SK-TDA4VM: SDK BUILDING PROBLEM
Part Number: SK-TDA4VM
when I flow this step ,I find some problem. http://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-sk-tda4vm/08_00_01_10/exports/docs/development_flow.html
log like below: I cannot find this file "ti_2a_wrapper.h". was it created by some scripts or download from somewhere? expecting your reply.
root@j7-evm:/opt/edge_ai_apps# ./setup_script.sh
tensorflow
dlpack
onnxruntime
edgeai-tidl-tools
edgeai-tiovx-modules
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = edgeai-tiovx-modules
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = edgeai-tiovx-modules-test
-- Configuring done
-- Generating done
-- Build files have been written to: /opt/edgeai-tiovx-modules/build
make[1]: Entering directory '/opt/edgeai-tiovx-modules/build'
make[2]: Entering directory '/opt/edgeai-tiovx-modules/build'
Scanning dependencies of target edgeai-tiovx-modules
make[2]: Leaving directory '/opt/edgeai-tiovx-modules/build'
[ 10%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_color_coo
[ 10%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_multi_sco
[ 15%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_img_mosao
[ 21%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_dl_pre_po
[ 26%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_dl_coloro
[ 31%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_sensor_mo
[ 36%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_viss_modo
[ 42%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_ldc_moduo
[ 47%] Linking C shared library ../../bin/Release/libedgeai-tiovx-modules.so
[ 47%] Built target edgeai-tiovx-modules
Scanning dependencies of target edgeai-tiovx-modules-test
[ 57%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovo
[ 63%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovo
[ 68%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovo
[ 73%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovo
[ 78%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovo
[ 84%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovo
[ 89%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_commo
[ 94%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/main.c.o
[100%] Linking C executable ../../bin/Release/edgeai-tiovx-modules-test
[100%] Built target edgeai-tiovx-modules-test
make[1]: Leaving directory '/opt/edgeai-tiovx-modules/build'
Install the project...
-- Install configuration: ""
-- Installing: /usr/lib/edgeai-tiovx-modules/libedgeai-tiovx-modules.so.0.1.0
-- Up-to-date: /usr/lib/edgeai-tiovx-modules/libedgeai-tiovx-modules.so
-- Up-to-date: /usr/include/edgeai-tiovx-modules/include
-- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_multi_scaler_modh
-- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_modules_common.h
-- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_sensor_module.h
-- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_dl_pre_proc_moduh
-- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_ldc_module.h
-- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_viss_module.h
-- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_color_convert_moh
-- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_ldc_module_lut_1h
-- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_img_mosaic_modulh
-- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_dl_color_blend_mh
edgeai-gst-plugins
The Meson build system
Version: 0.53.2
Source dir: /opt/edgeai-gst-plugins
Build dir: /opt/edgeai-gst-plugins/build
Build type: native build
Project name: GstTIOVX
Project version: 0.4.0
C compiler for the host machine: cc (gcc 9.2.1 "cc (GCC) 9.2.1 20191025")
C linker for the host machine: cc ld.bfd 2.34.0.20200220
Host machine cpu family: aarch64
Host machine cpu: aarch64
Found pkg-config: /usr/bin/pkg-config (0.29.2)
Run-time dependency gstreamer-1.0 found: YES 1.16.3
Run-time dependency gstreamer-base-1.0 found: YES 1.16.3
Run-time dependency gstreamer-video-1.0 found: YES 1.16.3
Run-time dependency gstreamer-check-1.0 found: YES 1.16.3
Run-time dependency gstreamer-allocators-1.0 found: YES 1.16.3
Run-time dependency tiovx found: YES 0.1.0
Run-time dependency ti_vision_apps found: YES 0.1.0
Run-time dependency edgeai_tiovx_modules found: YES 0.1.0
Compiler for C supports arguments -Wmissing-declarations: YES
Compiler for C supports arguments -Wmissing-prototypes: YES
Compiler for C supports arguments -Wredundant-decls: YES
Compiler for C supports arguments -Wundef: YES
Compiler for C supports arguments -Wwrite-strings: YES
Compiler for C supports arguments -Wformat: YES
Compiler for C supports arguments -Wformat-nonliteral: YES
Compiler for C supports arguments -Wformat-security: YES
Compiler for C supports arguments -Wold-style-definition: YES
Compiler for C supports arguments -Winit-self: YES
Compiler for C supports arguments -Wmissing-include-dirs: YES
Compiler for C supports arguments -Waddress: YES
Compiler for C supports arguments -Waggregate-return: YES
Compiler for C supports arguments -Wno-multichar -Wmultichar: YES
Compiler for C supports arguments -Wdeclaration-after-statement: YES
Compiler for C supports arguments -Wvla: YES
Compiler for C supports arguments -Wpointer-arith: YES
Compiler for C supports arguments -Wuninitialized: YES
Compiler for C supports arguments -Wunknown-pragmas: YES
Compiler for C supports arguments -Wunused-function: YES
Compiler for C supports arguments -Wunused-label: YES
Compiler for C supports arguments -Wunused-value: YES
Compiler for C supports arguments -Wunused-variable: YES
Compiler for C supports arguments -Werror: YES
Has header "dlfcn.h" : YES
Has header "inttypes.h" : YES
Has header "memory.h" : YES
Has header "poll.h" : YES
Has header "stdint.h" : YES
Has header "stdlib.h" : YES
Has header "stdio_ext.h" : YES
Has header "strings.h" : YES
Has header "string.h" : YES
Has header "sys/param.h" : YES
Has header "sys/poll.h" : YES
Has header "sys/prctl.h" : YES
Has header "sys/socket.h" : YES
Has header "sys/stat.h" : YES
Has header "sys/times.h" : YES
Has header "sys/time.h" : YES
Has header "sys/types.h" : YES
Has header "sys/utsname.h" : YES
Has header "sys/wait.h" : YES
Has header "ucontext.h" : YES
Has header "unistd.h" : YES
Has header "sys/resource.h" : YES
Program python3 found: YES (/usr/bin/python3)
Configuring config.h using configuration
Program hotdoc skipped: feature doc disabled
Message: Hotdoc not found, not building the documentation
Build targets in project: 17
Found ninja-1.10.0 at /usr/bin/ninja
ninja: Entering directory `build'
[24/59] Compiling C object 'ext/tiovx/d86ae3c@@gsttiovx@sha/gsttiovxisp.c.o'.
FAILED: ext/tiovx/d86ae3c@@gsttiovx@sha/gsttiovxisp.c.o
cc -Iext/tiovx/d86ae3c@@gsttiovx@sha -Iext/tiovx -I../ext/tiovx -I. -I../ -I/usc
../ext/tiovx/gsttiovxisp.c:76:10: fatal error: ti_2a_wrapper.h: No such file ory
   76 | #include "ti_2a_wrapper.h"
compilation terminated.
[26/59] Compiling C object 'ext/tiovx/d86ae3c@@gsttiovx@sha/gsttiovxldc.c.o'.
ninja: build stopped: subcommand failed.
[2/35] Compiling C object 'ext/tiovx/d86ae3c@@gsttiovx@sha/gsttiovxisp.c.o'.
[4/35] Compiling C object 'tests/check...cator@exe/libs_gsttiovxallocator.c.o'.
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = ti_dl_inferer
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = edgeai_utils
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = edgeai_common
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = app_edgeai
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = app_dump_model_info
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = app_config_checker
-- Configuring done
-- Generating done
-- Build files have been written to: /opt/edge_ai_apps/apps_cpp/build
make[1]: Entering directory '/opt/edge_ai_apps/apps_cpp/build'
make[2]: Entering directory '/opt/edge_ai_apps/apps_cpp/build'
Scanning dependencies of target ti_dl_inferer
Scanning dependencies of target edgeai_utils
make[2]: Leaving directory '/opt/edge_ai_apps/apps_cpp/build'
[  3%] Building CXX object utils/CMakeFiles/edgeai_utils.dir/src/edgeai_perfstao
[  7%] Building CXX object dl_inferer/CMakeFiles/ti_dl_inferer.dir/src/ti_dl_ino
[ 10%] Building CXX object utils/CMakeFiles/edgeai_utils.dir/src/ti_logger.cpp.o
[ 14%] Linking CXX static library ../../lib/Release/libedgeai_utils.a
[ 14%] Built target edgeai_utils
Scanning dependencies of target edgeai_common
[ 17%] Building CXX object common/CMakeFiles/edgeai_common.dir/src/pre_process_o
[ 21%] Building CXX object dl_inferer/CMakeFiles/ti_dl_inferer.dir/src/ti_dlr_io
[ 25%] Building CXX object common/CMakeFiles/edgeai_common.dir/src/post_processo
[ 28%] Building CXX object dl_inferer/CMakeFiles/ti_dl_inferer.dir/src/ti_onnx_o
[ 32%] Building CXX object common/CMakeFiles/edgeai_common.dir/src/post_processo
[ 35%] Building CXX object dl_inferer/CMakeFiles/ti_dl_inferer.dir/src/ti_tflito
[ 39%] Linking CXX static library ../../lib/Release/libti_dl_inferer.a
[ 39%] Built target ti_dl_inferer
[ 42%] Building CXX object common/CMakeFiles/edgeai_common.dir/src/post_processo
[ 46%] Building CXX object common/CMakeFiles/edgeai_common.dir/src/post_processo
[ 50%] Building CXX object common/CMakeFiles/edgeai_common.dir/src/inference_pio
[ 53%] Building CXX object common/CMakeFiles/edgeai_common.dir/src/edgeai_demo.o
[ 57%] Building CXX object common/CMakeFiles/edgeai_common.dir/src/edgeai_cmd_lo
[ 60%] Building CXX object common/CMakeFiles/edgeai_common.dir/src/edgeai_gst_wo
[ 64%] Building CXX object common/CMakeFiles/edgeai_common.dir/src/edgeai_classo
[ 67%] Building CXX object common/CMakeFiles/edgeai_common.dir/src/edgeai_demo_o
[ 71%] Building CXX object common/CMakeFiles/edgeai_common.dir/src/edgeai_utilso
[ 75%] Building CXX object common/CMakeFiles/edgeai_common.dir/src/edgeai_debugo
[ 78%] Linking CXX static library ../../lib/Release/libedgeai_common.a
[ 78%] Built target edgeai_common
Scanning dependencies of target app_edgeai
Scanning dependencies of target app_dump_model_info
[ 82%] Building CXX object app_dump_model_info/CMakeFiles/app_dump_model_info.do
[ 85%] Building CXX object app_edgeai/CMakeFiles/app_edgeai.dir/src/app_edgeai_o
[ 89%] Linking CXX executable ../../bin/Release/app_dump_model_info
[ 89%] Built target app_dump_model_info
Scanning dependencies of target app_config_checker
[ 92%] Building CXX object app_config_checker/CMakeFiles/app_config_checker.diro
[ 96%] Linking CXX executable ../../bin/Release/app_edgeai
[ 96%] Built target app_edgeai
[100%] Linking CXX executable ../../bin/Release/app_config_checker
[100%] Built target app_config_checker
make[1]: Leaving directory '/opt/edge_ai_apps/apps_cpp/build'
Setup Done!
