT_INTERRUPT EUSCI_B__TXIE #define EUSCI_SPI_RECEIVE_INTERRUPT EUSCI_B__RXIE #define EUSCI_SPI_ENABLE_SIGNAL_FOR_4WIRE_SLAVE EUSCI_B_CTLW0_STEM #define EUSCI_SPI_PREVENT_CONFLICTS_WITH_OTHER_MASTERS 0x00 //***************************************************************************** // //! ypedef eUSCI_SPI_MasterConfig //! \brief Type definition for \link _eUSCI_SPI_MasterConfig \endlink structure //! //! \struct _eUSCI_SPI_MasterConfig //! \brief Configuration structure for master mode in the \b SPI module. See //! \link SPI_initMaster \endlink for parameter documentation. // //***************************************************************************** typedef struct _eUSCI_SPI_MasterConfig { uint_fast8_t selectClockSource; uint32_t clockSourceFrequency; uint32_t desiredSpiClock; uint_fast16_t msbFirst; uint_fast16_t clockPhase; uint_fast16_t clockPolarity; uint_fast16_t spiMode; } eUSCI_SPI_MasterConfig; //***************************************************************************** // //! ypedef eUSCI_SPI_SlaveConfig //! \brief Type definition for \link _eUSCI_SPI_SlaveConfig \endlink structure //! //! \struct _eUSCI_SPI_SlaveConfig //! \brief Configuration structure for slave mode in the \b SPI module. See //! \link SPI_initSlave \endlink for parameter documentation. // //***************************************************************************** typedef struct _eUSCI_SPI_SlaveConfig { uint_fast16_t msbFirst; uint_fast16_t clockPhase; uint_fast16_t clockPolarity; uint_fast16_t spiMode; } eUSCI_SPI_SlaveConfig; //***************************************************************************** // //! Initializes the SPI Master block. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! \param config Configuration structure for SPI master mode //! //! <hr> //! <b>Configuration options for \link eUSCI_SPI_MasterConfig \endlink structure.</b> //! <hr> //! //! \param selectClockSource selects clock source. Valid values are //! - \b EUSCI_SPI_CLOCKSOURCE_ACLK //! - \b EUSCI_SPI_CLOCKSOURCE_SMCLK //! \param clockSourceFrequency is the frequency of the selected clock source //! \param desiredSpiClock is the desired clock rate for SPI communication //! \param msbFirst controls the direction of the receive and transmit shift //! register. Valid values are //! - \b EUSCI_SPI_MSB_FIRST //! - \b EUSCI_SPI_LSB_FIRST [Default Value] //! \param clockPhase is clock phase select. //! Valid values are //! - \b EUSCI_SPI_PHASE_DATA_CHANGED_ONFIRST_CAPTURED_ON_NEXT //! [Default Value] //! - \b EUSCI_SPI_PHASE_DATA_CAPTURED_ONFIRST_CHANGED_ON_NEXT //! \param clockPolarity is clock polarity select. //! Valid values are //! - \b EUSCI_SPI_CLOCKPOLARITY_INACTIVITY_HIGH //! - \b EUSCI_SPI_CLOCKPOLARITY_INACTIVITY_LOW [Default Value] //! \param spiMode is SPI mode select. //! Valid values are //! - \b EUSCI_SPI_3PIN [Default Value] //! - \b EUSCI_SPI_4PIN_UCxSTE_ACTIVE_HIGH //! - \b EUSCI_SPI_4PIN_UCxSTE_ACTIVE_LOW //! Upon successful initialization of the SPI master block, this function //! will have set the bus speed for the master, but the SPI Master block //! still remains disabled and must be enabled with SPI_enableModule() //! //! Modified bits are \b UCCKPH, \b UCCKPL, \b UC7BIT, \b UCMSB,\b UCSSELx, //! \b UCSWRST bits of \b UCAxCTLW0 register //! //! \return true // //***************************************************************************** extern bool SPI_initMaster(uint32_t moduleInstance, const eUSCI_SPI_MasterConfig *config); //***************************************************************************** // //! Selects 4Pin Functionality //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! \param select4PinFunctionality selects Clock source. Valid values are //! - \b EUSCI_SPI_PREVENT_CONFLICTS_WITH_OTHER_MASTERS //! - \b EUSCI_SPI_ENABLE_SIGNAL_FOR_4WIRE_SLAVE //! This function should be invoked only in 4-wire mode. Invoking this function //! has no effect in 3-wire mode. //! //! Modified bits are \b UCSTEM bit of \b UCAxCTLW0 register //! //! \return true // //***************************************************************************** extern void SPI_selectFourPinFunctionality(uint32_t moduleInstance, uint_fast8_t select4PinFunctionality); //***************************************************************************** // //! Initializes the SPI Master clock.At the end of this function call, SPI //! module is left enabled. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! \param clockSourceFrequency is the frequency of the selected clock source //! \param desiredSpiClock is the desired clock rate for SPI communication. //! //! Modified bits are \b UCSWRST bit of \b UCAxCTLW0 register and //! \b UCAxBRW register //! //! \return None // //***************************************************************************** extern void SPI_changeMasterClock(uint32_t moduleInstance, uint32_t clockSourceFrequency, uint32_t desiredSpiClock); //***************************************************************************** // //! Initializes the SPI Slave block. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! \param config Configuration structure for SPI slave mode //! //! <hr> //! <b>Configuration options for \link eUSCI_SPI_SlaveConfig \endlink structure.</b> //! <hr> //! //! \param msbFirst controls the direction of the receive and transmit shift //! register. Valid values are //! - \b EUSCI_SPI_MSB_FIRST //! - \b EUSCI_SPI_LSB_FIRST [Default Value] //! \param clockPhase is clock phase select. //! Valid values are //! - \b EUSCI_SPI_PHASE_DATA_CHANGED_ONFIRST_CAPTURED_ON_NEXT //! [Default Value] //! - \b EUSCI_SPI_PHASE_DATA_CAPTURED_ONFIRST_CHANGED_ON_NEXT //! \param clockPolarity is clock polarity select. //! Valid values are //! - \b EUSCI_SPI_CLOCKPOLARITY_INACTIVITY_HIGH //! - \b EUSCI_SPI_CLOCKPOLARITY_INACTIVITY_LOW [Default Value] //! \param spiMode is SPI mode select. //! Valid values are //! - \b EUSCI_SPI_3PIN [Default Value] //! - \b EUSCI_SPI_4PIN_UCxSTE_ACTIVE_HIGH //! - \b EUSCI_SPI_4PIN_UCxSTE_ACTIVE_LOW //! Upon successful initialization of the SPI slave block, this function //! will have initialized the slave block, but the SPI Slave block //! still remains disabled and must be enabled with SPI_enableModule() //! //! Modified bits are \b UCMSB, \b UC7BIT, \b UCMST, \b UCCKPL, \b UCCKPH, //! \b UCMODE, \b UCSWRST bits of \b UCAxCTLW0 //! //! \return true //***************************************************************************** extern bool SPI_initSlave(uint32_t moduleInstance, const eUSCI_SPI_SlaveConfig *config); //***************************************************************************** // //! Changes the SPI clock phase and polarity.At the end of this function call, //! SPI module is left enabled. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! \param clockPhase is clock phase select. //! Valid values are: //! - \b EUSCI_SPI_PHASE_DATA_CHANGED_ONFIRST_CAPTURED_ON_NEXT //! [Default Value] //! - \b EUSCI_SPI_PHASE_DATA_CAPTURED_ONFIRST_CHANGED_ON_NEXT //! \param clockPolarity is clock polarity select. //! Valid values are: //! - \b EUSCI_SPI_CLOCKPOLARITY_INACTIVITY_HIGH //! - \b EUSCI_SPI_CLOCKPOLARITY_INACTIVITY_LOW [Default Value] //! //! Modified bits are \b UCSWRST, \b UCCKPH, \b UCCKPL, \b UCSWRST bits of //! \b UCAxCTLW0 //! //! \return None // //***************************************************************************** extern void SPI_changeClockPhasePolarity(uint32_t moduleInstance, uint_fast16_t clockPhase, uint_fast16_t clockPolarity); //***************************************************************************** // //! Transmits a byte from the SPI Module. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! \param transmitData data to be transmitted from the SPI module //! //! This function will place the supplied data into SPI transmit data register //! to start transmission //! //! Modified register is \b UCAxTXBUF //! //! \return None. // //***************************************************************************** extern void SPI_transmitData(uint32_t moduleInstance, uint_fast8_t transmitData); //***************************************************************************** // //! Receives a byte that has been sent to the SPI Module. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! //! This function reads a byte of data from the SPI receive data Register. //! //! \return Returns the byte received from by the SPI module, cast as an //! uint8_t. // //***************************************************************************** extern uint8_t SPI_receiveData(uint32_t moduleInstance); //***************************************************************************** // //! Enables the SPI block. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! //! This will enable operation of the SPI block. //! Modified bits are \b UCSWRST bit of \b UCAxCTLW0 register. //! //! \return None. // //***************************************************************************** extern void SPI_enableModule(uint32_t moduleInstance); //***************************************************************************** // //! Disables the SPI block. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! //! This will disable operation of the SPI block. //! //! Modified bits are \b UCSWRST bit of \b UCAxCTLW0 register. //! //! \return None. // //***************************************************************************** extern void SPI_disableModule(uint32_t moduleInstance); //***************************************************************************** // //! Returns the address of the RX Buffer of the SPI for the DMA module. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! //! Returns the address of the SPI RX Buffer. This can be used in conjunction //! with the DMA to store the received data directly to memory. //! //! \return NONE // //***************************************************************************** extern uint32_t SPI_getReceiveBufferAddressForDMA(uint32_t moduleInstance); //***************************************************************************** // //! Returns the address of the TX Buffer of the SPI for the DMA module. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! //! Returns the address of the SPI TX Buffer. This can be used in conjunction //! with the DMA to obtain transmitted data directly from memory. //! //! \return NONE // //***************************************************************************** extern uint32_t SPI_getTransmitBufferAddressForDMA(uint32_t moduleInstance); //***************************************************************************** // //! Indicates whether or not the SPI bus is busy. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! //! This function returns an indication of whether or not the SPI bus is //! busy.This function checks the status of the bus via UCBBUSY bit //! //! \return EUSCI_SPI_BUSY if the SPI module transmitting or receiving //! is busy; otherwise, returns EUSCI_SPI_NOT_BUSY. // //***************************************************************************** extern uint_fast8_t SPI_isBusy(uint32_t moduleInstance); //***************************************************************************** // //! Enables individual SPI interrupt sources. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! \param mask is the bit mask of the interrupt sources to be enabled. //! //! Enables the indicated SPI interrupt sources. Only the sources that //! are enabled can be reflected to the processor interrupt; disabled sources //! have no effect on the processor. //! //! The mask parameter is the logical OR of any of the following: //! - \b EUSCI_SPI_RECEIVE_INTERRUPT Receive interrupt //! - \b EUSCI_SPI_TRANSMIT_INTERRUPT Transmit interrupt //! //! Modified registers are \b UCAxIFG and \b UCAxIE //! //! \return None. // //***************************************************************************** extern void SPI_enableInterrupt(uint32_t moduleInstance, uint_fast8_t mask); //***************************************************************************** // //! Disables individual SPI interrupt sources. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! \param mask is the bit mask of the interrupt sources to be //! disabled. //! //! Disables the indicated SPI interrupt sources. Only the sources that //! are enabled can be reflected to the processor interrupt; disabled sources //! have no effect on the processor. //! //! The mask parameter is the logical OR of any of the following: //! - \b EUSCI_SPI_RECEIVE_INTERRUPT Receive interrupt //! - \b EUSCI_SPI_TRANSMIT_INTERRUPT Transmit interrupt //! //! Modified register is \b UCAxIE //! //! \return None. // //***************************************************************************** extern void SPI_disableInterrupt(uint32_t moduleInstance, uint_fast8_t mask); //***************************************************************************** // //! Gets the current SPI interrupt status. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! \param mask Mask of interrupt to filter. This can include: //! - \b EUSCI_SPI_RECEIVE_INTERRUPT -Receive interrupt //! - \b EUSCI_SPI_TRANSMIT_INTERRUPT - Transmit interrupt //! //! Modified registers are \b UCAxIFG. //! //! \return The current interrupt status as the mask of the set flags //! Mask parameter can be either any of the following selection: //! - \b EUSCI_SPI_RECEIVE_INTERRUPT -Receive interrupt //! - \b EUSCI_SPI_TRANSMIT_INTERRUPT - Transmit interrupt // //***************************************************************************** extern uint_fast8_t SPI_getInterruptStatus(uint32_t moduleInstance, uint16_t mask); //***************************************************************************** // //! Gets the current SPI interrupt status masked with the enabled interrupts. //! This function is useful to call in ISRs to get a list of pending //! interrupts that are actually enabled and could have caused //! the ISR. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! Modified registers are \b UCAxIFG. //! //! \return The current interrupt status as the mask of the set flags //! Mask parameter can be either any of the following selection: //! - \b EUSCI_SPI_RECEIVE_INTERRUPT -Receive interrupt //! - \b EUSCI_SPI_TRANSMIT_INTERRUPT - Transmit interrupt // //***************************************************************************** extern uint_fast8_t SPI_getEnabledInterruptStatus(uint32_t moduleInstance); //***************************************************************************** // //! Clears the selected SPI interrupt status flag. //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! \param mask is the masked interrupt flag to be cleared. //! //! The mask parameter is the logical OR of any of the following: //! - \b EUSCI_SPI_RECEIVE_INTERRUPT -Receive interrupt //! - \b EUSCI_SPI_TRANSMIT_INTERRUPT - Transmit interrupt //! Modified registers are \b UCAxIFG. //! //! \return None // //***************************************************************************** extern void SPI_clearInterruptFlag(uint32_t moduleInstance, uint_fast8_t mask); //***************************************************************************** // //! Registers an interrupt handler for the timer capture compare interrupt. //! //! \param moduleInstance is the instance of the eUSCI (SPI) module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! It is important to note that for eUSCI modules, only "B" modules such as //! EUSCI_B0 can be used. "A" modules such as EUSCI_A0 do not support the //! I2C mode. //! //! \param intHandler is a pointer to the function to be called when the //! timer capture compare interrupt occurs. //! //! This function registers the handler to be called when a timer //! interrupt occurs. This function enables the global interrupt in the //! interrupt controller; specific SPI interrupts must be enabled //! via SPI_enableInterrupt(). It is the interrupt handler's responsibility to //! clear the interrupt source via SPI_clearInterruptFlag(). //! //! \return None. // //***************************************************************************** extern void SPI_registerInterrupt(uint32_t moduleInstance, void (*intHandler)(void)); //***************************************************************************** // //! Unregisters the interrupt handler for the timer //! //! \param moduleInstance is the instance of the eUSCI A/B module. Valid //! parameters vary from part to part, but can include: //! - \b EUSCI_A0_BASE //! - \b EUSCI_A1_BASE //! - \b EUSCI_A2_BASE //! - \b EUSCI_A3_BASE //! - \b EUSCI_B0_BASE //! - \b EUSCI_B1_BASE //! - \b EUSCI_B2_BASE //! - \b EUSCI_B3_BASE //! //! This function unregisters the handler to be called when timer //! interrupt occurs. This function also masks off the interrupt in the //! interrupt controller so that the interrupt handler no longer is called. //! //! \sa Interrupt_registerInterrupt() for important information about //! registering interrupt handlers. //! //! \return None. // //***************************************************************************** extern void SPI_unregisterInterrupt(uint32_t moduleInstance); /* Backwards Compatibility Layer */ #define EUSCI_B_SPI_PHASE_DATA_CHANGED_ONFIRST_CAPTURED_ON_NEXT 0x00 #define EUSCI_B_SPI_PHASE_DATA_CAPTURED_ONFIRST_CHANGED_ON_NEXT UCCKPH #define EUSCI_B_SPI_MSB_FIRST UCMSB #define EUSCI_B_SPI_LSB_FIRST 0x00 #define EUSCI_B_SPI_CLOCKPOLARITY_INACTIVITY_HIGH UCCKPL #define EUSCI_B_SPI_CLOCKPOLARITY_INACTIVITY_LOW 0x00 #define EUSCI_B_SPI_CLOCKSOURCE_ACLK UCSSEL__ACLK #define EUSCI_B_SPI_CLOCKSOURCE_SMCLK UCSSEL__SMCLK #define EUSCI_B_SPI_3PIN UCMODE_0 #define EUSCI_B_SPI_4PIN_UCxSTE_ACTIVE_HIGH UCMODE_1 #define EUSCI_B_SPI_4PIN_UCxSTE_ACTIVE_LOW UCMODE_2 #define EUSCI_B_SPI_PREVENT_CONFLICTS_WITH_OTHER_MASTERS 0x00 #define EUSCI_B_SPI_ENABLE_SIGNAL_FOR_4WIRE_SLAVE UCSTEM #define EUSCI_B_SPI_TRANSMIT_INTERRUPT UCTXIE #define EUSCI_B_SPI_RECEIVE_INTERRUPT UCRXIE #define EUSCI_B_SPI_BUSY UCBUSY #define EUSCI_B_SPI_NOT_BUSY 0x00 #define EUSCI_A_SPI_PHASE_DATA_CHANGED_ONFIRST_CAPTURED_ON_NEXT 0x00 #define EUSCI_A_SPI_PHASE_DATA_CAPTURED_ONFIRST_CHANGED_ON_NEXT UCCKPH #define EUSCI_A_SPI_MSB_FIRST UCMSB #define EUSCI_A_SPI_LSB_FIRST 0x00 #define EUSCI_A_SPI_CLOCKPOLARITY_INACTIVITY_HIGH UCCKPL #define EUSCI_A_SPI_CLOCKPOLARITY_INACTIVITY_LOW 0x00 #define EUSCI_A_SPI_CLOCKSOURCE_ACLK UCSSEL__ACLK #define EUSCI_A_SPI_CLOCKSOURCE_SMCLK UCSSEL__SMCLK #define EUSCI_A_SPI_3PIN UCMODE_0 #define EUSCI_A_SPI_4PIN_UCxSTE_ACTIVE_HIGH UCMODE_1 #define EUSCI_A_SPI_4PIN_UCxSTE_ACTIVE_LOW UCMODE_2 #define EUSCI_A_SPI_PREVENT_CONFLICTS_WITH_OTHER_MASTERS 0x00 #define EUSCI_A_SPI_ENABLE_SIGNAL_FOR_4WIRE_SLAVE UCSTEM #define EUSCI_A_SPI_TRANSMIT_INTERRUPT UCTXIE #define EUSCI_A_SPI_RECEIVE_INTERRUPT UCRXIE #define EUSCI_A_SPI_BUSY UCBUSY #define EUSCI_A_SPI_NOT_BUSY 0x00 extern void EUSCI_A_SPI_select4PinFunctionality(uint32_t baseAddress, uint8_t select4PinFunctionality); extern void EUSCI_A_SPI_masterChangeClock(uint32_t baseAddress, uint32_t clockSourceFrequency, uint32_t desiredSpiClock); extern bool EUSCI_A_SPI_slaveInit(uint32_t baseAddress, uint16_t msbFirst, uint16_t clockPhase, uint16_t clockPolarity, uint16_t spiMode); extern void EUSCI_A_SPI_changeClockPhasePolarity(uint32_t baseAddress, uint16_t clockPhase, uint16_t clockPolarity); extern void EUSCI_A_SPI_transmitData(uint32_t baseAddress, uint8_t transmitData); extern uint8_t EUSCI_A_SPI_receiveData(uint32_t baseAddress); extern void EUSCI_A_SPI_enableInterrupt(uint32_t baseAddress, uint8_t mask); extern void EUSCI_A_SPI_disableInterrupt(uint32_t baseAddress, uint8_t mask); extern uint8_t EUSCI_A_SPI_getInterruptStatus(uint32_t baseAddress, uint8_t mask); extern void EUSCI_A_SPI_clearInterruptFlag(uint32_t baseAddress, uint8_t mask); extern void EUSCI_A_SPI_enable(uint32_t baseAddress); extern void EUSCI_A_SPI_disable(uint32_t baseAddress); extern uint32_t EUSCI_A_SPI_getReceiveBufferAddressForDMA(uint32_t baseAddress); extern uint32_t EUSCI_A_SPI_getTransmitBufferAddressForDMA( uint32_t baseAddress); extern bool EUSCI_A_SPI_isBusy(uint32_t baseAddress); extern void EUSCI_B_SPI_select4PinFunctionality(uint32_t baseAddress, uint8_t select4PinFunctionality); extern void EUSCI_B_SPI_masterChangeClock(uint32_t baseAddress, uint32_t clockSourceFrequency, uint32_t desiredSpiClock); extern bool EUSCI_B_SPI_slaveInit(uint32_t baseAddress, uint16_t msbFirst, uint16_t clockPhase, uint16_t clockPolarity, uint16_t spiMode); extern void EUSCI_B_SPI_changeClockPhasePolarity(uint32_t baseAddress, uint16_t clockPhase, uint16_t clockPolarity); extern void EUSCI_B_SPI_transmitData(uint32_t baseAddress, uint8_t transmitData); extern uint8_t EUSCI_B_SPI_receiveData(uint32_t baseAddress); extern void EUSCI_B_SPI_enableInterrupt(uint32_t baseAddress, uint8_t mask); extern void EUSCI_B_SPI_disableInterrupt(uint32_t baseAddress, uint8_t mask); extern uint8_t EUSCI_B_SPI_getInterruptStatus(uint32_t baseAddress, uint8_t mask); extern void EUSCI_B_SPI_clearInterruptFlag(uint32_t baseAddress, uint8_t mask); extern void EUSCI_B_SPI_enable(uint32_t baseAddress); extern void EUSCI_B_SPI_disable(uint32_t baseAddress); extern uint32_t EUSCI_B_SPI_getReceiveBufferAddressForDMA(uint32_t baseAddress); extern uint32_t EUSCI_B_SPI_getTransmitBufferAddressForDMA( uint32_t baseAddress); extern bool EUSCI_B_SPI_isBusy(uint32_t baseAddress); //***************************************************************************** // // Mark the end of the C bindings section for C++ compilers. // //***************************************************************************** #ifdef __cplusplus } #endif //***************************************************************************** // // Close the Doxygen group. //! @} // //***************************************************************************** #endif /* SPI_H_ */
