UCC28056: The voltage division ratio of Kzc
Part Number: UCC28056
The UCC28056 datasheet and XLS design tool set the Kzc voltage division ratio to 401 by default. Is this the internal default or recommended value of the chip? If my input voltage ranges from 176 to 256 V, can I change this ratio to avoid keeping excessive design margin?
