工程师们好:
评估板:66AK2L06 CCS8
新建的IPC_messageq工程,编译结果报错 Cannot read property "base" from undefined ;
这是什么原因导致的,应该怎么改呢?
涉及到的代码如下:
config.bld 中 SR_0 部分: var SR_0 = { name: "SR_0", space: "data", access: "RW", base: 0x84800000, len: 0x200000, comment: "SR#0 Memory (2 MB)" }; ipc.cfg.xs 中 sharedregion 部分: var SR0Mem = Program.cpu.memoryMap["SR_0"]; SharedRegion.setEntryMeta(0, new SharedRegion.Entry({ name: "SR_0", base: SR0Mem.base, len: SR0Mem.len, ownerProcId: 1, isValid: true, cacheEnable: xdc.global.SR0_cacheEnable })
