TPS54160A: TPS54160A burnt and shorted between input and output.
Part Number: TPS54160A
There is one case of damaged of TPS54160A. it happens during normal operation, 24V input, 3.3V/500mA output. it shows burnt on the surface, input and output shorted, and the output directly as 24V.
