刚拿到6678LE的评估板,CCS是5.1版本,系统是Xp,安装完光盘提供的驱动安装程序后。
在no boot 方式下,给板子上电。打开CCS5.1后,创建配置文件后(用的是XDS100v1),点击“Test connection”。出现如下错误提示:
this error is generated by TI's USCIF driver or utilities.
this value is '-151'(0xffffff69)
the title is 'SC_ERR_POD_OPEN'.
the explanaton is :
this utility failed to open the adapter for a custom emulator .
the adapter returned an error
[end]
请高手帮下忙,这是哪里出了问题?板子是新买的。
