LM51772: The status register 0x78 always reads as 0x40. How can I set this bit to 0?
Part Number: LM51772
I'm currently using the LM51772 and trying to configure the registers via I2C, but it fails to output a valid voltage. Could you tell me how to configure the registers and pins to achieve the target voltage output?
