EMIFA总线问题
Other Parts Discussed in Thread: ADS7846, OMAP-L138
电路:
EMIFA总线上有nand flash与几片ADC。
问题:
一、
EMIFA总线上的CS3接了nand,而cs0只支持SDRAM,不支持异步设备,那么ADC的片选只能接CS2、CS4、CS5了,是这样么?
二、
现在焊接上一片ADC在CS2上,boot选择从nand启动,启动后加载完uboot后就无法启动了,应该是ADC影响了nand的读取,但是ADC的CS与RD等控制引脚已经与OMAPL138断开了。
输出如下:
Loading from nand0, offset 0x120000
NAND read from offset 120000 failed -74
** Read error
U-Boot >
在上面的情况下,快速的重新掉电、上电,系统又可以启动(而这时,会有极少的机率会无法加载文件系统)
  • 1. 是的。
    2. 请问是怎么判断ADC影响到了nand的读取。nand flash能正确烧写吗?烧写的时候也是接着ADC的?
  • 没有焊接ADC时,从nand启动,是可以启动的,但是焊上了adc后,启动不了。,只是启动到了uboot,如下上面问题里所描述。
    在烧写系统到nand的过程中,没有焊接ADC
  • 请问uboot也是放在nand flash里的吗?
  • 有时在内核启动时无法找到nand flash
    [ 1.792997] ata1: SATA max UDMA/133 mmio [mem 0x01e18000-0x01e19fff] port 0x100 irq 67
    [ 1.806825] nand_get_flash_type: second ID read did not match 00,00 against 2c,dc
    [ 1.814752] No NAND device found
    [ 1.822454] UBI error: ubi_init: UBI error: cannot initialize UBI, error -19
    [ 1.830288] spi_davinci spi_davinci.1: DMA: supported
    [ 1.835448] spi_davinci spi_davinci.1: DMA: RX channel: 18, TX channel: 19, event queue: 0
    [ 1.846159] m25p80 spi1.0: unrecognized JEDEC id ffffff
    [ 1.852550] spi_davinci spi_davinci.1: Controller at 0xfef0e000
    [ 1.862923] CAN device driver interface
    [ 1.866991] smsc911x: Driver version 2008-10-21
    [ 1.872109] _regulator_get: smsc911x supply vdd33a not found, using dummy regulator
    [ 1.880214] _regulator_get: smsc911x supply vddvario not found, using dummy regulator
    [ 1.987697] smsc911x: Device not READY in 100ms aborting
    [ 2.038368] davinci_mdio davinci_mdio.0: davinci mdio revision 1.5
    [ 2.044643] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
    [ 2.052726] davinci_mdio.0: probed
    [ 2.056229] davinci_mdio davinci_mdio.0: phy[0]: device davinci_mdio-0:00, driver SMSC LAN8710/LAN8720
    [ 2.066473] PPP generic driver version 2.4.2
    [ 2.072559] PPP BSD Compression module registered
    [ 2.077325] PPP Deflate Compression module registered
    [ 2.083482] usbcore: registered new interface driver rndis_wlan
    [ 2.090592] usbcore: registered new interface driver zd1201
    [ 2.097150] usbcore: registered new interface driver asix
    [ 2.103478] usbcore: registered new interface driver cdc_ether
    [ 2.110359] usbcore: registered new interface driver net1080
    [ 2.116965] usbcore: registered new interface driver rndis_host
    [ 2.123806] usbcore: registered new interface driver cdc_subset
    [ 2.130796] usbcore: registered new interface driver zaurus
    [ 2.137371] usbcore: registered new interface driver cdc_ncm
    [ 2.148459] ata1: SATA link down (SStatus 0 SControl 300)
    [ 2.161310] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [ 2.167794] ohci ohci.0: DA8xx OHCI
    [ 2.171831] ohci ohci.0: new USB bus registered, assigned bus number 1
    [ 2.178618] Waiting for USB PHY clock good...
    [ 2.183170] ohci ohci.0: irq 59, io mem 0x01e25000
    [ 2.240797] hub 1-0:1.0: USB hub found
    [ 2.244698] hub 1-0:1.0: 1 port detected
    [ 2.250950] Initializing USB Mass Storage driver...
    [ 2.256970] usbcore: registered new interface driver usb-storage
    [ 2.263248] USB Mass Storage support registered.
    [ 2.269604] usbcore: registered new interface driver usbserial
    [ 2.275534] usbserial: USB Serial Driver core
    [ 2.280827] USB Serial support registered for GSM modem (1-port)
    [ 2.288038] usbcore: registered new interface driver option
    [ 2.293847] option: v0.7.2:USB Driver for GSM modems
    [ 2.299462] gadget: Mass Storage Function, version: 2009/09/11
    [ 2.305490] gadget: Number of LUNs=1
    [ 2.309326] lun0: LUN: removable file: (no medium)
    [ 2.314356] gadget: Mass Storage Gadget, version: 2009/09/11
    [ 2.320274] gadget: userspace failed to provide iSerialNumber
    [ 2.326206] gadget: g_mass_storage ready
    [ 2.330343] musb-hdrc musb-hdrc: MUSB HDRC host driver
    [ 2.335648] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 2
    [ 2.345573] hub 2-0:1.0: USB hub found
    [ 2.349935] hub 2-0:1.0: 1 port detected
    [ 2.357664] mousedev: PS/2 mouse device common for all mice
    [ 2.364528] _regulator_get: spi1.1 supply vcc not found, using dummy regulator
    [ 2.372692] ads7846 spi1.1: touchscreen, irq 145
    [ 2.379064] input: ADS7846 Touchscreen as /devices/platform/spi_davinci.1/spi_master/spi1/spi1.1/input/input0
    [ 2.392952] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
    [ 2.399719] omap_rtc: RTC power up reset detected
    [ 2.405251] i2c /dev entries driver
    [ 2.410605] Linux video capture interface: v2.00
    [ 2.423638] ov2640 1-0030: Product ID error 87:87
    [ 2.429311] vpif_capture vpif_capture: Error registering v4l2 subdevice
    [ 2.439545] usbcore: registered new interface driver uvcvideo
    [ 2.445351] USB Video Class driver (1.1.1)
    [ 2.450279] watchdog watchdog: heartbeat 60 sec
    [ 2.456645] cpuidle: using governor ladder
    [ 2.461490] cpuidle: using governor menu
    [ 2.468736] davinci_mmc davinci_mmc.0: Using DMA, 4-bit mode
    [ 2.480448] usbcore: registered new interface driver usbhid
    [ 2.486080] usbhid: USB HID core driver
    [ 2.490603] _regulator_get: ad7606-8.0 supply vcc not found, using dummy regulator
    [ 2.504065] timer clk rate(156000000)
    [ 2.508890] iio_davinci_tmr_trigger iio_davinci_tmr_trigger.0: iio trigger davinci TMR2, IRQ-68
    [ 2.520677] usbcore: registered new interface driver snd-usb-audio
    [ 2.533659] soc-audio soc-audio.0: ASoC: Failed to create card debugfs directory
    [ 2.541894] _regulator_get: 1-0018 supply IOVDD not found, using dummy regulator
    [ 2.549729] _regulator_get: 1-0018 supply DVDD not found, using dummy regulator
    [ 2.557282] _regulator_get: 1-0018 supply AVDD not found, using dummy regulator
    [ 2.564984] _regulator_get: 1-0018 supply DRVDD not found, using dummy regulator
    [ 2.580816] asoc: tlv320aic3x-hifi <-> davinci-mcasp.0 mapping ok
    [ 2.588526] usb 1-1: new full-speed USB device number 2 using ohci
    [ 2.598686] ALSA device list:
    [ 2.601710] #0: DA850/OMAP-L138 EVM
    [ 2.605770] TCP cubic registered
    [ 2.609383] NET: Registered protocol family 17
    [ 2.613974] can: controller area network core (rev 20090105 abi 8)
    [ 2.620569] NET: Registered protocol family 29
    [ 2.625100] can: raw protocol (rev 20090105)
    [ 2.629516] can: broadcast manager protocol (rev 20090105 t)
    [ 2.635270] can: netlink gateway (rev 20101209)
    [ 2.641136] lib80211: common routines for IEEE802.11 drivers
    [ 2.647226] _regulator_get: deviceless supply cvdd not found, using dummy regulator
    [ 2.662334] console [netcon0] enabled
    [ 2.666043] netconsole: network logging started
    [ 2.675294] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
    [ 2.684971] VFS: Cannot open root device "ubi0_0" or unknown-block(0,0)
    [ 2.691800] Please append a correct "root=" boot option; here are the available partitions:
    [ 2.700343] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
