本人使用starterware的库,配置EDMA,例子使用的是AM335X_StarterWare_02_00_01_01\examples\beaglebone\edma下面的edmaTest.c
裸机开发,例子的东西应该不会错的哇,但是又用不起来,我还有哪些地方没配置呢?或者遗漏哪里了呢/
代码的结果是:源数据跟目的数据不一样,目的数据没变化,也就是传输不成功!!!
代码进入到EDMAAppEDMA3Test()下面的这个末尾,也就是这个地方出错:
SrcBuff[index] != DstBuff[index
EDMA3Test: Data write-read matching FAILED.\r\n
具体代码如下:
main()
MMUConfigAndEnable();
CacheEnable(CACHE_ALL);
//VFPv3Enable();
EDMAModuleClkConfig();
/* Initialize EDMA */
EDMA3Init(EDMAAPP_EDMACC_BASE_ADDRESS, EDMAAPP_DMA_EVTQ);
/* Enable IRQ in CPSR. */
IntMasterIRQEnable();
/* Intialize ARM interrupt controller */
IntAINTCInit();
/* Registers Edma3ComplHandler0 Isr in Interrupt Vector Table of AINTC. */
IntRegister(SYS_INT_EDMACOMPINT , _EDMAAppEdma3ccComplIsr);
/* Set priority for system interrupt in AINTC */
IntPrioritySet(SYS_INT_EDMACOMPINT, 0u, AINTC_HOSTINT_ROUTE_IRQ);
/* Enable the EDMA CC0 system interrupt in AINTC.*/
IntSystemEnable(SYS_INT_EDMACOMPINT);
IntRegister(SYS_INT_EDMAERRINT , _EDMAAppEdma3ccErrIsr);
IntPrioritySet(SYS_INT_EDMAERRINT, 0u, AINTC_HOSTINT_ROUTE_IRQ);
/* Enable the EDMA CCERR system interrupt AINTC.*/
IntSystemEnable(SYS_INT_EDMAERRINT);
#ifdef CH_TYPE_DMA
EDMAAppEDMA3Test();
#else
EDMAAppQDMA3Test();
#endif
EDMA3Deinit(EDMAAPP_EDMACC_BASE_ADDRESS, EDMAAPP_DMA_EVTQ);
具体的 EDMAAppEDMA3Test();如下: (都是直接复制edmaTest.c里面的函数!无改动)
void EDMAAppEDMA3Test()
volatile unsigned int index = 0u;
volatile unsigned int count = 0u;
EDMA3CCPaRAMEntry paramSet;
unsigned char data = 0u;
volatile unsigned int retVal = 0u;
unsigned int isTestPassed = false;
unsigned int numEnabled = 0u;
unsigned int aCount = EDMAAPP_MAX_ACOUNT;
unsigned int bCount = EDMAAPP_MAX_BCOUNT;
unsigned int cCount = EDMAAPP_MAX_CCOUNT;
/* Initalize source and destination buffers */
for (count = 0u; count < (aCount * bCount * cCount); count++)
SrcBuff[count] = data++;
** No need to initialize the destination buffer as it is
** being invalidated.
/* Request DMA channel and TCC */
retVal = EDMA3RequestChannel(EDMAAPP_EDMACC_BASE_ADDRESS,
EDMAAPP_DMA_CH_TYPE, EDMAAPP_DMA_CH_NUM,
EDMAAPP_DMA_TCC_NUM, EDMAAPP_DMA_EVTQ);
/* Registering Callback Function */
EDMAAppCallbackFxn[EDMAAPP_DMA_TCC_NUM] = &EDMAAppCallback;
if(TRUE == retVal)
/* Fill the PaRAM Set with transfer specific information */
paramSet.srcAddr = (unsigned int)(SrcBuff);
paramSet.destAddr = (unsigned int)(DstBuff);
paramSet.aCnt = (unsigned short)aCount;
paramSet.bCnt = (unsigned short)bCount;
paramSet.cCnt = (unsigned short)cCount;
/* Setting up the SRC/DES Index */
paramSet.srcBIdx = (short)aCount;
paramSet.destBIdx = (short)aCount;
if(EDMA3_SYNC_A == EDMAAPP_DMA_SYNC_TYPE)
/* A Sync Transfer Mode */
paramSet.srcCIdx = (short)aCount;
paramSet.destCIdx = (short)aCount;
else
/* AB Sync Transfer Mode */
paramSet.srcCIdx = ((short)aCount * (short)bCount);
paramSet.destCIdx = ((short)aCount * (short)bCount);
/* Configure the paramset with NULL link */
paramSet.linkAddr = (unsigned short)0xFFFFu;
paramSet.bCntReload = (unsigned short)0u;
paramSet.opt = 0u;
/* Src & Dest are in INCR modes */
paramSet.opt &= ~(EDMA3CC_OPT_SAM | EDMA3CC_OPT_DAM);
/* Program the TCC */
paramSet.opt |= ((EDMAAPP_DMA_TCC_NUM << EDMA3CC_OPT_TCC_SHIFT)
& EDMA3CC_OPT_TCC);
/* Enable Intermediate & Final transfer completion interrupt */
paramSet.opt |= (1u << EDMA3CC_OPT_ITCINTEN_SHIFT);
paramSet.opt |= (1u << EDMA3CC_OPT_TCINTEN_SHIFT);
paramSet.opt &= ~EDMA3CC_OPT_SYNCDIM;
else
paramSet.opt |= (1u << EDMA3CC_OPT_SYNCDIM_SHIFT);
/* Now, write the PaRAM Set. */
EDMA3SetPaRAM(EDMAAPP_EDMACC_BASE_ADDRESS, EDMAAPP_DMA_CH_NUM, ¶mSet);
EDMA3GetPaRAM(EDMAAPP_EDMACC_BASE_ADDRESS, EDMAAPP_DMA_CH_NUM, ¶mSet);
** Since the transfer is going to happen in Manual mode of EDMA3
** operation, we have to 'Enable the Transfer' multiple times.
** Number of times depends upon the Mode (A/AB Sync)
** and the different counts.
if(TRUE == retVal)
/* Need to activate next param */
numEnabled = bCount * cCount;
else
numEnabled = cCount;
for(index = 0u; index < numEnabled; index++)
IrqRaised = EDMAAPP_IRQ_STATUS_XFER_INPROG;
** Now enable the transfer as many times as calculated above.
retVal = EDMA3EnableTransfer(EDMAAPP_EDMACC_BASE_ADDRESS,
EDMAAPP_DMA_CH_NUM,
EDMAAPP_DMA_TRIG_MODE);
/* Wait for the Completion ISR. */
while(EDMAAPP_IRQ_STATUS_XFER_INPROG == IrqRaised)
** Wait for the Completion ISR on Master Channel.
** You can insert your code here to do something
** meaningful.
/* Check the status of the completed transfer */
if(IrqRaised < (int)EDMAAPP_IRQ_STATUS_XFER_INPROG)
/* Some error occured, break from the FOR loop. */
ConsoleUtilsPrintf("\r\nEDMA3Test: Event Miss Occured!!!\r\n");
/* Clear the error bits first */
EDMA3ClearErrorBits(EDMAAPP_EDMACC_BASE_ADDRESS, EDMAAPP_DMA_CH_NUM, EDMAAPP_DMA_EVTQ);
break;
/* Match the Source and Destination Buffers. */
if(TRUE == retVal)
for(index = 0u; index < (aCount * bCount * cCount); index++)
if(SrcBuff[index] != DstBuff[index])
ConsoleUtilsPrintf("EDMA3Test: Data write-read matching FAILED.\r\n");
ConsoleUtilsPrintf("The mismatch happened at index : %d\r\n",
((int)index + 1u));
break;
if(index == (aCount * bCount * cCount))
isTestPassed = true;
ConsoleUtilsPrintf("EDMA3Test: Data write-read matching PASSED.\r\n");
/* Free the previously allocated channel. */
retVal = EDMA3FreeChannel(EDMAAPP_EDMACC_BASE_ADDRESS,
EDMAAPP_DMA_TRIG_MODE, EDMAAPP_DMA_TCC_NUM,
EDMAAPP_DMA_EVTQ);
/* Unregister Callback Function */
EDMAAppCallbackFxn[EDMAAPP_DMA_TCC_NUM] = NULL;
if(TRUE != retVal)
ConsoleUtilsPrintf("EDMA3Test: EDMA3_DRV_freeChannel() FAILED.\r\n");
if(true == isTestPassed)
ConsoleUtilsPrintf("EDMA3Test PASSED.\r\n");
else
ConsoleUtilsPrintf("EDMA3Test FAILED\r\n");
