6424的中断向量表在哪找的到啊
你好,
可以下面的intvecs.asm
; * Copyright (c) Texas Instruments Inc 2002, 2003, 2004, 2005, 2006, 2007
; * Use of this software is controlled by the terms and conditions found
; * in the license agreement under which this software has been supplied.
; * @brief Interrupt vector file for C64x and C64x+.
; * @file intvecs.asm
; * @verbatim
; This file contains interrupt service table. The CPU interrupt 4 vector
; contains interrupt4 function.
; @endverbatim
; Global symbols defined here and exported out of this file
.global _intcVectorTable
.global _c_int00
.global _vector1
.global _vector2
.global _vector3
.global _interrupt4
.global _vector5
.global _vector6
.global _vector7
.global _vector8
.global _vector9
.global _vector10
.global _vector11
.global _vector12
.global _vector13
.global _vector14
.global _vector15
; This is a macro that instantiates one entry in the interrupt service table.
VEC_ENTRY .macro addr
STW B0,*--B15
MVKL addr,B0
MVKH addr,B0
B B0
LDW *B15++,B0
NOP 2
NOP
NOP
.endm
; This is a dummy interrupt service routine used to initialize the IST.
_vec_dummy:
B B3
NOP 5
; This is the actual interrupt service table (IST).
.sect ".vecs"
.align 1024
_intcVectorTable:
_vector0: VEC_ENTRY _c_int00 ;RESET
_vector1: VEC_ENTRY _vec_dummy ;NMI
_vector2: VEC_ENTRY _vec_dummy ;RSVD
_vector3: VEC_ENTRY _vec_dummy ;RSVD
_vector4: VEC_ENTRY _interrupt4 ;Interrupt4 ISR
_vector5: VEC_ENTRY _vec_dummy
_vector6: VEC_ENTRY _vec_dummy
_vector7: VEC_ENTRY _vec_dummy
_vector8: VEC_ENTRY _vec_dummy
_vector9: VEC_ENTRY _vec_dummy
_vector10: VEC_ENTRY _vec_dummy
_vector11: VEC_ENTRY _vec_dummy
_vector12: VEC_ENTRY _vec_dummy
_vector13: VEC_ENTRY _vec_dummy
_vector14: VEC_ENTRY _vec_dummy
_vector15: VEC_ENTRY _vec_dummy
;* Automated Revision Information
;* Changed: $Date: 2007-09-11 11:05:40 -0500 (Tue, 11 Sep 2007) $
;* Revision: $Revision: 3960 $
你好,
到下面的网站下载PSP, DM648_BIOSPSP_RELEASE_01_10_03\pspdrivers_1_10_03\packages\ti\sdo\pspdrivers\soc\c6424\examples\intc里面有中断例程。
https://www-a.ti.com/downloads/sds_support/targetcontent/psp/bios_psp/index.html
