Part Number: MSP432E401Y
我用的是MSP432E401Y系列,现在只能读取到PL0的I/O,其他四个均无法读取,请问有人知道这是什么原因吗?
#include
#include
#include "ti/devices/msp432e4/driverlib/driverlib.h"
#include "delay.h"
#define MIN_DUTY 20
#define MID_DUTY 30
#define MAX_DUTY 40
#define GPIO_PIN_RESET 0
#define GPIO_PIN_SET 1
//#define TURN_LEFT_TIME 1100
//#define TURN_RIGHT_TIME 1100
#define TURN_SMALL 100
#define TURN_BIG 300
#define BUZZER_ON GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_1, GPIO_PIN_1);
#define BUZZER_OFF GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_1, 0x0);
#define READ_L2 GPIOPinRead(GPIO_PORTL_BASE, GPIO_PIN_0)
#define READ_L1 GPIOPinRead(GPIO_PORTL_BASE, GPIO_PIN_1)
#define READ_M GPIOPinRead(GPIO_PORTL_BASE, GPIO_PIN_2)
#define READ_R1 GPIOPinRead(GPIO_PORTL_BASE, GPIO_PIN_3)
#define READ_R2 GPIOPinRead(GPIO_PORTL_BASE, GPIO_PIN_4)
uint8_t dir = 0;
// uint16_t pwmcnt = 0;
#ifdef DEBUG
void __error__(char *pcFilename, uint32_t ui32Line)
while (1)
#endif
/*驱动板接线
电机
P27-PG1 PWML
P26-PK4 PWMR*/
void delay(uint32_t us)
volatile uint32_t ui32Loop; // Enable the GPIO port that is used for the on-board LED.
us *= 20;
for (ui32Loop = 0; ui32Loop < us; ui32Loop++)
void key_init(void)
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOJ);
GPIOPinTypeGPIOInput(GPIO_PORTJ_BASE, GPIO_PIN_0);
GPIOPadConfigSet(GPIO_PORTJ_BASE, GPIO_PIN_0,
GPIO_STRENGTH_2MA, GPIO_PIN_TYPE_STD_WPU);
GPIOPinTypeGPIOInput(GPIO_PORTJ_BASE, GPIO_PIN_1);
GPIOPadConfigSet(GPIO_PORTJ_BASE, GPIO_PIN_1,
uint8_t scankeys()
if (GPIOPinRead(GPIO_PORTJ_BASE, GPIO_PIN_0) == GPIO_PIN_RESET)
dir = 0;
return 1;
else if (GPIOPinRead(GPIO_PORTJ_BASE, GPIO_PIN_1) == GPIO_PIN_RESET)
dir = 1;
return 1;
else
return 0;
void lpwm_init()
MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM0);
while (!(MAP_SysCtlPeripheralReady(SYSCTL_PERIPH_PWM0)))
MAP_PWMClockSet(PWM0_BASE, PWM_SYSCLK_DIV_1);
MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
while (!MAP_SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOF))
MAP_GPIOPinConfigure(GPIO_PF0_M0PWM0);
MAP_GPIOPinConfigure(GPIO_PF1_M0PWM1);
MAP_GPIOPinTypePWM(GPIO_PORTF_BASE, (GPIO_PIN_0 | GPIO_PIN_1));
MAP_PWMGenConfigure(PWM0_BASE, PWM_GEN_0, PWM_GEN_MODE_UP_DOWN | PWM_GEN_MODE_NO_SYNC);
MAP_PWMGenPeriodSet(PWM0_BASE, PWM_GEN_0, 64000);
MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_0,MAP_PWMGenPeriodGet(PWM0_BASE, PWM_GEN_0) / 4);
MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_1,MAP_PWMGenPeriodGet(PWM0_BASE, PWM_GEN_0) / 4);
// MAP_IntMasterEnable();
// MAP_PWMGenIntTrigEnable(PWM0_BASE, PWM_GEN_0,
// PWM_INT_CNT_ZERO | PWM_INT_CNT_LOAD |
// PWM_INT_CNT_AU | PWM_INT_CNT_AD);
// MAP_IntEnable(INT_PWM0_0);
// MAP_PWMIntEnable(PWM0_BASE, PWM_INT_GEN_0);
MAP_PWMOutputState(PWM0_BASE, PWM_OUT_0_BIT | PWM_OUT_1_BIT, true);
void rpwm_init()
MAP_GPIOPinConfigure(GPIO_PF2_M0PWM2);
MAP_GPIOPinConfigure(GPIO_PF3_M0PWM3);
MAP_GPIOPinTypePWM(GPIO_PORTF_BASE, (GPIO_PIN_2 | GPIO_PIN_3));
MAP_PWMGenConfigure(PWM0_BASE, PWM_GEN_1, PWM_GEN_MODE_UP_DOWN | PWM_GEN_MODE_NO_SYNC);
MAP_PWMGenPeriodSet(PWM0_BASE, PWM_GEN_1, 64000);
MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_2,MAP_PWMGenPeriodGet(PWM0_BASE, PWM_GEN_1) / 4);
MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_3,MAP_PWMGenPeriodGet(PWM0_BASE, PWM_GEN_1) / 4);
MAP_PWMOutputState(PWM0_BASE, PWM_OUT_2_BIT | PWM_OUT_3_BIT, true);
// void PWM0_0_IRQHandler(void)
// uint32_t getIntStatus;
// getIntStatus = MAP_PWMGenIntStatus(PWM0_BASE, PWM_GEN_0, true);
// MAP_PWMGenIntClear(PWM0_BASE, PWM_GEN_0, getIntStatus);
// 0左前1右前2左后3右后
void duty_set_l(uint8_t dutyl)
MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_0, 640 * dutyl);
MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_2, 640 * dutyl);
void duty_set_r(uint8_t dutyr)
MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_1, 640 * dutyr);
MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_3, 640 * dutyr);
void duty_set_all(uint8_t duty)
MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_0, 640 * duty);
MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_1, 640 * duty);
MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_2, 640 * duty);
MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_3, 640 * duty);
void car_front()
duty_set_all(MID_DUTY);
MAP_PWMOutputState(PWM0_BASE, PWM_OUT_0_BIT, true);
MAP_PWMOutputState(PWM0_BASE, PWM_OUT_1_BIT, true);
MAP_PWMOutputState(PWM0_BASE, PWM_OUT_2_BIT, false);
MAP_PWMOutputState(PWM0_BASE, PWM_OUT_3_BIT, false);
void car_back()
MAP_PWMOutputState(PWM0_BASE, PWM_OUT_0_BIT, false);
MAP_PWMOutputState(PWM0_BASE, PWM_OUT_1_BIT, false);
MAP_PWMOutputState(PWM0_BASE, PWM_OUT_2_BIT, true);
MAP_PWMOutputState(PWM0_BASE, PWM_OUT_3_BIT, true);
void car_right()
duty_set_all(MAX_DUTY);
void car_left()
void brake()
duty_set_all(0);
void gs_init()
MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOL);
while (!MAP_SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOL))
MAP_GPIOPinTypeGPIOInput(GPIO_PORTL_BASE, (GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4));
// MAP_GPIOPadConfigSet(GPIO_PORTL_BASE, (GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4),GPIO_STRENGTH_2MA, GPIO_PIN_TYPE_STD_WPU);
// GPIOPinTypeGPIOInput(GPIO_PORTL_BASE, GPIO_PIN_0);
// GPIOPadConfigSet(GPIO_PORTL_BASE, GPIO_PIN_0,
// GPIO_STRENGTH_2MA, GPIO_PIN_TYPE_OD);
// GPIOPinTypeGPIOInput(GPIO_PORTL_BASE, GPIO_PIN_1);
// GPIOPadConfigSet(GPIO_PORTL_BASE, GPIO_PIN_1,
// GPIOPinTypeGPIOInput(GPIO_PORTL_BASE, GPIO_PIN_2);
// GPIOPadConfigSet(GPIO_PORTL_BASE, GPIO_PIN_2,
// GPIOPinTypeGPIOInput(GPIO_PORTL_BASE, GPIO_PIN_3);
// GPIOPadConfigSet(GPIO_PORTL_BASE, GPIO_PIN_3,
// GPIOPinTypeGPIOInput(GPIO_PORTL_BASE, GPIO_PIN_4);
// GPIOPadConfigSet(GPIO_PORTL_BASE, GPIO_PIN_4,
void scanline()
if (READ_L2 == GPIO_PIN_SET && READ_L1 == GPIO_PIN_SET && READ_M == GPIO_PIN_SET && READ_R1 == GPIO_PIN_SET && READ_R2 == GPIO_PIN_SET)
brake();
BUZZER_ON;
delay_ms(500);
BUZZER_OFF;
delay_ms(500);
brake();
else if (READ_L2 == GPIO_PIN_RESET && READ_L1 == GPIO_PIN_RESET && READ_M == GPIO_PIN_RESET && READ_R1 == GPIO_PIN_RESET && READ_R2 == GPIO_PIN_RESET)
car_front();
else if (READ_M == GPIO_PIN_SET)
BUZZER_OFF;
car_front();
// if(READ_L1 == GPIO_PIN_SET && READ_L2 == GPIO_PIN_SET){
// BUZZER_ON;
// car_left();
// delay_ms(TURN_LEFT_TIME);
// BUZZER_OFF;
// duty_set_all(MID_DUTY);
// car_front();
// else if(READ_R1 == GPIO_PIN_SET && READ_R2 == GPIO_PIN_SET){
// BUZZER_ON;
// car_right();
// delay_ms(TURN_RIGHT_TIME);
// BUZZER_OFF;
// car_front();
else
BUZZER_ON;
delay_ms(100);
BUZZER_OFF;
if (READ_L1 == GPIO_PIN_SET)
car_left();
// if(READ_L2 == GPIO_PIN_SET){
// car_right();
// delay_ms(TURN_RIGHT_TIME - TURN_SMALL);
delay_ms(TURN_SMALL);
else if (READ_L2 == GPIO_PIN_SET)
car_left();
// if(READ_L1 == GPIO_PIN_SET){
// car_right();
// delay_ms(TURN_RIGHT_TIME - TURN_BIG);
delay_ms(TURN_BIG);
else if (READ_R1 == GPIO_PIN_SET)
car_right();
// if(READ_R2 == GPIO_PIN_SET){
// car_left();
// delay_ms(TURN_LEFT_TIME - TURN_SMALL);
else if (READ_R2 == GPIO_PIN_SET)
car_right();
// if(READ_R1 == GPIO_PIN_SET){
// car_left();
// delay_ms(TURN_LEFT_TIME - TURN_BIG);
delay_ms(TURN_BIG);
int main(void)
// MAP_SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ | SYSCTL_OSC_MAIN |SYSCTL_USE_PLL | SYSCTL_CFG_VCO_480),120000000);
MAP_SysCtlClockFreqSet((SYSCTL_OSC_INT | SYSCTL_USE_OSC), 16000000);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPION); // Check if the peripheral access is enabled.
GPIOPinTypeGPIOOutput(GPIO_PORTN_BASE, GPIO_PIN_0); // LED
GPIOPinTypeGPIOOutput(GPIO_PORTN_BASE, GPIO_PIN_1);
GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_0, GPIO_PIN_0);
Delay_Init();
GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_0, 0x0);
key_init();
gs_init();
lpwm_init();
rpwm_init();
MAP_PWMGenEnable(PWM0_BASE, PWM_GEN_0);
MAP_PWMGenEnable(PWM0_BASE, PWM_GEN_1);
brake();
BUZZER_ON;
delay_ms(500);
BUZZER_OFF;
while (1)
if (scankeys() == 1)
break;
BUZZER_ON;
delay_ms(500);
BUZZER_OFF;
while (1) // Loop forever.
//scanline();
BUZZER_ON;
delay_ms(80);
BUZZER_OFF;
delay_ms(80);
BUZZER_ON;
delay_ms(80);
BUZZER_OFF;
delay_ms(80);
BUZZER_ON;
delay_ms(80);
BUZZER_OFF;
delay_ms(80);
if(READ_M == GPIO_PIN_SET){
BUZZER_ON;
delay_ms(80);
BUZZER_OFF;
delay_ms(80);
BUZZER_ON;
delay_ms(80);
BUZZER_OFF;
delay_ms(80);
BUZZER_ON;
delay_ms(80);
BUZZER_OFF;
delay_ms(80);
BUZZER_ON;
delay_ms(80);
BUZZER_OFF;
delay_ms(80);
BUZZER_ON;
delay_ms(80);
BUZZER_OFF;
delay_ms(80);
BUZZER_ON;
delay_ms(80);
BUZZER_OFF;
delay_ms(80);
delay_ms(200);
