TPS92391: TPS92391 IC电路配置check
Part Number: TPS92391
Hello, TI's Electronic Engineer: I've been designing the peripheral circuit of tps932391 recently, but I'm not sure whether the IC pin setting is wrong. Can you check the drawing.If you can, please reply to your email directly. Thank you~
