1. The efuse PN is TPS16530 .Is it nessecery for the design to add a COUT CAP(100uf/100v ;RED ) on the efuse out put? The high voltage Aluminum cap size is too big for the output port.
Could it be replaced by a Ceramic caps such as the value is 2.2uf/100v?
2. SCHEMATIC1 _ PAGE3_RRU_POWER_SU.pdf
Attached is the SCH design for TPS16530 ,please check.
