Part Number: BQ40Z50-R2
Other Parts Discussed in Thread: BQSTUDIO
从官网上下载了BQ40Z50-R5的BQZ文件到D:\ti\BatteryManagementStudio\config目录下之后,每次重新进入R5都会跳出这个报错,关闭后可以正常使用,希望官方能看一下是什么原因,会不会有别的影响,谢谢!
This is normal and does not impact the functionality of BQStudio or the gauge.
With the BQ40Z50-R5 firmware release we have added in extra functionality which allows you to hover over the bits and registers within BQStudio to see the TRM definition. When we push the new BQStudio test version within the next couple months the popup window you see will go away.
