BQ25756: 充电异常
Part Number: BQ25756
1.使用贵公司该系列产品对超级电容充电,为什么充电一段时间后,电压升高到一定值,就没有输出电流了?并且充电状态仍然为不变“Fast Charge”
2.寄存器配置:
//0010: Charge Voltage Limit:15V
//0050: Charge Current Limit--1A
//0060: Input Current DPM Limit--3A
//0382: Input Voltage DPM Limit--4.5V
//0028: Precharge Current Limit--500mA
//00F0: Termination Current Limit--3A
//01: Precharge and Term Control(关闭终止充电电流控制termination control、开启预充电和涓流充电)
 //05: Timer Control(关闭顶部定时器,关闭看门口,关闭充电计时12H)
//C9: Charger Control(默认)
//C0: Pin Control(默认)
//20: Power Path and Reverse Mode Control(默认)
//20: MPPT Control(默认)
//D4: TS Charging Threshold Control(65C~-10C)
//56: TS Charging Region Control(关闭TS)
//00: Charger Mask 1
//00: Charger Mask 2
//00: Fault Mask
//90: ADC Control(开启ADC循环模式)
//08: ADC Channel Control(开启所有ADC通道)
//00: Gate Driver Strength Control
//00: Gate Driver Dead Time Control
//00: Reverse_Mode_Battery_Discharge_Current Register (Address = 0x62)
