TI PMIC power on seq20250331-2.pptx
Hi TI:
Our design used TPS6521920WRHBRQ1+AM6202ATGFHIAMCRQ1。
The timing and voltage are different from the specification, because it is a different model, we only find the spec for the common model(TPS65219-Q1). we need TI to confirm the sequence, if have any issue or risk.
At present, the AM6202 is normal to boot up.
Thanks
