EVM5515的Nor Flash型号PC28F128P30T85换成MT28GU256AAA2EGC后,驱动参数怎么修改?
开发平台为EVM5515,由于PC28F128P30T85已经停产,且价格很高,120RMB/PCS。
PC28F128P30T85和MT28GU256AAA2EGC是Pin to Pin兼容的,容量分别是128MB和256MB。
如果将PC28F128P30T85换成MT28GU256AAA2EGC后,驱动参数怎么修改?
EVM5515开发板的例程CSL_EMIF_NOR_CpuTransfer文件如下
 *   Copyright (c) Texas Instruments Inc 2002, 2003, 2004, 2005, 2008
 *   Use of this software is controlled by the terms and conditions found in the
 *   license agreement under which this software has been supplied.
/** @file csl_nor.c
 *  @brief NOR functional layer API source file
 *  Path: \(CSLPATH)\src\nor\src
 * Revision History
 * 15-Oct-2010 Created
#include "..\inc\csl_nor.h"
CSL_Status NOR_setup(CSL_NorObj *norObj, Uint16 instId)
	CSL_Status status;
	status = CSL_SOK;
	norObj->emifRegs 	= CSL_EMIF_REGS;
	norObj->sysCtrlRegs = CSL_SYSCTRL_REGS;
	norObj->instId		= instId;
	return status;
CSL_Status NOR_emifResetAndClock(CSL_NorHandle hNor)
	CSL_Status 	status;
	Uint16		i;
	status = CSL_SOK;
	/* Configure EMIF */
	/* 1c26h ECDR */
	CSL_FINS(hNor->sysCtrlRegs->ECDR, SYS_ECDR_EDIV, 0x1);
	/* 1c04h PSRCR - Set Reset Count */
	CSL_FINS(hNor->sysCtrlRegs->PSRCR, SYS_PSRCR_COUNT, 0x20);
	/* 1c05h PRCR - enable emif self-clearing*/
	CSL_FINS(hNor->sysCtrlRegs->PRCR, SYS_PRCR_PG4_RST, 0x0);
	/* 1c05h PRCR - Reset EMIF */
	CSL_FINS(hNor->sysCtrlRegs->PRCR, SYS_PRCR_PG1_RST, 0x1);
	/* Give some delay for the device to reset */
	for(i = 0; i < 100; i++){;}
	/* Enable EMIF module in Idle PCGCR */
	CSL_FINST(hNor->sysCtrlRegs->PCGCR1, SYS_PCGCR1_EMIFCG, ACTIVE);
	return status;
CSL_Status NOR_setupEmifChipSelect(CSL_NorHandle hNor, CSL_NorConfig *norCfg)
	CSL_Status 					status;
	volatile ioport Uint16    	*asyncCSnCR1Addr;
    volatile ioport Uint16    	*asyncCSnCR2Addr;
	status = CSL_SOK;
	hNor->commandSet 		= norCfg->commandSet;
	hNor->norWidth			= norCfg->norWidth;
	if(CSL_NOR_16_BIT == norCfg->norWidth) {
		/*hNor->blockSize is in bytes. In 16bit device, one address points to 16bit or 2byte*/
		hNor->blockLength = norCfg->blockSize/2;
	} else if(CSL_NOR_8_BIT == norCfg->norWidth) {
		hNor->blockLength = norCfg->blockSize;
	hNor->numOfBlocks		= norCfg->numOfBlocks;
	hNor->writeBufferSize	= norCfg->writeBufferSize;
	hNor->norOpMode			= norCfg->norOpMode;
	hNor->enableUnlockSeq	= TRUE;
/*	hNor->intrNumNor		= 0;
	hNor->addrCycles		= 0;*/
	/* 1c00h EBSR - Configure EM_A[20:15] for EMIF */
	CSL_FINS(hNor->sysCtrlRegs->EBSR, SYS_EBSR_A20_MODE, 0x0);
	CSL_FINS(hNor->sysCtrlRegs->EBSR, SYS_EBSR_A19_MODE, 0x0);
	CSL_FINS(hNor->sysCtrlRegs->EBSR, SYS_EBSR_A18_MODE, 0x0);
	CSL_FINS(hNor->sysCtrlRegs->EBSR, SYS_EBSR_A17_MODE, 0x0);
	CSL_FINS(hNor->sysCtrlRegs->EBSR, SYS_EBSR_A16_MODE, 0x0);
	CSL_FINS(hNor->sysCtrlRegs->EBSR, SYS_EBSR_A15_MODE, 0x0);
	/* 1c33h ESCR - EMIF generates 16bit access to External Memory for every word access */
	CSL_FINS(hNor->sysCtrlRegs->ESCR, SYS_ESCR_BYTEMODE, 0x0);
	/* 1004h AWCCR1 MEWC - 0xFF (max) */
	CSL_FINS(hNor->emifRegs->AWCCR1, EMIF_AWCCR1_MEWC, norCfg->asyncWaitCfg->waitCycles);
	switch(norCfg->norChipSelect)
	case CSL_NOR_CS2:
		/* 1005h AWCCR2 - EM_WAIT0 pin for EM_CS2 */
		CSL_FINS(hNor->emifRegs->AWCCR2, EMIF_AWCCR2_CS2_WAIT, norCfg->asyncWaitCfg->waitPin);
		hNor->CSnBASE = (Uint32)CSL_EMIF_CS2_DATA_BASE_ADDR;
		hNor->DMABYTEADDR = (Uint32)CSL_NAND_CE0_ADDR;
		asyncCSnCR1Addr = &hNor->emifRegs->ACS2CR1;
		asyncCSnCR2Addr = &hNor->emifRegs->ACS2CR2;
		break;
	case CSL_NOR_CS3:
		/* 1005h AWCCR2 - EM_WAIT0 pin for EM_CS3 */
		CSL_FINS(hNor->emifRegs->AWCCR2, EMIF_AWCCR2_CS3_WAIT, norCfg->asyncWaitCfg->waitPin);
		hNor->CSnBASE = (Uint32)CSL_EMIF_CS3_DATA_BASE_ADDR;
		hNor->DMABYTEADDR = (Uint32)CSL_NAND_CE1_ADDR;
		asyncCSnCR1Addr = &hNor->emifRegs->ACS3CR1;
		asyncCSnCR2Addr = &hNor->emifRegs->ACS3CR2;
		break;
	case CSL_NOR_CS4:
		/* 1005h AWCCR2 - EM_WAIT0 pin for EM_CS4 */
		CSL_FINS(hNor->emifRegs->AWCCR2, EMIF_AWCCR2_CS4_WAIT, norCfg->asyncWaitCfg->waitPin);
		hNor->CSnBASE = (Uint32)CSL_EMIF_CS4_DATA_BASE_ADDR;
		hNor->DMABYTEADDR = (Uint32)CSL_ASYNC_CE0_ADDR;
		asyncCSnCR1Addr = &hNor->emifRegs->ACS4CR1;
		asyncCSnCR2Addr = &hNor->emifRegs->ACS4CR2;
		break;
	case CSL_NOR_CS5:
		/* 1005h AWCCR2 - EM_WAIT0 pin for EM_CS5 */
		CSL_FINS(hNor->emifRegs->AWCCR2, EMIF_AWCCR2_CS5_WAIT, norCfg->asyncWaitCfg->waitPin);
		hNor->CSnBASE = (Uint32)CSL_EMIF_CS5_DATA_BASE_ADDR;
		hNor->DMABYTEADDR = (Uint32)CSL_ASYNC_CE1_ADDR;
		asyncCSnCR1Addr = &hNor->emifRegs->ACS5CR1;
		asyncCSnCR2Addr = &hNor->emifRegs->ACS5CR2;
		break;
	default:
		break;
	switch(norCfg->asyncWaitCfg->waitPin)
	case CSL_NOR_WAIT0:
		/* 1005h AWCCR2 - Insert wait cycles if EM_WAIT0 is high/low */
		CSL_FINS(hNor->emifRegs->AWCCR2, EMIF_AWCCR2_WP0, norCfg->asyncWaitCfg->waitPol);
		break;
	case CSL_NOR_WAIT1:
		/* 1005h AWCCR2 - Insert wait cycles if EM_WAIT1 is high/low */
		CSL_FINS(hNor->emifRegs->AWCCR2, EMIF_AWCCR2_WP1, norCfg->asyncWaitCfg->waitPol);
		break;
	case CSL_NOR_WAIT2:
		/* 1005h AWCCR2 - Insert wait cycles if EM_WAIT2 is high/low */
		CSL_FINS(hNor->emifRegs->AWCCR2, EMIF_AWCCR2_WP2, norCfg->asyncWaitCfg->waitPol);
		break;
	case CSL_NOR_WAIT3:
		/* 1005h AWCCR2 - Insert wait cycles if EM_WAIT3 is high/low */
		CSL_FINS(hNor->emifRegs->AWCCR2, EMIF_AWCCR2_WP3, norCfg->asyncWaitCfg->waitPol);
		break;
	default:
		break;
	/* 1010h ACS2CR1 */
	CSL_FINS(*asyncCSnCR1Addr, EMIF_ACS2CR1_RSETUPLSB, (Uint16)(norCfg->asyncCfg->r_setup & 0x7));
	/* Set read strobe duration cycles */
	CSL_FINS(*asyncCSnCR1Addr, EMIF_ACS2CR1_RSTROBE, norCfg->asyncCfg->r_strobe);
	/* Set read strobe hold cycles */
	CSL_FINS(*asyncCSnCR1Addr, EMIF_ACS2CR1_RHOLD, norCfg->asyncCfg->r_hold);
	/* Set turn around cycles */
	CSL_FINS(*asyncCSnCR1Addr, EMIF_ACS2CR1_TA, norCfg->asyncCfg->turnAround);
	/* Set asynchronous memory size */
	CSL_FINS(*asyncCSnCR1Addr, EMIF_ACS2CR1_ASIZE, norCfg->asyncCfg->aSize);
	/* 1011h ACS2CR2 */
	CSL_FINS(*asyncCSnCR2Addr, EMIF_ACS2CR2_SS, norCfg->asyncCfg->selectStrobe);
	/* Set extended wait mode bit */
	CSL_FINS(*asyncCSnCR2Addr, EMIF_ACS2CR2_EW, norCfg->asyncCfg->ewMode);
	/* Set write srobe setup cycles */
	CSL_FINS(*asyncCSnCR2Addr, EMIF_ACS2CR2_WSETUP, norCfg->asyncCfg->w_setup);
	/* Set write duration cycles */
	CSL_FINS(*asyncCSnCR2Addr, EMIF_ACS2CR2_WSTROBE, norCfg->asyncCfg->w_strobe);
	/* Set write hold cycles */
	CSL_FINS(*asyncCSnCR2Addr, EMIF_ACS2CR2_WHOLD, norCfg->asyncCfg->w_hold);
	/* Set read strobe setup cycles */
	CSL_FINS(*asyncCSnCR2Addr, EMIF_ACS2CR2_RSETUPMSB, (norCfg->asyncCfg->r_setup >> 0x3));
#if 0
	/* 1068h PGMODECTRL1 & 1069h PGMODECTRL2*/
	/*For PHOENIX_QT*/
	CSL_FINS(hNor->emifRegs->PAGEMODCTRL1, EMIF_PAGEMODCTRL1_CS2_PAGE_DELAY, 0x2);
	CSL_FINS(hNor->emifRegs->PAGEMODCTRL1, EMIF_PAGEMODCTRL1_CS2_PAGE_SIZE, 0x1);
	CSL_FINS(hNor->emifRegs->PAGEMODCTRL1, EMIF_PAGEMODCTRL1_CS2_PAGEMOD_EN, 0x1);
	/*For EVM5515*/
	CSL_FINS(hNor->emifRegs->PAGEMODCTRL1, EMIF_PAGEMODCTRL1_CS2_PAGE_SIZE, 0x0);/*don't know*/
	CSL_FINS(hNor->emifRegs->PAGEMODCTRL1, EMIF_PAGEMODCTRL1_CS2_PAGEMOD_EN, 0x0);/*don't know*/
#endif
	return status;
CSL_Status NOR_readId(CSL_NorHandle hNor)
	CSL_Status 	status;
	status = CSL_SOK;
	/* Read NOR ID */
	if(CSL_NOR_INTEL_STD_CMDSET & hNor->commandSet)
		*(CSL_VUint16*)hNor->CSnBASE = 0x90;
	else if (CSL_NOR_AMD_STD_CMDSET & hNor->commandSet)
		if(CSL_NOR_8_BIT == hNor->norWidth)
			*(CSL_VUint16*)(hNor->CSnBASE+0xAAA) = 0xAA;
			*(CSL_VUint16*)(hNor->CSnBASE+0x555) = 0x55;
			*(CSL_VUint16*)(hNor->CSnBASE+0xAAA) = 0x90;
		else if(CSL_NOR_16_BIT == hNor->norWidth)
			*(CSL_VUint16*)(hNor->CSnBASE+0x555) = 0xAA;
			*(CSL_VUint16*)(hNor->CSnBASE+0x2AA) = 0x55;
			*(CSL_VUint16*)(hNor->CSnBASE+0x555) = 0x90;
	__asm("	NOP");/*For "A write followed by A read" pre-fetch reordering*/
	__asm("	NOP");
	__asm("	NOP");
		hNor->deviceID[0] = (*(CSL_VUint16*)(hNor->CSnBASE+0x00));/*man id*/
		hNor->deviceID[1] = (*(CSL_VUint16*)(hNor->CSnBASE+0x01));/*dev id*/
		hNor->deviceID[2] = (*(CSL_VUint16*)(hNor->CSnBASE+0x05));/*rcr*/
			hNor->deviceID[1] = (*(CSL_VUint16*)(hNor->CSnBASE+0x02));/*dev id-1*/
			hNor->deviceID[2] = (*(CSL_VUint16*)(hNor->CSnBASE+0x1C));/*dev id-2*/
			hNor->deviceID[3] = (*(CSL_VUint16*)(hNor->CSnBASE+0x1E));/*dev id-3*/
			hNor->deviceID[1] = (*(CSL_VUint16*)(hNor->CSnBASE+0x01));/*dev id-1*/
			hNor->deviceID[2] = (*(CSL_VUint16*)(hNor->CSnBASE+0x0E));/*dev id-2*/
			hNor->deviceID[3] = (*(CSL_VUint16*)(hNor->CSnBASE+0x0F));/*dev id-3*/
		/*Reset to exit auto-select mode for AMD*/
		*(CSL_VUint16*)(hNor->CSnBASE+0x0) = 0xF0;
	return status;
/* This is available only for Intel Command Based*/
/*The second arg is long because it is the block address not the block number*/
static CSL_Status NOR_readAndClearStatus(CSL_NorHandle hNor, Uint32 dBlockOffset, Uint16 *norStatus)
	CSL_Status status;
	status = CSL_SOK;
	{/* Read status register */
		*(CSL_VUint16*)(hNor->CSnBASE+dBlockOffset) = 0x70;
		__asm("	NOP");
		__asm("	NOP");
		__asm("	NOP");
		*norStatus = (*(CSL_VUint16*)(hNor->CSnBASE+dBlockOffset));
		/* Clear status register */
		*(CSL_VUint16*)(hNor->CSnBASE+dBlockOffset) = 0x50;
		__asm("	NOP");
		__asm("	NOP");
		__asm("	NOP");
	return status;
CSL_Status NOR_readCFI(CSL_NorHandle hNor)
	CSL_Status status;
	status = CSL_SOK;
	/* Read CFI */
		*(CSL_VUint16*)(hNor->CSnBASE+0x10) = 0x98;
	else if(CSL_NOR_AMD_STD_CMDSET & hNor->commandSet)
			*(CSL_VUint16*)(hNor->CSnBASE+0xAA) = 0x98;
			*(CSL_VUint16*)(hNor->CSnBASE+0x55) = 0x98;
	__asm("	NOP");
	__asm("	NOP");
	__asm("	NOP");
	hNor->cfiData[0] = (*(CSL_VUint16*)(hNor->CSnBASE+0x26));
	hNor->cfiData[1] = (*(CSL_VUint16*)(hNor->CSnBASE+0x27));
	hNor->cfiData[2] = (*(CSL_VUint16*)(hNor->CSnBASE+0x28));
	hNor->cfiData[3] = (*(CSL_VUint16*)(hNor->CSnBASE+0x29));
	hNor->cfiData[4] = (*(CSL_VUint16*)(hNor->CSnBASE+0x2a));
	hNor->cfiData[5] = (*(CSL_VUint16*)(hNor->CSnBASE+0x2b));
	hNor->cfiData[6] = (*(CSL_VUint16*)(hNor->CSnBASE+0x2c));
	hNor->cfiData[7] = (*(CSL_VUint16*)(hNor->CSnBASE+0x2d));
	hNor->cfiData[8] = (*(CSL_VUint16*)(hNor->CSnBASE+0x2e));
		/*Reset to exit Read-CFI mode in AMD*/
	return status;
CSL_Status NOR_readBlockLockStatus(CSL_NorHandle hNor, Uint16 *blockLockStatus)
	CSL_Status 	status;
	Uint16		blockLockConf;
	Uint32		i;
	status = CSL_SOK;
	__asm("	NOP");
	__asm("	NOP");
	__asm("	NOP");
	for(i=0; i<=130/*hNor->numOfBlocks*/; i++)//taking only first 130 blocks
			blockLockConf = (*(CSL_VUint16*)(hNor->CSnBASE+(i*hNor->blockLength)+0x2));
			/*This is the same for 8-bit and 16-bit*/
			blockLockConf = (*(CSL_VUint16*)(hNor->CSnBASE+((i*hNor->blockLength)&0xFFFFFF00)+0x02));
		if(blockLockConf & 0x1)
			/*Block is LOCKED*/
			blockLockStatus[i/16] |= (0x1 << (i%16));
			/*If bit[1] is set then Block is LOCKED-DOWN*/
		else
			/*Block is Unlocked*/
			blockLockStatus[i/16] &= (0x1 << (i%16));
	return status;
CSL_Status NOR_unlockBlock(CSL_NorHandle hNor, Uint16 blockNum, Uint16 *blockLockStatus)
	CSL_Status 	status;
	Uint32		dBlockAddress;
	status = CSL_SOK;
	dBlockAddress = (Uint32)blockNum * hNor->blockLength;
	/* Lock Block Setup Command */
		*(CSL_VUint16*)(hNor->CSnBASE+dBlockAddress) = 0x60;
	/* Unlock Block Command */
		*(CSL_VUint16*)(hNor->CSnBASE+dBlockAddress) = 0xD0;
	/* Read ID Command */
	__asm("	NOP");
	__asm("	NOP");
	__asm("	NOP");
	*blockLockStatus = (*(CSL_VUint16*)(hNor->CSnBASE+dBlockAddress+0x2));
	return status;
CSL_Status NOR_readArray(CSL_NorHandle hNor, Uint16 blockNum, Uint16 wordOffset)
	CSL_Status 	status;
	Uint32		dWordAddress;
	status = CSL_SOK;
	dWordAddress = ((Uint32)blockNum * hNor->blockLength) + (Uint32)wordOffset;
	/* Read Array Command */
		*(CSL_VUint16*)(hNor->CSnBASE+dWordAddress) = 0xFF;
		/*No unlock or command cycle required when bank is reading array data
		Issuing a reset command, as it may be required in some cases and
		it doesn't matter in others*/
		/* This is the same for 8 and 16 bit devices*/
		*(CSL_VUint16*)(hNor->CSnBASE+dWordAddress) = 0xF0;
	__asm("	NOP");
	__asm("	NOP");
	__asm("	NOP");
	return status;
CSL_Status NOR_enterUnlockBypassedMode(CSL_NorHandle hNor)
	CSL_Status status;
	status = CSL_SOK;
	/*This is only for amd cmdset based nor device*/
	/*Unlock bypass is possible only for wordWrite, blockErase and chipErase*/
			*(CSL_VUint16*)(hNor->CSnBASE+0xAAA) = 0x20;
			*(CSL_VUint16*)(hNor->CSnBASE+0x555) = 0x20;
		hNor->enableUnlockSeq = FALSE;
	return status;
CSL_Status NOR_exitUnlockBypassedMode(CSL_NorHandle hNor)
	CSL_Status status;
	status = CSL_SOK;
		/*This is the same for 8-bit and 16-bit devices*/
		*(CSL_VUint16*)(hNor->CSnBASE+0x0) = 0x90;
		*(CSL_VUint16*)(hNor->CSnBASE+0x0) = 0x00;
	return status;
CSL_Status NOR_eraseBlock(CSL_NorHandle hNor, Uint16 blockNum,
							Uint16 statusMode, Uint16 *eraseStatus)
	CSL_Status 		status;
	volatile Uint16 pollStatus;
	volatile Uint16 dqNValue;
	status = CSL_SOK;
	dBlockAddress = (Uint32)blockNum*hNor->blockLength;
	/* Block erase setup */
		*(CSL_VUint16*)(hNor->CSnBASE+dBlockAddress) = 0x20;
			if(hNor->enableUnlockSeq)
			*(CSL_VUint16*)(hNor->CSnBASE+0xAAA) = 0x80;
			*(CSL_VUint16*)(hNor->CSnBASE+0x555) = 0x80;
	/* Block erase confirm */
		if((CSL_NOR_8_BIT == hNor->norWidth) && hNor->enableUnlockSeq)
		else if((CSL_NOR_16_BIT == hNor->norWidth) && hNor->enableUnlockSeq)
		*(CSL_VUint16*)(hNor->CSnBASE+dBlockAddress) = 0x30;
		do {
			status = NOR_readAndClearStatus(hNor, 0, eraseStatus);
		} while(!(*eraseStatus & 0x0080));
	#if 0
		/*Check DQ3 for Erase Timer timedout condition*/
		do {
			dqNValue = (*(CSL_VUint16*)(hNor->CSnBASE+dBlockAddress));
		} while(0x0008 != (dqNValue & 0x0008));
	#endif
		/*After erase timer times out. erase algorithm begins*/
		if(CSL_NOR_DQ7_STATUS == statusMode)
			do {
				pollStatus = (*(CSL_VUint16*)(hNor->CSnBASE+dBlockAddress));
				if(0x0080 == (pollStatus&0x0080))
				{/*If DQ7=1 then erase complete or erase suspended state*/
					break;
			} while(0x0020 != (pollStatus&0x0020));/*Program/Erase/Write-to-Buffer timedout*/
			if(0x0020 == (pollStatus&0x0020))/*A timeout happened*/
					status = CSL_SOK;
				else
					status = CSL_EMMCSD_TIMEOUT;
					/*Issue a reset to change to read array mode*/
		}/*DQ7 status*/
		else if (CSL_NOR_DQ6_STATUS == statusMode)
			do {
				#if 0
				if((dqNValue&0x0004) == (pollStatus&0x0004))
				{/*DQ2 not toggling. This sector is not for erase*/
				/*As we are checking the status soon after the erase command,
				this condition shall always be in the toggle state*/
					break;
				#endif
				if((dqNValue&0x0040) == (pollStatus&0x0040))
				{/*DQ6 not toggling. Erase suspend or Erase complete*/
					break;
					status = CSL_SOK;
				else
		}/*DQ6 status*/
		*eraseStatus = pollStatus;
	}/*amd cmdset*/
	return status;
/*Uint16 is ok for wordOffset as we deal with 64KWord NOR device. Range is 0x0-0xFFFF*/
CSL_Status NOR_writeWord(CSL_NorHandle hNor, Uint16 blockNum,
						Uint16 wordOffset, Uint16 wordData,
						Uint16 statusMode, Uint16 *writeStatus)
	CSL_Status		status;
	status = CSL_SOK;
		*(CSL_VUint16*)(hNor->CSnBASE+dWordAddress) = 0x40;
			*(CSL_VUint16*)(hNor->CSnBASE+0xAAA) = 0xA0;
		{*(CSL_VUint16*)(hNor->CSnBASE+0x0) = 0xF0;
			*(CSL_VUint16*)(hNor->CSnBASE+0x555) = 0xA0;
	*(CSL_VUint16*)(hNor->CSnBASE+dWordAddress) = wordData;
		do {
			status = NOR_readAndClearStatus(hNor, 0, writeStatus);
		} while(!((*writeStatus) & 0x0080));
			dqNValue = wordData&0x0080;
			do {
				pollStatus = (*(CSL_VUint16*)(hNor->CSnBASE+dWordAddress));
				if(dqNValue == (pollStatus&0x0080))
				{/*If DQ7 read, is equal to DQ7 written then write is complete*/
					break;
					status = CSL_SOK;
				else
		}/*DQ7 status*/
			do {
				dqNValue = (*(CSL_VUint16*)(hNor->CSnBASE+dWordAddress));
				{/*If DQ6 stopped its toggle then write is complete*/
					break;
				/*read twice. will the compiler optimize??*/
					status = CSL_SOK;
				else
		}/*DQ6 status*/
		*writeStatus = pollStatus;
	}/*amd cmdset*/
	return status;
CSL_Status NOR_writeBufferSetup(CSL_NorHandle hNor, Uint16 blockNum,
								Uint16 wordOffset, Uint16 numOfWords)
	CSL_Status 		status;
	Uint16			writeStatus;
	status = CSL_SOK;
	if(hNor->writeBufferSize < numOfWords)
		status = CSL_ESYS_FAIL;
	/* Buffered Program Setup command */
		*(CSL_VUint16*)(hNor->CSnBASE+dWordAddress) = 0xE8;
		do {/* Wait for Buffer Ready on SR[7]*/
			#if 0
			status = NOR_readAndClearStatus(hNor, dWordAddress, &writeStatus);
			#endif
			writeStatus = *(CSL_VUint16*)(hNor->CSnBASE+dWordAddress);
		} while(!(writeStatus & 0x80));
		/* Write the number of Words to be written */
		*(CSL_VUint16*)(hNor->CSnBASE+dWordAddress) = numOfWords-1;
		*(CSL_VUint16*)(hNor->CSnBASE+dBlockAddress) = 0x25;
		*(CSL_VUint16*)(hNor->CSnBASE+dBlockAddress) = numOfWords-1;
	}/*amd cmdset*/
	return status;
CSL_Status NOR_writeBufferComplete(CSL_NorHandle hNor, Uint16 blockNum,
									Uint16 wordOffset, Uint16 numOfWords,
									Uint16 *writeBuffer, Uint16 statusMode,
	CSL_Status 		status;
	volatile Uint16 pollStatus=0;
	volatile Uint16 dqNValue=0;
	status = CSL_SOK;
	/* Buffered Program Confirm command */
		*(CSL_VUint16*)(hNor->CSnBASE+dBlockAddress) = 0x29;
		do { /*Wait for Buffer Ready on SR[7]*/
		} while(!((*writeStatus) & 0x80));
//			dqNValue = writeBuffer[numOfWords-1] & 0x0080;/*This is not working properly, with s/m test on QT - Pramod*/
			dqNValue = *(writeBuffer+numOfWords-1);
			dqNValue &= 0x0080;
			do {
				pollStatus = (*(CSL_VUint16*)(hNor->CSnBASE+dWordAddress+numOfWords-1));
					break;
				if(0x0002 == (pollStatus&0x0002))
				{/*When DQ1=1, it means that the Write-to-buffer programming has aborted*/
					/*Abort write-to-buffer*/
						*(CSL_VUint16*)(hNor->CSnBASE+dWordAddress) = 0x55;
						*(CSL_VUint16*)(hNor->CSnBASE+0x555) 		= 0xF0;
					break;
					status = CSL_SOK;
				else
			/*DQ1=1, is handled below*/
		}/*DQ7 status*/
			do {
				dqNValue = (*(CSL_VUint16*)(hNor->CSnBASE+dWordAddress+(Uint32)(numOfWords-1)));
				pollStatus = (*(CSL_VUint16*)(hNor->CSnBASE+dWordAddress+(Uint32)(numOfWords-1)));
					break;
					break;
					status = CSL_SOK;
				else
		}/*DQ6 status*/
	}/*amd cmdset*/
	return status;
 * Copyright (c) 2008-2016 Texas Instruments Incorporated.
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 *    Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *    its contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/** @file CSL_EMIF_NOR_CpuTransfer.c
 *  @brief EMIF functional layer polled mode example source file
 * \page    page13  CSL EMIF EXAMPLE DOCUMENTATION
 * \section EMIF5 EMIF EXAMPLE5 - NOR CPU MODE TEST
 * \subsection EMIF5x TEST DESCRIPTION:
 * NOTE:   NOR Flash on-board C5517 EVM is a 128Mbit Spansion flash S29Gl128S11DHIV20.
 * In CSL_NOR_Test.h, comment #define EVM5515 1 and Uncomment #define EVM5517 1 if running on C5517 EVM.
 * In CSL_NOR_Test.h, comment #define EVM5517 1 and Uncomment #define EVM5515 1 if running on C5515 EVM.
 * 1. Configure EMIF, start the clock and bring it out of reset.
 * 2. Configure the NOR flash parameters in EMIF registers such as AWCCR1, AWCCR2, ACS2CR1, ACS2CR2, etc.
 * 3. Read the manufacturer and device IDs.
 * 4. Check if the test-block is blocked for r/w or not.
 * 5. Erase the block and prepare it for r/w.
 * 6. Write a block of data to the selected block in the NOR Flash.
 * 7. Read a block of data from the test block.
 * 8. Perform a comparison of read and written data. There should be no mismatch.
 * NOTE: This test assumes that
 *  a. NOR flash is connected to emif cs2 on C5515 EVM and on C5517 EVM.
 * This example may not work with connections that are different from above
 * connections.
 * NOTE: THIS TEST HAS BEEN DEVELOPED TO WORK WITH CHIP VERSIONS C5515 AND
 * C5517. MAKE SURE THAT PROPER CHIP VERSION MACRO IS DEFINED IN THE FILE
 * c55xx_csl\inc\csl_general.h.
 * \subsection EMIF5y TEST PROCEDURE:
 *  @li Open the CCS and connect the target (C5515/C5517 EVM)
 *  @li Open the project "CSL_NOR_PollExample_Out.pjt" and build it
 *  @li Load the program on to the target
 *  @li Set the PLL frequency to 12.288MHz
 *  @li Run the program and observe the test result
 *  @li Repeat the test at the following PLL frequencies
 *      C5515: 60MHz and 100MHz
 *      C5517: 60MHz, 100MHz, 150MHz and 200MHz
 *  @li Repeat the test in Release mode
 * \subsection EMIF5z TEST RESULT:
 *  @li All the CSL APIs should return success
 *  @li Read and write data buffer comparison should be successful.
 * Revision History
 * 05-Sep-2008 Created
 * 10-Mar-2016 Updates to header
#include <stdio.h>
#include <string.h>
#include <csl_types.h>
#include "inc\csl_nor.h"
#include <csl_dma.h>
#include "CSL_NOR_Test.h"
/* Save the lock status of 130 blocks */
Uint16	gBlockLockStatus[CSL_NOR_BLOCKLOCK_STATUS_ARRAY];
/* Align is for optimum performance while using Buffered and BEFP Programming */
#ifdef CSL_NOR_USE_ALIGNED_BUFFER
#pragma DATA_ALIGN(gNorReadBuffer,CSL_NOR_BUFFER_ALIGN_BOUNDARY); /*32-byte boundary and it works*/
#endif
Uint16	gNorReadBuffer[CSL_NOR_TEST_BUFFER_WORD_COUNT];
#pragma DATA_ALIGN(gNorWriteBuffer,CSL_NOR_BUFFER_ALIGN_BOUNDARY); /*32-byte boundary and it works*/
#endif
Uint16	gNorWriteBuffer[CSL_NOR_TEST_BUFFER_WORD_COUNT];
CSL_Status CSL_norCpuTransferTest(void)
	CSL_Status 			status;
	CSL_NorObj			norObj;
	CSL_NorHandle		hNor;
	Uint16				norStatus;
	Uint16				blockNum;
	Uint32				i;
	Uint16				wordOffset;
#ifdef EVM5515
	CSL_NorAsyncCfg		norAsyncCfg		= PC28F128P30T85_ASYNCCFG_DEFAULT;
	CSL_NorAsyncWaitCfg	norAsyncWaitCfg = PC28F128P30T85_ASYNCWAITCFG_DEFAULT;
	CSL_NorConfig		norCfg			= PC28F128P30T85_NORCFG_POLLED;
#elif EVM5517
	CSL_NorAsyncCfg		norAsyncCfg		= S29GL128S11DHIV20_ASYNCCFG_DEFAULT;
	CSL_NorAsyncWaitCfg	norAsyncWaitCfg = S29GL128S11DHIV20_ASYNCWAITCFG_DEFAULT;
	CSL_NorConfig		norCfg			= S29GL128S11DHIV20_NORCFG_POLLED;
#endif
	status 				= CSL_SOK;
	hNor 				= &norObj;
	norCfg.asyncWaitCfg	= &norAsyncWaitCfg;
	norCfg.asyncCfg		= &norAsyncCfg;
	memset(&gNorReadBuffer, 0x0, sizeof(gNorReadBuffer));
	memset(&gNorWriteBuffer, 0x0, sizeof(gNorWriteBuffer));
	for(i=0; i<CSL_NOR_TEST_BUFFER_WORD_COUNT; i++)
		gNorWriteBuffer[i] = i;
	status = NOR_setup(&norObj, 0);
	if(CSL_SOK != status)
		printf("SETUP: Bad Status\n");
	status = NOR_emifResetAndClock(hNor);
		printf("NOR EMIF RST & CLK: Bad Status\n");
	/*norCfg was filled when it was defined*/
	status = NOR_setupEmifChipSelect(hNor, &norCfg);
		printf("SETUP EMIF CS: Bad Status\n");
	memset(hNor->deviceID, 0x0, sizeof(hNor->deviceID));
	status = NOR_readId(hNor);
		printf("READ ID: Bad Status\n");
	if((0xFF == hNor->deviceID[1]) || (0xFFFF == hNor->deviceID[1]))
		printf("No Device Found\n");
	else
		printf("Manufacturer ID %x\n", hNor->deviceID[0]);
		printf("Device ID %x\n", hNor->deviceID[1]);
	memset(hNor->cfiData, 0x0, sizeof(hNor->cfiData));
	status = NOR_readCFI(hNor);
		printf("READ CFI: Bad Status\n");
	/*Read Block Lock Status */
	memset(&gBlockLockStatus, 0x0, sizeof(gBlockLockStatus));
	status = NOR_readBlockLockStatus(hNor, &gBlockLockStatus[0]);
		printf("READ BLOCK LOCK STATUS: Bad Status\n");
	/*Unlock the Block*/
	blockNum = CSL_NOR_TEST_BLOCK_NUM;
	if(gBlockLockStatus[CSL_NOR_TEST_BLOCK_NUM/16] & (0x1 << (CSL_NOR_TEST_BLOCK_NUM%16)))
		status = NOR_unlockBlock(hNor, blockNum, &norStatus);
			printf("UNLOCK BLOCK: Bad Status\n");
		if(norStatus & 0x1)
			printf("Block-%d is LOCKED\n", blockNum);
			if(norStatus & 0x2)
				printf("Block-%d is LOCKED-DOWN\n", blockNum);
			else
				printf("Block-%d is not Locked-Down\n", blockNum);
		else
			printf("Block-%d is Unlocked\n", blockNum);
	else
		printf("Block-%d was Unlocked\n", blockNum);
	/* Erase the Block */
	norStatus = 0;
	//status = NOR_eraseBlock(hNor, blockNum, CSL_NOR_DQ7_STATUS, &norStatus);
	status = NOR_eraseBlock(hNor, blockNum, CSL_NOR_DQ6_STATUS, &norStatus);
	if(CSL_SOK == status)
			if(norStatus & 0x20)
				printf("ERASE: Failed\n");
				if(norStatus & 0x8)
					printf("ERASE: Vpp range Error\n");
				if((norStatus & 0x30) == 0x30)
					printf("ERASE: Command sequence Error\n");
				if(norStatus & 0x2)
					printf("ERASE: Block Locked Error\n");
		else
			printf("ERASE: Success\n");
	else
		printf("NOR_eraseBlock: Failed\n");
	/*Write the Block Using CPU*/
		//status = NOR_writeWord(hNor, blockNum, (Uint16)i, gNorWriteBuffer[i], CSL_NOR_DQ7_STATUS, &norStatus);
		status = NOR_writeWord(hNor, blockNum, (Uint16)i, gNorWriteBuffer[i], CSL_NOR_DQ6_STATUS, &norStatus);
				if(norStatus & 0x10)
					printf("PROGRAM: Failed\n");
					if(norStatus & 0x8)
						printf("PROGRAM: Vpp range Error\n");
						printf("PROGRAM: Command sequence Error\n");
					if(norStatus & 0x2)
						printf("PROGRAM: Block Locked Error\n");
					break;
		else
			printf("WRITE WORD: Bad Status\n");
			break;
	if(CSL_NOR_TEST_BUFFER_WORD_COUNT == i)
		printf("PROGRAM: Success\n");
	/*Read the Block Using CPU*/
	wordOffset = CSL_NOR_TEST_WORD_OFFSET;
	status = NOR_readArray(hNor, blockNum, wordOffset);
		printf("READ ARRAY: Bad Status\n");
	for(i=0;i<CSL_NOR_TEST_BUFFER_WORD_COUNT;i++)
		gNorReadBuffer[i] = (*(CSL_VUint16*)(hNor->CSnBASE+dWordAddress+i));
	/*Compare and print result*/
		if(gNorReadBuffer[i] != gNorWriteBuffer[i])
			printf("COMPARE: FAILED Data doesn't match at %d\n", i);
			break;
		printf("COMPARE: Success\n");
	return status;
/////INSTRUMENTATION FOR BATCH TESTING -- Part 1 --
/////  Define PaSs_StAtE variable for catching errors as program executes.
/////  Define PaSs flag for holding final pass/fail result at program completion.
volatile Int16 PaSs_StAtE = 0x0001; // Init to 1. Reset to 0 at any monitored execution error.
volatile Int16 PaSs = 0x0000; // Init to 0.  Updated later with PaSs_StAtE when and if
/////                                  program flow reaches expected exit point(s).
 * \brief Tests NOR
 * \param None
 * \param None
void main(void)
#if (defined(CHIP_C5535) || defined(CHIP_C5545))
	  printf("\nEnsure CHIP_C5517, CHIP_C5505_C5515 or CHIP_C5504_C5514 is #defined. C5535/C5545 don't have EMIF\n");
#else
	CSL_Status	status;
	status = CSL_SOK;
	status = CSL_norCpuTransferTest();
	if(0 != status){
		printf("NOR_CpuTransfer - Test FAILED!!\n\n");
		   	PaSs_StAtE = 0x0000; // Was intialized to 1 at declaration.
	}else
		printf("NOR_CpuTransfer - Test Passed\n\n");
	   /////INSTRUMENTATION FOR BATCH TESTING -- Part 3 --
   /////  At program exit, copy "PaSs_StAtE" into "PaSs".
   PaSs = PaSs_StAtE; //If flow gets here, override PaSs' initial 0 with
   /////                   // pass/fail value determined during program execution.
   /////  Note:  Program should next exit to C$$EXIT and halt, where DSS, under
   /////   control of a host PC script, will read and record the PaSs' value.
#endif
4101.CSL_NOR_Test.h
函数CSL_norCpuTransferTest()中用到了几个关键的宏
它们在CSL_NOR_Test.h中定义。
我现在换成MT28GU256AAA2EGC后,该怎么修改呢?
  • 还可以用SPI flash。
  • 用SPI flash启动速度太慢了,无法满足产品要求。之前发帖说过这个问题。提高SPI flash速度到最高,启动时间还要4~5秒。
  • 这几个宏不是必须要改的,只是一个名称,需要到csl_nor.h里的PC28F128P30T85 参数定义都要改成MT28GU256AAA2EGC的参数
  • 这个当然明白。我就是不知道怎么改这些参数。PC28xx和MT28xx都是intel的,Pin2Pin兼容,只是后者容量增大了一倍。
    但换上之后,CSL_EMIF_NOR_CpuTransfer例程无法正确识别,输出信息为“No Device Found”。
  • 先对比一下两份手册,device id 地址是一样的 :
    看了一下代码,应该跟配置没有关系。是不是硬件没焊好。
    CSL_Status status;
    status = CSL_SOK;
    /* Read NOR ID */
    __asm(" NOP");
    __asm(" NOP");
    return status;
    你也可以跟踪看一下读回来的deviceID0~3值到底是多少?
