Other Parts Discussed in Thread: BQSTUDIO
Hi TI expert,
We turn off the Battery Trip Point Interrupt Function by setting BTE_EN to 1.
When the RC has crossed below the set threshold,The Flags()[SOC1] bit is set to 1,but the interrupt didn't asserts on the HDQ pin.
Then we tried to Set the [HOST_IE] bit to 1 and issue SET_HDQINTEN through BqStudio, but it didn't work.
Attached is the GG file,please help check,thank you!
