TDA4VM: 在Fusion1扩展板连接SG5-OX05BIR摄像头无法启动
Part Number: TDA4VM
硬件:
开发板:TDA4VM
扩展板:Fusion1 Board
摄像头:SG5-OX05BIR-4000-FPDLINK
系统:QNX + RTOS
现状:
我们在将TDA4VM开发板和Fusion1扩展板以及摄像头连接后,在串口终端运行run_app_single_cam.sh脚本,但是自动选择sensor drivers时,选择的是UB9xxx_RAW12_TESTPATTERN,并不是我们想要的sensor drivers,
而且保存图像时,图像只是colorbar的数据,并不是摄像头捕获到的数据,我们目前怀疑TI并不支持这款摄像头,导致这款摄像头无法启动。
问题:
1. 加串器和解串器可能需要重新配置,camera厂家提供了一套新的参数,我们应该如何配置?
2. 我们运行的是run_app_single_cam.sh,在TI提供的RTOS代码里哪部分可以修改加串器解串器的参数?
  • 在运行脚本时,自动选择sensor drivers会选择UB9xxx_RAW12_TESTPATTERN,应该并不是和我们的摄像头匹配的sensor drivers,以下是我们在运行demo时的log信息:
    J7EVM@QNX:/ti_fs/vision_apps# run_app_single_cam.sh
    APP: Init QNX ... !!!
    appIpcInit: IPC: Init QNX ... !!!
    appIpcInit: IPC: Init ... Done !!!
        32.504971 s: REMOTE_SERVICE: Init ... !!!
        32.505107 s: REMOTE_SERVICE: Init ... Done !!!
        32.505135 s: GTC Frequency = 200 MHz
    APP: Init ... Done !!!
        32.505165 s:  VX_ZONE_INIT:Enabled
        32.505178 s:  VX_ZONE_ERROR:Enabled
        32.505191 s:  VX_ZONE_WARNING:Enabled
        32.505437 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
        32.505478 s:  VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!!
    [tsdl]: ===========cfg_file_name: /ti_fs/vision_apps/app_single_cam.cfg===========
    sensor_selection = [0]
    ldc_enable = [0]
    num_frames_to_run = [1000000000]
    is_interactive = [1]
        32.509251 s: ISS: Enumerating sensors ... !!!
        33.009216 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
        33.009290 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
        33.009306 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
        33.009321 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
        33.009337 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
        33.009353 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
    Select camera port index 0-7 : 2
    6 registered sensor drivers
    a : IMX390-UB953_D3
    b : AR0233-UB953_MARS
    c : AR0820-UB953_LI
    d : UB9xxx_RAW12_TESTPATTERN
    e : UB96x_UYVY_TESTPATTERN
    f : GW_AR0233_UYVY
    Select a sensor above or press '0' to autodetect the sensor : Invalid selection
    . Try again
    a : IMX390-UB953_D3
    c : AR0820-UB953_LI
    f : GW_AR0233_UYVY
    Select a sensor above or press '0' to autodetect the sensor : 0
    Sensor selected : UB9xxx_RAW12_TESTPATTERN
    LDC Selection Yes(1)/No(0) : LDC Selection Yes(1)/No(0) : 1
    Querying UB9xxx_RAW12_TESTPATTERN
        53.025763 s: ISS: Querying sensor [UB9xxx_RAW12_TESTPATTERN] ... !!!
        53.026129 s: ISS: Querying sensor [UB9xxx_RAW12_TESTPATTERN] ... Done !!!
        53.026151 s: ISS: Initializing sensor [UB9xxx_RAW12_TESTPATTERN], doing IM_SENSOR_CMD_PWRON ... !!!
        53.026749 s: ISS: Initializing sensor [UB9xxx_RAW12_TESTPATTERN], doing IM_SENSOR_CMD_CONFIG ... !!!
    [MCU2_0]     53.026558 s: rawtestpat_PowerOn : Read 0x7a from register 0x0 on slave device 0x3d
        53.656005 s: ISS: Initializing sensor [UB9xxx_RAW12_TESTPATTERN] ... Done !!!
    read_test_image_raw : Unable to open file /ti_fs/vision_apps/test_data/img_test.raw
    app_create_viss : sensor_dcc_id = 9702
    Enabling LDC
    Creating LDC
    Invalid DCC size for LDC. Disabling DCC
    Scaler is enabled
        53.723003 s: ISS: Starting sensor [UB9xxx_RAW12_TESTPATTERN] ... !!!
        54.236004 s: ISS: Starting sensor [UB9xxx_RAW12_TESTPATTERN] ... !!!
     Demo : Single Camera w/ 2A
     p: Print performance statistics
     s: Save Sensor RAW, VISS Output and H3A output images to File System
     e: Export performance statistics
     x: Exit
     Enter Choice:
    Unsupported command
     x: Exit
     Enter Choice: s
    RAW file name /ti_fs/vision_apps/test_data/img_0000.raw
    YUV file name /ti_fs/vision_apps/test_data/img_viss_0000.yuv
    imgaddr_width = 3840
    imgaddr_height = 2160
    imgaddr_stride = 3840
    width = 3840
    height = 2160
    Written 12441600 bytes
    H3A file name /ti_fs/vision_apps/test_data/h3a_0000.bin
    YUV file name /ti_fs/vision_apps/test_data/img_msc_0000.yuv
    imgaddr_width = 1920
    imgaddr_height = 1080
    imgaddr_stride = 1920
    width = 1920
    height = 1080
    Written 3110400 bytes
    YUV file name /ti_fs/vision_apps/test_data/img_ldc_0000.yuv
    width = 1920
    height = 1080
     x: Exit
     Enter Choice:
    Unsupported command
     x: Exit
     Enter Choice:
  • 您好,我们已收到您的问题并升级到英文论坛寻求帮助,链接如下,如有答复将尽快回复您:
    e2e.ti.com/.../tda4vm-connecting-the-sg5-ox05bir-camera-on-the-fusion1-expansion-board-will-not-boot
  • 您好,
    请参阅以下note,其中有关于如何在成像框架中添加新的传感器驱动程序:
    https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/latest/exports/docs/psdk_rtos/docs/user_guide/developer_notes_image_sensor.html
    如果您在上面的menu选项中选择option"0",它会尝试自动检测传感器和串行器/解串器组合。在这种情况下,由于传感器不受支持,这个就很可能是从 ub960选择测试模式输出的原因。
    请您按照以上链接添加新的传感器,然后从sensor selection menu中选择该传感器。
