工程师你好,我在TI官网下载L138的BXL文件,然后使用Ultra Librarian转化为Altium designer格式的封装库,但是在运行脚本文件时,提示如下信息:unexpected symbol :. ,然后定位到脚本文件的这个位置:pad.X := MilsToCoord(Evaluate(s1)); 。请问是不是你们提供的脚本文件有什么错误,请你们解答?
我试了一下,好像没有问题,把产生的文件放在附件了,你试试看能不能用。
说明如下:
Symbol "OMAP-L138_ZWT_361_A" renamed to "OMAP-L138_ZWT_36"
Symbol "OMAP-L138_ZWT_361_B" renamed to "OMAP-L138_ZWT_00"
Symbol "OMAP-L138_ZWT_361_C" renamed to "OMAP-L138_ZWT_01"
Symbol "OMAP-L138_ZWT_361_D" renamed to "OMAP-L138_ZWT_02"
Component "OMAP-L138_ZWT_361" renamed to "OMAP-L138_ZWT_36"
Ultra Librarian Lite 5.3.163 Process Report
TextStyle count: 22
Padstack count: 1
Pattern count: 1
Symbol count: 4
Component count: 1
Export
************* Important Instructions Follow ************
All files exported to: C:\UltraLibrarian\Library\Exported\Altium\2013-04-27_00-48-18\2013-04-27_00-48-18.txt
To import your new library part into Altium follow these steps:
1. After running the Ultra Librarian export for the first time,
you will need to copy the following files into an area where
they can be accessed for all future translations. They are script
files that Altium will need to be able to find.
a. UL_Form.dfm
b. UL_Form.pas
c. UL_Import.pas
d. UL_Import.prjScr
2. The above script file will need to be run from within Altium.
This can be done by going to File, Open and selecting the
UL_Import.PrjScr file stored above.
3. Select the UL_Form.pas file form the new project that has loaded,
and then select runfrom the drop down menu. You will need to select
the form again. Run the form.
3. When the script is run, it will ask you for the file name of the
Ultra Librarian file to run. You should select the latest file
produced with a date code (for instance 2010-02-17_23-12-34.txt).
4. The script will open a new Integraged Library project and import
the Ultra Librarian data into it. When complete a message box
will pop up saying that import is done.
All files exported to: C:\UltraLibrarian\Library\Exported\Altium\2016-02-22_16-32-06\2016-02-22_16-32-06
a. UL_Form.dfm
b. UL_Form.pas
c. UL_Import.pas
d. UL_Import.prjScr
For additional information, please visit this site:
http://www.accelerated-designs.com/help/Altium_import.html
For a video tutorial, please visit:
http://youtu.be/pih50yx9HYU
All files exported to: C:\UltraLibrarian\Library\Exported\Concept\2016_02_22_16_32_06
To import your new library part to Concept:
1. Locate and run the generatefiles.bat.
2. Move file structure into your library structure.
你们是安装中出了什么问题吗?在安装过程中有一个步骤出现2外勾选项,都选上再往下安装就可以了。
