TMS320F28379D: 使用XDS110烧写程序后,程序可以正常运行,但是点击RESTART按钮后,程序进入Interrupt_illegalOperationHandler中断
Part Number: TMS320F28379D
目前的状况是在仿真模式下,ram模式和flash模式均可以正常执行,但是点击restart后,ram模式下会进入Interrupt_illegalOperationHandler中断。第二个问题是当我关闭了编译器优化后发现flash模式烧录程序后,程序并没有在MCU上运行启动,以下是我的RAM.cmd文件
MEMORY
PAGE 0 :
   /* BEGIN is used for the "boot to SARAM" bootloader mode   */
   BEGIN            : origin = 0x000000, length = 0x000002
   RAMM0            : origin = 0x000123, length = 0x0002DD
   RAMD0            : origin = 0x00B000, length = 0x000800
   // RAMLS0           : origin = 0x008000, length = 0x000800
   RAMLS0           : origin = 0x008000, length = 0x001000
   RAMLS1           : origin = 0x009000, length = 0x000800
   // RAMLS1           : origin = 0x008800, length = 0x000800
   // RAMLS2           : origin = 0x009000, length = 0x000800
   RAMLS3           : origin = 0x009800, length = 0x001000
   // RAMLS3           : origin = 0x009800, length = 0x000800
   // RAMLS4           : origin = 0x00A000, length = 0x000800
   // RAMGS10     : origin = 0x016000, length = 0x001000
   RESET            : origin = 0x3FFFC0, length = 0x000002
  /* Flash sectors */
   FLASHA           : origin = 0x080002, length = 0x001FFE	/* on-chip Flash */
   FLASHB           : origin = 0x082000, length = 0x002000	/* on-chip Flash */
   FLASHC           : origin = 0x084000, length = 0x002000	/* on-chip Flash */
   FLASHD           : origin = 0x086000, length = 0x002000	/* on-chip Flash */
   FLASHE           : origin = 0x088000, length = 0x008000	/* on-chip Flash */
   FLASHF           : origin = 0x090000, length = 0x008000	/* on-chip Flash */
   FLASHG           : origin = 0x098000, length = 0x008000	/* on-chip Flash */
   FLASHH           : origin = 0x0A0000, length = 0x008000	/* on-chip Flash */
   FLASHI           : origin = 0x0A8000, length = 0x008000	/* on-chip Flash */
   FLASHJ           : origin = 0x0B0000, length = 0x008000	/* on-chip Flash */
   FLASHK           : origin = 0x0B8000, length = 0x002000	/* on-chip Flash */
   FLASHL           : origin = 0x0BA000, length = 0x002000	/* on-chip Flash */
   FLASHM           : origin = 0x0BC000, length = 0x002000	/* on-chip Flash */
   FLASHN           : origin = 0x0BE000, length = 0x001FF0	/* on-chip Flash */
//   FLASHN_RSVD     : origin = 0x0BFFF0, length = 0x000010    /* Reserve and do not use for code as per the errata advisory "Memory: Prefetching Beyond Valid Memory" */
PAGE 1 :
   BOOT_RSVD       : origin = 0x000002, length = 0x000121     /* Part of M0, BOOT rom will use this for stack */
   RAMM1           : origin = 0x000400, length = 0x0003F8     /* on-chip RAM block M1 */
//   RAMM1_RSVD      : origin = 0x0007F8, length = 0x000008     /* Reserve and do not use for code as per the errata advisory "Memory: Prefetching Beyond Valid Memory" */
   RAMD1           : origin = 0x00B800, length = 0x000800
   // RAMLS5      : origin = 0x00A800, length = 0x000800
   //修改长度
   RAMGS0      : origin = 0x00C000, length = 0x001000
   RAMGS1      : origin = 0x00D000, length = 0x001000
   RAMGS2      : origin = 0x00E000, length = 0x001000
   RAMGS3      : origin = 0x00F000, length = 0x002000
   // RAMGS3      : origin = 0x00F000, length = 0x001000
   // RAMGS4      : origin = 0x010000, length = 0x001000
   RAMGS5      : origin = 0x011000, length = 0x001000
   RAMGS6      : origin = 0x012000, length = 0x001000
   RAMGS7      : origin = 0x013000, length = 0x001000
   RAMGS8      : origin = 0x014000, length = 0x001000
   RAMGS9      : origin = 0x015000, length = 0x001000
//   RAMGS11     : origin = 0x017000, length = 0x000FF8   /* Uncomment for F28374D, F28376D devices */
//   RAMGS11_RSVD : origin = 0x017FF8, length = 0x000008    /* Reserve and do not use for code as per the errata advisory "Memory: Prefetching Beyond Valid Memory" */
   RAMGS11     : origin = 0x017000, length = 0x002000
   // RAMGS11     : origin = 0x017000, length = 0x001000     /* Only Available on F28379D, F28377D, F28375D devices. Remove line on other devices. */
   // RAMGS12     : origin = 0x018000, length = 0x001000     /* Only Available on F28379D, F28377D, F28375D devices. Remove line on other devices. */
   RAMGS13     : origin = 0x019000, length = 0x001000     /* Only Available on F28379D, F28377D, F28375D devices. Remove line on other devices. */
   RAMGS14     : origin = 0x01A000, length = 0x001000     /* Only Available on F28379D, F28377D, F28375D devices. Remove line on other devices. */
   RAMGS15     : origin = 0x01B000, length = 0x000FF8     /* Only Available on F28379D, F28377D, F28375D devices. Remove line on other devices. */
//   RAMGS15_RSVD : origin = 0x01BFF8, length = 0x000008    /* Reserve and do not use for code as per the errata advisory "Memory: Prefetching Beyond Valid Memory" */
                                                            /* Only on F28379D, F28377D, F28375D devices. Remove line on other devices. */
   CPU2TOCPU1RAM   : origin = 0x03F800, length = 0x000400
   CPU1TOCPU2RAM   : origin = 0x03FC00, length = 0x000400
   CANA_MSG_RAM     : origin = 0x049000, length = 0x000800
   CANB_MSG_RAM     : origin = 0x04B000, length = 0x000800
SECTIONS
   codestart        : > BEGIN,     PAGE = 0
   // .text            : >> RAMD0 |  RAMLS0 | RAMLS3,   PAGE = 0
   .text            : >> RAMGS1 | RAMGS2 | RAMGS3 | RAMGS11 , PAGE = 1
   // .text            : >> FLASHA | FLASHB | FLASHC,   PAGE = 0
   .cinit           : > RAMM0,     PAGE = 0
   .switch          : > RAMM0,     PAGE = 0
   .reset           : > RESET,     PAGE = 0, TYPE = DSECT /* not used, */
   // .stack           : > RAMM1,     PAGE = 1
   .stack           : > RAMD1,     PAGE = 1
#if defined(__TI_EABI__)
   .bss             : >> RAMLS5 | RAMGS9,    PAGE = 1
   .bss:output      : > RAMLS3,    PAGE = 0
   .init_array      : > RAMM0,     PAGE = 0
   .const           : > RAMGS6,    PAGE = 1
   .data            : >> RAMGS6 | RAMGS7 | RAMGS8 | RAMGS13,    PAGE = 1
   .sysmem          : > RAMGS6,    PAGE = 1
#else
   .pinit           : > RAMM0,     PAGE = 0
   .ebss            : > RAMLS5,    PAGE = 1
   .econst          : > RAMLS5,    PAGE = 1
   .esysmem         : > RAMLS5,    PAGE = 1
#endif
   Filter_RegsFile  : > RAMGS0,    PAGE = 1
   ramgs0           : > RAMGS0,    PAGE = 1
   ramgs1           : > RAMGS1,    PAGE = 1
   SFRA_F32_Data    : > RAMGS10,   PAGE = 1
   dclfuncs    : > RAMGS13,   PAGE = 1
#ifdef __TI_COMPILER_VERSION__
   #if __TI_COMPILER_VERSION__ >= 15009000
    .TI.ramfunc : {} > RAMM0,      PAGE = 0
   #else
    ramfuncs    : > RAMM0      PAGE = 0
   #endif
#endif
   /* The following section definitions are required when using the IPC API Drivers */
    GROUP : > CPU1TOCPU2RAM, PAGE = 1
        PUTBUFFER
        PUTWRITEIDX
        GETREADIDX
    GROUP : > CPU2TOCPU1RAM, PAGE = 1
        GETBUFFER :    TYPE = DSECT
        GETWRITEIDX :  TYPE = DSECT
        PUTREADIDX :   TYPE = DSECT
    /* The following section definition are for SDFM examples */
   Filter1_RegsFile : > RAMGS1, PAGE = 1, fill=0x1111
   Filter2_RegsFile : > RAMGS2, PAGE = 1, fill=0x2222
   Filter3_RegsFile : > RAMGS3, PAGE = 1, fill=0x3333
   // Filter4_RegsFile : > RAMGS4, PAGE = 1, fill=0x4444
   Difference_RegsFile : >RAMGS5,   PAGE = 1, fill=0x3333
// End of file.
