Part Number: AM2634
Hi TI,
I have a few questions related to cache operations that need clarification on:
- Cache Capacity of CacheP_wbInv: What is the maximum amount of data that CacheP_wbInv can handle in one invocation? Can it process more than 16KB at a time?
- Non-Cached Regions and CacheP_wbInv: If an array is located in a memory region configured as NON-CACHED through the MPU, does invoking the CacheP_wbInv interface on this address have any effect?
- Cache Operations for Struct Pointers in SIPC: Consider a scenario where we define a struct variable used in SIPC, one of its members being a pointer that is assigned a value on the HSM side without prior initialization. In this case, is it necessary to perform a CacheP_wbInv operation for this pointer?
These clarifications are crucial for optimizing our system's performance and ensuring correct data handling. I appreciate your timely response to these queries.
Thank you very much.
Best regards,
